- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
No one is born able to use Linux.
And hey it's a hell of a lot easier to use now than 20 odd years ago. Debian\Ubuntu\Mint and other debian based distros make installing software almost as easy as Windows. Geesh installing via rpm's was dependency hell.
Yes, I remember spending some time at a similar period trying to get into Linux too, tempted by the possibility that I might be able to start using a 'free' alternative to Cubase for recording music ( Ardour ). The convoluted installation process however made it entirely unappealing at the time.
So yes, I agree that installation of packages under Linux is a lot simpler than it has ever been. Even so, I would think most people with above-average computer literacy skills would still view a dry installation of Mach 3 in XP as a much simpler task than a dry install of LCNC under Mint or Ubuntu 16.04 or Debian etc. The fact that this tutorial exists at all would indicate as much.
I guess what I'm saying is don't judge the novice users too harshly for asking some questions about the process. I'm a relative newcomer to Linux too and had to make a few educated guesses and searches about what I was doing in order to get this tutorial to just 'work'. For all we know, English may not be Aklinahs native language and wading through a 46-page thread to find out why ftp://kernal.org doesn't work anymore may not be particularly easy for him.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
And don't forget to do everything Legally (ie no dodgy copy of XP or Win2k) and to have restricted cnc controller software Linux is the alternative. And the free alternative as well. Yes you can Mach3 without buying a license but that restircts you too 50 lines of gcode. GRBL is another free alternative but it lacks many many features.
There is no need to read thru 46 page thread as to why ftp.kernel.org doesn't work.....a Google search turns up that info rather quickly.
The tutorial is spot on the money if you carefully follow the directions, one of the better written tutorials out there, in just about any subject. It's quite impressive.
Use this instead;
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev EDIT:.
I tried but I get this message: fatal: unable to connect to github.com
What can I do?
fatal remote error:
Repository not found.
the help.github tells (help.github.com/articles/error-repository-not-found/) Check your spelling, Checking your permissions, Check your SSH access, Check that the repository really exists
Just for fun, and it probably won't help: sudo git clone ...
The repository definitely exists.
I suspect AGK has some internet access issues
serverfault.com/questions/189070/what-fi...nal-git-repositories
For what is this:
Open a terminal and do the following with your name and email:
git config --global user.name "Your full name"
git config --global user.email "This email address is being protected from spambots. You need JavaScript enabled to view it."
- InMyDarkestHour
- User is blocked
git clone git://github.com/zultron/smictrl.git
git clone https://github.com/zultron/smictrl.git
- General
