- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- InMyDarkestHour
- User is blocked
- Thank you received: 111
12 Apr 2018 04:03 #108868
by InMyDarkestHour
Replied by InMyDarkestHour on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
If you are having trouble in ubuntu 16.04 finding packages it is best to use aptitude and do a search
tcl8.6-dev & tk8.6-dev are listed & current for ubuntu 16.04
You can use this page to search for packages
packages.ubuntu.com/
- InMyDarkestHour
- User is blocked
12 Apr 2018 04:08 #108869
by InMyDarkestHour
ftp://ftp.kernel.org has changed to www.kernel.org
The linux kernel sources have been moved from ftp servers to http servers. It happened a few months ago and probably slipped the notice of many useres.
- cncnoob1979
- Topic Author
- Thank you received: 75
12 Apr 2018 14:30 #108878
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Yes this was covered a few pages back. However I am not able to edit the main postings any longer.
Since the latest forum upgrade you can not edit any prior replies/entries you created if there is a response/reply to thread you created.
Hence I can no longer make updates to my 4 postings in the.begining of this thread. Maybe someone / mod can help me with that?
12 Apr 2018 14:41 #108880
Replied by andypugh on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Post a list of corrections (either here or in an email) and I will make the changes
12 Apr 2018 14:47 #108882
I am confused now.
What method of installing are you trying to use? In another email you seem to be patching a kernel. Here you seem to be doing something else.
As far as I know you are using Ubuntu 16.04 (Xenial Xerus) so I am not sure which options will work.
My entering of the long code at post 4
I am confused now.
12 Apr 2018 20:43 #108897
by dbanks
Replied by dbanks on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
I gave up on that. Impending timelines and making no progress spurred a change in direction.
12 Apr 2018 20:47 #108898
by dbanks
Might not be searching right but I was unable to locate any 4.8x anything. I'm not doing 16.04 anymore, I'm trying Mint instead, as there looks to be a ton more documentation.
12 Apr 2018 20:50 - 12 Apr 2018 20:53 #108899
by dbanks
That worked. It's downloading. I mistyped it a few times haha.
Last edit: 12 Apr 2018 20:53 by dbanks.
12 Apr 2018 20:59 - 12 Apr 2018 21:09 #108902
by dbanks
Typing Make Xconfig gave me fatal error sys/types.h: no such file or directory. Did I do something wrong in a step prior to this for this to happen? I tried using Make menuconfig with the same result.
Last edit: 12 Apr 2018 21:09 by dbanks.
- InMyDarkestHour
- User is blocked
12 Apr 2018 21:36 #108905
by InMyDarkestHour
Mint is based on Ubuntu 16.04
If you look at your apt sources you will see references to ubuntu
- General
Time to create page: 1.658 seconds
