How to. 2 or more motors on one axis. Gantry
02 Jan 2021 08:48 #193811
by nau
net ystep => parport.0.pin-05-out
net ystep => parport.0.pin-06-out
shall be:
net y0step => parport.0.pin-05-out
net y1step => parport.0.pin-06-out
same in rest of HAL (especially AXIS section)
Replied by nau on topic How to. 2 or more motors on one axis. Gantry LinuxCNC 2.8 Master
Problem in HAL file. You have to strip axis pins and connections. InsteadI have 2 Y axis... Now its not work after i edit INI file and HAL file...
Try to move z axis but in screen moving Y1 axis (join 2 in my hal file)
Its swaping...
This my ini and hal file
shall be:
The following user(s) said Thank You: Trihwangyudi1990
02 Jan 2021 09:26 #193814
by nau
dear rodw, tommylight, Clive S, phillc54 thank you for helping me!
including my new configs maybe that would help someone
I started fresh. New config with StepConf. Only thing is different that all step signals wasn't inverted and now it is. After inverting step's XYZ config won't worked (XZ worked and Y not) as before and I had to change Y limits to negative. After that XYZ config was fixed. Then I've changed all details for XYYZ configuration and now it's fully working XYYZ mode. At start in Joint mode and after homing it become Axis mode (world). Still don't understand logic of setting limits LinuxCNC but at least it's working.I think we have reached the limits of what can be done with remote trouble shooting. The unfortunate thing is that there are thousands of machines that are homing correctly so it not Linuxcnc at fault. You need to walk away for a day or two and then come back with fresh eyes, study the homing configuration docs and resolve the issue.
- Trihwangyudi1990
02 Jan 2021 10:31 #193819
by Trihwangyudi1990
X axis work.... Limit and home work
Y0 axis work but Y1 axis is swaping with Z axis..
Z axis cant move
The configuration of my ini and hal file after I change it
Replied by Trihwangyudi1990 on topic How to. 2 or more motors on one axis. Gantry LinuxCNC 2.8 Master
Change litle bit but now the problem...
Its swaping...
shall be:
Z axis cant move
02 Jan 2021 10:50 #193821
by nau
and set HOME_SEQUENCE = -1 to both joint 1 and 2 to home them together only
you have to home all first.Change litle bit but now the problem...
Z axis cant move
- Trihwangyudi1990
02 Jan 2021 15:33 #193844
by Trihwangyudi1990
Now its time to add rotary axis...
Great comunityB)
Thanks its work.... :
Z axis cant move
Great comunityB)
27 Jan 2021 22:59 - 27 Jan 2021 23:00 #196842
by mf290997
Replied by mf290997 on topic How to. 2 or more motors on one axis. Gantry LinuxCNC 2.8 Master
I changed my files according to your manual, but somehow the second motor of my Y axis doesn't move. the first motor, which I configured using stepconf does still try to move, but only loses steps due to the other motor stopping it. Here are my hal and ini files. I hope someone can help me with this issue.
# Generated by stepconf 1.1 at Wed Jan 27 23:05:41 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xcf00 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net zdir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net ydir => parport.0.pin-07-out
net y2step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
setp parport.0.pin-09-out-invert 1
net y2dir => parport.0.pin-09-out
net xenable => parport.0.pin-14-out
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net y2pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y2pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y2step <= stepgen.2.step
net y2dir <= stepgen.2.dir
net y2enable joint.2.amp-enable-out => stepgen.2.enable
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 35000
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
[EMC]
MACHINE = cnc
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 20.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 200.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/linuxcncaddi/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 39062
SERVO_PERIOD = 1000000
[HAL]
HALFILE = cnc.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 200.0
MAX_ACCELERATION = 500.0
MIN_LIMIT = -0.001
MAX_LIMIT = 710.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 710.0
STEPGEN_MAXACCEL = 625.0
SCALE = 106.666666667
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[AXIS_Y]
MIN_LIMIT = -0.001
MAX_LIMIT = 1220.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1220.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1220.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
[AXIS_Z]
MAX_VELOCITY = 19.0002432031
MAX_ACCELERATION = 60.0
MIN_LIMIT = -80.0
MAX_LIMIT = 0.001
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -80.0
MAX_LIMIT = 0.001
STEPGEN_MAXACCEL = 75.0
SCALE = 1280.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
Last edit: 27 Jan 2021 23:00 by mf290997.
28 Jan 2021 07:58 #196904
Replied by rodw on topic How to. 2 or more motors on one axis. Gantry LinuxCNC 2.8 Master
On your Y axis joints (joints 1 &2), change the home sequence on both to equal -1
HOME_SEQUENCE = -1
28 Jan 2021 09:45 #196913
by Clive S
Replied by Clive S on topic How to. 2 or more motors on one axis. Gantry LinuxCNC 2.8 Master
[JOINT_1]
TYPE = LINEAR
HOME = 0.0 This is the final home position
MIN_LIMIT = -0.001
MAX_LIMIT = 1220.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0 This is used to square the gantry (a small number) ie 0.25
HOME_SEARCH_VEL = 0 use this to search for the home switch ( if you change the sign it will reverse the direction) if it is zero it probably won't move
HOME_LATCH_VEL = 0 This number is set to the speed of the search to the switch ( if you change the sign it will reverse the direction)
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0 It is usual to have 0 for the Z axis (so that the Z will lift out of the way first) but for dual homing both axis have to have the same -ve number ie -1
TYPE = LINEAR
MIN_LIMIT = -0.001
MAX_LIMIT = 1220.0
FERROR = 1
MIN_FERROR = .25
HOME_USE_INDEX = NO
29 Jan 2021 02:32 #197026
by mf290997
Thanks for the help, the -1 did it. now, after homing, which at the moment does nothing, everything moves correctly.
I don't quite understand now, how I need to setup the homing. I don't want you use two endstops on Y, the system is rigid enough for me that homing on one side schould be enough for my needs.
Is there a good explanation on how to setup the hal/ini file for homing switch inputs? I think I can't use stepconf anymore, because that would override my previous changes, correct?
Clives explanations were very helpful, but I don't understand the difference between HOME_LATCH_VEL and HOME_SEARCH_VEL yet.
29 Jan 2021 02:47 #197027
Yes, now you have a working config. forget pncconf and edit by hand
Homing is describered here. Read it all but check out section 5 for all the velocities.
linuxcnc.org/docs/2.8/html/config/ini-homing.html
The whole thing about gantry machines is the use of two home switches allows the gantry to be squared when it homes.
Time to create page: 0.427 seconds
