- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
- InMyDarkestHour
- User is blocked
- Thank you received: 111
03 Jun 2018 18:23 #111534
by InMyDarkestHour
Replied by InMyDarkestHour on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Yeah it's safe, I don't know if you noticed but when you first boot the Linuxcnc install in the top right there is a message about 300 or so updates available. The version of Linuxcnc that is installed is 2.7.0.
I think you'll find the Linuxcnc 2.7 install is the easiest, no need to compile a kernel. apt-get does it all.
You may want to look at this available for both debian & Linux Mint:
aptoncd.sourceforge.net/
Should save you a bit of time when you decide to do an install of your cnc computer. Allows you to save all the updates and and extras you install on a cd. I usally add geany + geany-plugins (a tabbed text editor), midnight commander and gftp (a gui ftp client) to any install I do.
One thing I will do when I get my new MB is do some comparison testing between XFCE & LXDE on latency......on one machine I was testing on LXDE seemed to have lower latencies........but that was with an install of a Slackware based distro, with a self compiled kernel and install of Linuxcnc.
03 Jun 2018 20:14 #111546
by Sparky961
Or not... This is the part of linux that gets frustrating for anyone less than an advanced user. I did this, plus a few other things that will be listed below, and ended up with an error. I've been logging each command executed and the result thereof so that I could post it when I ran into a problem.
Here it is:
Replied by Sparky961 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
There are 2.7 uspace packages available to install.
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install linuxcnc-uspace
Job done.
Here it is:
LinuxCNC 2.7 Wheezy (linuxcnc-2.7-wheezy.iso)
sudo apt-get update
--> Seemed to work - lots of scrolling terminal output, no obvious errors
sudo apt-get upgrade-dist
--> wow, that takes a long time and does a lot of scary stuff... but otherwise seemed to work
uname -r
--> 3.4.9-rtai-686-pae
tested linuxcnc
--> axis sim works (RTAPI ERROR: Unexpected realtime delay on task 1 - likely due to running in VirtualBox)
tested glade
--> version 3.8.0, preferences window has GtkBuilder (default) and Libglade, HAL Python and VCP Actions widget panels are displayed
install VirtualBox Guest Additions with instructions at: https://www.linuxbabe.com/desktop-linux/how-to-install-virtualbox-guest-additions-on-debian-step-by-step
sudo apt-get install build-essential module-assistant
sudo m-a prepare
[mount cd image]
sudo sh /media/cdrom/autorun.sh
--> Seemed to build kernal module ok.
Restart
--> VirtualBox Guest Additions isn't working properly, based on auto-resize guest window not working. Not a problem, but annoying.
--> "Package linuxcnc-uspace is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package 'linuxcnc-uspace' has no installation candidate' "
03 Jun 2018 20:22 #111548
by Sparky961
According to these instructions (linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel) there's an important step that was missed. It looks like I need to install a preempt-rt kernel first. See #4 at above link.
I'm waiting for 80+ MB now and will try continuing through those instructions to see if I get positive results.
- InMyDarkestHour
- User is blocked
03 Jun 2018 20:33 - 03 Jun 2018 20:40 #111551
by InMyDarkestHour
Installing uspace will also install the kernel no need to build one.
if not try:
Do you have a
Mine is as such, if you edit yours to match make sure to do
Just checked and seems to be working.
if not try:
sudo apt-get --install-recommends linuxcnc-uspace
Do you have a
/etc/apt/sources.list.d/linuxcnc.list
sudo apt-get update
deb http://linuxcnc.org/ wheezy base 2.7-rtai
deb-src http://linuxcnc.org/ wheezy base 2.7-rtai
deb http://linuxcnc.org/ wheezy 2.7-uspace
deb-src http://linuxcnc.org/ wheezy 2.7-uspace
#deb http://buildbot.linuxcnc.org/ wheezy master-rt
#deb-src http://buildbot.linuxcnc.org/ wheezy master-rt
#deb http://buildbot.linuxcnc.org/ wheezy 2.7-rt
#deb-src http://buildbot.linuxcnc.org/ wheezy 2.7-rt
Last edit: 03 Jun 2018 20:40 by InMyDarkestHour.
03 Jun 2018 21:02 #111556
by Sparky961
So in the meantime, as I'm working and posting at the same time, I did install the preempt-rt kernel and everything seems to be working with that. Maybe I'll have to uninstall that later, and I hope it's as easy as installing - because that was truly painless.
My /etc/apt/sources.list.d/linuxcnc.list does not match what you provided. I have not manually altered it from the initial install, so I see two possibilities: 1. you or some other application has added the -uspace lines to yours 2. some other application has removed the -uspace lines from mine.
So now I have to decide which of the two instruction sets to keep following....
(Aside: Sorry if this is to be considered "thread hijacking". It started out related but has taken a different direction than I anticipated. Feel free to tell me to take it elsewhere.)
On a related note, the dist-upgrade for my Mint install is STILL running. I'm not far off from 24 hours of run time on that now. It has until tomorrow morning to finish, then I'll have to restart it at work. On the plus side, my work network is blazing fast in comparison to home.
- InMyDarkestHour
- User is blocked
03 Jun 2018 21:08 #111558
by InMyDarkestHour
Yeah sorry I added the uspace lines, should have mentioned that.
03 Jun 2018 21:14 #111559
by Sparky961
No need to apologize. If I'm not used to conflicting and incomplete information by now I really shouldn't be doing this.
I wonder if step #8 in the "Getting LinuxCNC" article will alter that file in the same way. It seems it's doing the same thing. I'll check if this file is altered after I'm done.
- InMyDarkestHour
- User is blocked
03 Jun 2018 21:19 #111560
by InMyDarkestHour
I didn't even see that, I just added the sources and went ahead on my own.....note to self RTFM
03 Jun 2018 21:42 #111562
by Sparky961
04 Jun 2018 06:43 #111576
by AGK
Replied by AGK on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
wiki.linuxcnc.org/cgi-bin/wiki.pl?Translation - The next. 4. Building the Document I do this:
agk@debian:~$ cd linuxcnc-dev/src
agk@debian:~/linuxcnc-dev/src$ ./autogen.sh
agk@debian:~/linuxcnc-dev/src$ ./configure --enable-build-dokumentation >> /home/debian/Desktop/configure.txt 2>&1
bash: /home/debian/Desktop/configure.txt: Datei oder Verzeichnis nicht gefunden
and:
agk@debian:~/linuxcnc-dev/src$ ./configure --enable-build-dokumentation >> /home/debian/Desktop?/configure.txt 2>&1
bash: /home/debian/Desktop?/configure.txt: Datei oder Verzeichnis nicht gefunden
What is wrong?
and:
What is wrong?
- General
Time to create page: 0.248 seconds
