(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
24 Dec 2019 20:01 #153163 by jj80909
I got it to work with 4.14.28-rt23-kona-rt_amd64.
I also loaded grub customizer with the instructions from John Thornton's page.
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
and then deleted all options except 4.14.28-rt23-kona-rt and 4.14.28-rt23-kona-rt (recovery mode).
24 Dec 2019 20:11 #153164 by tommylight
Well if the PC has PS/2 connectors for the keyboard and mouse and you have a USB keyboard attached, then holding any key during boot time will not work, forgot to mention that.
Glad you got it working, i will add the Grub Customizer info to the original post in case someone else has the same issue.
Thank you for reporting back.
04 Jan 2020 22:22 #154035 by tjmarch
This also worked for Lubuntu 18.04
Thanks alot Tommylight
Tim
05 Jan 2020 00:07 #154051 by ytiuqibu
Given the successes reported here should consideration be given to pinning this thread at least in the short term?
05 Jan 2020 01:59 #154065 by tommylight
Done.
Thank you.
07 Jan 2020 21:33 #154258 by Mladen
Thank you for instructions, but I got this massage:
Cannot upgrade secure boot enforcement policy due to unsigned kernels.
Your system has UEFI secure boot enabled in firmware, and the following kernels present on your system are unsigned: 4.16.12.-rt-kona-rt.
How to solve it?
07 Jan 2020 21:45 #154260 by andypugh
You might be able to turn off secure boot in the BIOS.
Or it might be impossible to install any Linux on that motherboard.
22 Jan 2020 03:46 #155392 by J Crowder
OK, I am a complete non-linux noob. I downloaded the Mint 19.2 and put it on a DVD. It installed great. I then followed your instructions above and downloaded the Header and Image files for the 4.16.12-rt5-kona-rt_amd64.deb. I then installed the gdebi installer and used it to install both packages. I made sure that I have the grub customizer and I restart. The computer won't load and tells me tat I need to load the kernel first. I double checked and the 4.16 ...RT is the thing it is trying to load.
Note: once I load Mint and reboot it offers a UEFI modification page or something. I do not click or press a key to go into it, should I? I don't really care about which version of Linux I install, I just want to get the LinuxCNC loaded and working. Any help is appreciated.
22 Jan 2020 17:13 #155435 by tommylight
Yeah UEFI and it's many, many f@k-ups!
Try disabling UEFI if possible or at least check the boot options as there should be one with UEFI and one without it for the drive (HDD or SSD). Most probably you will have to go through the install again, but in some cases it work without reinstalling it.
The following user(s) said Thank You: J Crowder
