Compiling on Debian Wheezy
21 Aug 2013 07:45 #37913
by tatel
Replied by tatel on topic Compiling on Debian Wheezy
tatel
I have now built a SMP version of 3.5.7-rtai and a Uni-processor version too, which seems to work very well.
There is a query regards the RTAI / magma repos and whether they were altered by a recent commit.
I will be testing that tomorrow, for now have used copies of previous pulls.
If you PM me, I can send you a URL for the configs and a zipped copy of the pulls.
You may have to bear with me for a bit, one of my email servers has gone down at present
22 Aug 2013 13:24 #37950
by tatel
Hi all,
I got a 2.6.32-11-rtai kernel running, in wheezy, this time using vanilla sources and rtai-source from apt.
It has been very instructive. It turns out that I need to boot with "lapic" If not, I get errors about permissions to load module, unknown symbol, rtf3, etc that, IIRC, got in the first build with 3.5.7/magma.
Some work with symbolic links resolved the issue of change from /usr/include/gnu to /usr/include/i386-linux-gnu/gnu
/usr/share/doc/rtai-source/Readme.Debian is instructive but the command
fakeroot make-kpkg --initrd kernel_image modules_image
didn't worked for me. It failed at modules image, so installed the new kernel package, rebooted, then in /usr/src/modules/rtai did the usual configure;make, install and got directory /usr/lib/realtime. But it didn't worked until reboot with "lapic"
@ArcEye: I Already PMailed you
Best regards
Best regards
22 Aug 2013 15:32 - 22 Aug 2013 15:33 #37952
by ArcEye
Replied by ArcEye on topic Compiling on Debian Wheezy
Hi
Glad you are making progress
Not received your PM, but email server has been playing up.
Probably not now necessary, I have built the latest pulls of magma and rtai and both work
magma is at fetchable with
cvs -d:pserver:anonymous@cvs.gna.org:/cvs/rtai co magma
The ShabbyX repo of RTAI 3.9.1 built to work with linuxcnc can be cloned with
git clone github.com/ShabbyX/RTAI RTAI
For the unified-build-candidate of linuxcnc
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
git checkout -b unified-build-candidate-2
My SMP .config for 3.5.7 is on a previous post
My UP .config for 3.5.7 is here
The essential part, apart from disabling SMP and choosing the exact processor type, is to enable APIC and APIC IO
This seems a bit counter intuitive, certainly it was not enabled in the 2.6.24-16 kernel with Hardy, but it is required by magma and
the build will error and not work without it.
I have been testing my UP 3.5.7 kernel on a P4 2.4GHz moving metal.
The only problem I have encountered is that the system is not as light as Hardy and even with lightdm and icewm, windowing events, mouse moves etc are creating latency spikes not
previously seen.
This will be because I am using the on-board video chip, which I could get away with on Hardy.
I have ordered a cheap secondhand AGP video card, which should hopefully remove that problem
Even without it, on automatic movement tests on my lathe, with 3000mm/min rapids and 100mm/s/s acceleration, over 20 minutes, completed without any missed steps or RT warnings.
Hopefully I have future-proofed my old computers
previously seen.
Last edit: 22 Aug 2013 15:33 by ArcEye.
The following user(s) said Thank You: tatel
22 Aug 2013 21:06 #37972
by tatel
Well, finally I got linuxcnc running on 3.5.7-rtai
Thank you all and specially ArcEye. You have been helpful.
I'm using RTAI not magma.
Im getting latency spikes about 500000 ns, tried to use smiset but failed (rtai_smi.ko not found). I see that modules directory is not very well set, I guess this has to be done at ./configure.
Time to relax
Regards
Time to relax
Regards
Time to create page: 0.073 seconds
