(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
24 Dec 2019 20:01 #153163
by jj80909
Replied by jj80909 on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I got it to work with 4.14.28-rt23-kona-rt_amd64.
I also loaded grub customizer with the instructions from John Thornton's page.
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
and then deleted all options except 4.14.28-rt23-kona-rt and 4.14.28-rt23-kona-rt (recovery mode).
sudo apt-get update
- Topic Author
- Thank you received: 5924
24 Dec 2019 20:11 #153164
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Well if the PC has PS/2 connectors for the keyboard and mouse and you have a USB keyboard attached, then holding any key during boot time will not work, forgot to mention that.
Glad you got it working, i will add the Grub Customizer info to the original post in case someone else has the same issue.
Thank you for reporting back.
04 Jan 2020 22:22 #154035
by tjmarch
Replied by tjmarch on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
This also worked for Lubuntu 18.04
Thanks alot Tommylight
Tim
Tim
05 Jan 2020 00:07 #154051
by ytiuqibu
Replied by ytiuqibu on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Given the successes reported here should consideration be given to pinning this thread at least in the short term?
- Topic Author
05 Jan 2020 01:59 #154065
Thank you.
Done.Given the successes reported here should consideration be given to pinning this thread at least in the short term?
Thank you.
07 Jan 2020 21:33 #154258
by Mladen
Replied by Mladen on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Thank you for instructions, but I got this massage:
Cannot upgrade secure boot enforcement policy due to unsigned kernels.
Your system has UEFI secure boot enabled in firmware, and the following kernels present on your system are unsigned: 4.16.12.-rt-kona-rt.
How to solve it?
How to solve it?
07 Jan 2020 21:45 #154260
Replied by andypugh on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
You might be able to turn off secure boot in the BIOS.
Or it might be impossible to install any Linux on that motherboard.
07 Jan 2020 21:48 #154261
There might be an answer here: askubuntu.com/questions/1069433/upgrade-...6-04-to-18-04-failed
22 Jan 2020 03:46 #155392
by J Crowder
Replied by J Crowder on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
OK, I am a complete non-linux noob. I downloaded the Mint 19.2 and put it on a DVD. It installed great. I then followed your instructions above and downloaded the Header and Image files for the 4.16.12-rt5-kona-rt_amd64.deb. I then installed the gdebi installer and used it to install both packages. I made sure that I have the grub customizer and I restart. The computer won't load and tells me tat I need to load the kernel first. I double checked and the 4.16 ...RT is the thing it is trying to load.
Note: once I load Mint and reboot it offers a UEFI modification page or something. I do not click or press a key to go into it, should I? I don't really care about which version of Linux I install, I just want to get the LinuxCNC loaded and working. Any help is appreciated.
- Topic Author
22 Jan 2020 17:13 #155435
Yeah UEFI and it's many, many f@k-ups!
Try disabling UEFI if possible or at least check the boot options as there should be one with UEFI and one without it for the drive (HDD or SSD). Most probably you will have to go through the install again, but in some cases it work without reinstalling it.
The following user(s) said Thank You: J Crowder
Time to create page: 0.198 seconds
