- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
04 Jun 2017 13:04 #94049
by trilobyte
Replied by trilobyte on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
i don't have internet connection during the next days. i can only go online with my cell phone. can someone provide me the .deb files to install linuxcnc? 2.7,2.8, or 2.9?
i've saved the deb files for the RT kernel, but i can't install linuxxcnc at the moment because my linux machine isn't able to connect to the internet.
- cncnoob1979
- Topic Author
- Thank you received: 75
13 Jun 2017 22:10 - 13 Jun 2017 22:11 #94482
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Here is a link to my built .deb of LinuxCNC 2.8Pre ~ USPACE that I use on my mill. I do not guarantee anything so use with caution.
1drv.ms/f/s!AlFSQXDHA0QAxGoqfsQwGBwqUzMm
Last edit: 13 Jun 2017 22:11 by cncnoob1979.
- verticalperformance
- Thank you received: 13
17 Jun 2017 05:16 #94637
by verticalperformance
Replied by verticalperformance on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Great tutorial, which saved me a huge amount of time and trouble!
I successfully managed to follow post#2 method and now have a running 2.7.8 version on 32Bit Mint. Apart from a little worse latency than Ubuntu 10.04 it all works fine. Bit of an old clunker of a PC so I'll put up with it.
I do have one question, how do I update to 2.7.9 without pulling that branch and recompiling from source?
I tried added "deb linuxcnc.org precise base 2.7-rtai" to the source list, and I can see that the docs are able to be updated to 2.7.9, but not the program itself.
If I go to Software Manger in Mint I can see LinuxCNC (not installed) and Linuxcnc-uspace (which is installed) so I suspect this is why an update is not being reported.
Maybe another thread on "how to keep it updated" ?
Thanks,
Keith
Thanks,
Keith
- Gommiswald
26 Jun 2017 19:20 #95001
by Gommiswald
Replied by Gommiswald on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Hi
That is really great, what you have made here. Without this documentation I would not be able to run my MESA 7I76E card in Linux Mint! Thank you very much!
Daniel
Daniel
- cncnoob1979
- Topic Author
27 Jun 2017 18:34 #95066
by cncnoob1979
Keith,
I have not tried to update one of my built debs to a buildbot version.
I just recompile every now and again. I actually use the master branch religiously. It's quite stable. If you get that working I could add it to the topic.
Daniel,
Glad you found this useful. Glad I could help.
All,
I'm still around. Still very busy as I have recently moved and dealing with a remodel.
Take care,
James
Daniel,
All,
Take care,
James
- Gommiswald
28 Jun 2017 09:53 #95099
by Gommiswald
Hello
I just got a problem. I made the Post 2 till the end. But I cannot find - as you write at the end of Post 2 "Note: After...." anywhere in Main Menu an listing of CNC. Have you an idea, what I could do - maybe what I made wrong?
Thanks a lot and kind regards
Daniel
Daniel
28 Jun 2017 11:22 #95100
by PKM
Replied by PKM on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Daniel,
You installed the linuxcnc-uspace_2.8.0....deb, right?
Read the blue text note at the end of post 2.
- Gommiswald
28 Jun 2017 12:17 #95102
by Gommiswald
Hi
I have followed step by step post 2 with "Downloading and Configuring LinuxCNC" and I have seen the note at the end of post 2. But nowhere a listing of CNC. Maybe someone else encountered the same problem?
Daniel
Daniel
28 Jun 2017 17:31 #95121
by PKM
What exactly did you do after issuing "../debian/configure uspace ; debuild -uc -us"?
- Gommiswald
28 Jun 2017 18:45 #95133
by Gommiswald
I just closed the terminal.
- General
