- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- InMyDarkestHour
- User is blocked
- Thank you received: 111
07 May 2018 10:38 #110321
by InMyDarkestHour
Replied by InMyDarkestHour on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Could be related to this
forum.linuxcnc.org/9-installing-linuxcnc...installing-it#109582
There is a forum search function
The following user(s) said Thank You: Aklinahs
07 May 2018 15:23 #110329
by Aklinahs
Replied by Aklinahs on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
'm trying to install linux cnc to ubuntu 16.04 64bit...
now im at this step
sudo apt-get update
cd linuxcnc-dev
cd debian
./configure uspace [ or ./configure -r]
cd ..
dpkg-checkbuilddeps
when i entering this line ./configure uspace im getting an error saying
unknown distribution: Ubuntu-16.04
configuration may be wrong!
successfully configured for 'uspace-Ubuntu-16.04'-'uspace'..
What could be the error
now im at this step
sudo apt-get update
cd linuxcnc-dev
cd debian
cd ..
dpkg-checkbuilddeps
- cncnoob1979
- Topic Author
- Thank you received: 75
07 May 2018 17:20 #110330
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
You need to enable source code repositories.
I cover this in the first page of threads. I also posted pictures.
The unknown configuration issue maybe the distribution is unknown.
You should still be ok. Try it out and see.
08 May 2018 06:26 - 08 May 2018 06:27 #110368
by Aklinahs
Last edit: 08 May 2018 06:27 by Aklinahs.
12 May 2018 10:35 #110596
by bkt
on some wiki/hoto (not these that is well done) the point is not well placed the right one is "point, pace, point,slach, scripts, slash, rip-environments" only ... not double point at the end or other only 2 point with one space between.
After these command:
At these point axis gui window will be opened.
giorgio
Replied by bkt on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
. ./scripts/rip-environment
linuxcnc
giorgio
12 May 2018 15:04 - 12 May 2018 15:11 #110602
by Grotius
Replied by Grotius on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Hi K1,
Nice avatar !! Pinquin kenobi...
For run linux in place, the exact typing command is very strange indeed, for me in beginning also very confusing :
. ./rip-environment ( dot space dot / rip-environment )
linuxcnc
Sector 1:
in code :
In picture :
I see Aklinahs is installing lintian.... There is no ask for " sudo make setuid " ... So that is different from orginal linuxcnc install.
No experience for me so far with lintian.
I would prefer first command after compiling would be : sudo make setuid
After that change to scrips directory and type sector 1.
linuxcnc
Sector 1:
in code :
. ./rip-environment
linuxcnc
In picture :
Last edit: 12 May 2018 15:11 by Grotius.
- InMyDarkestHour
- User is blocked
13 May 2018 02:34 - 13 May 2018 02:35 #110629
by InMyDarkestHour
Last edit: 13 May 2018 02:35 by InMyDarkestHour. Reason: Stupid me forgot to include linkl
- InMyDarkestHour
- User is blocked
13 May 2018 02:40 #110630
by InMyDarkestHour
Methinks, with paranoia, that Aklinahs maybe doing an assessment.......as his very first post was for someone to write a complete HOWTO on installing linuxcnc in ubuntu 16.04, there was no searching the forum for this at all, otherwise he would have found a couple of discussions regarding this.
But I'm old & grumpy
Hi K1,
13 May 2018 04:02 - 13 May 2018 04:02 #110640
by curtisa
Replied by curtisa on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
...or he's just a Linux novice like a lot of people here and just needed that last bit of help to get him over the line.
As much as I love LinuxCNC, as a Linux beginner I do sometimes find it frustrating that to install a bit of software on the OS generally takes a few more jumps than just double-clicking on 'setup.exe'. This can be further complicated when you just want to run the mill rather than spend a few days being an impromptu computer programmer trying to get the software to install in the first place.
While I eventually got LCNC to install on Mint 18.1 by following post 3 in this thread (for which I am eternally grateful to cncnoob1979 for his efforts in putting the tutorial together), it didn't go entirely according to the wording of the instructions and I still had to jump back and forth to this thread a few times to find out where I was getting stuck.
If you're more used to installing stuff in Windows, then the initial culture shock of Linux takes a bit of effort getting used to. Dependencies? Building? Git-cloning? Why can't I just download 'installer.msi' and click on it?
...Just the ramblings of somebody on the other side of the 'Window' look in.
Last edit: 13 May 2018 04:02 by curtisa.
- InMyDarkestHour
- User is blocked
13 May 2018 04:30 #110641
by InMyDarkestHour
I tend to disagree, every issue he came up against was a question to forum, where as most of them could be resolved by searching.
Spend time on any electronics forum and just wait for the lazy ones to try and get other's to do their home work in a round about way.
No one is born able to use Linux.
And hey it's a hell of a lot easier to use now than 20 odd years ago. Debian\Ubuntu\Mint and other debian based distros make installing software almost as easy as Windows. Geesh installing via rpm's was dependency hell.
Even know my favourite all time distro doesn't have any dependency checking......but ldd and google really help.
For fun grab a '486 with 16MB install Redhat 6 and wait for X windows to start.
Git & Building software isn't particular to Linux.
Actually if you follow the instructions at the beginning of the thread it works, admittedly kernel.org no longer hosting ftp is a bit of a blah, but even that can be worked out by a quick google search. Unknown host is an issue that can be resolved by google. Trying to connect to ftp.kernel.org would be an issue on any platform.
And I bet someone who had never used Windows, either from a MAC or Linux\Unix background would have issues with learning that OS.
- General
Time to create page: 0.159 seconds
