(superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
23 Jan 2020 01:56 #155484
by J Crowder
Replied by J Crowder on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Disabled UEFI and I am in!! Thanks so much. Now, on to more learning.
- BeagleBrainz
- User is blocked
- Thank you received: 570
04 Feb 2020 18:27 #156531
by BeagleBrainz
Replied by BeagleBrainz on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Just thinking aloud.......
Could a so called “meta package” be built so installing kernel and linuxcnc be installed by one package ?
- Topic Author
- Thank you received: 5924
04 Feb 2020 19:17 #156535
Replied by tommylight on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Might be, never considered that before, thank you.
07 Feb 2020 23:24 #156717
by freddie
Replied by freddie on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
I am trying this on Linux mint mate 19.1 and downloaded all the files as per your instructions but don't know how to load the rt kernel. boot menu shows it is there but when I select it I get error saying I need to load kernel first. I have to select the regular kernel to boot. Don't know what to do. New to this even though I have been using linuxcnc on my router for over a year. Thought in would be nice to enjoy mint out in my work shed when not running cnc. Help!
- BeagleBrainz
- User is blocked
08 Feb 2020 01:19 #156724
by BeagleBrainz
Ok will need a picture of the boot menu message you are getting, the way you are describing is a little confusing to me.
Will need you to post the contents of /boot/grub/grub.cfg
- Topic Author
08 Feb 2020 01:56 #156725
You need to install 2 files with "kona" in their name, installing just linux-headers-kona will result in the error you are getting. You must all install Linux-image-kona........
08 Feb 2020 02:37 #156729
by WhyMe1
Replied by WhyMe1 on topic (superseeded) Linuxcnc on Linux Mint 19.3 quick and easy installation
Download 4.16.12-rt5-kona-rt_amd64.deb used gdebi to install ,Reboot shift/ctrl grub2 menu ,Not showing it only see 5.3.8.28 generic .I also did the the three sudo line, reboot same thing NO 4.16.12rt5Kona rt amd64 again only shows Linux 5.3.8.28 generic.
What am I doing wrong ?? Not a happy camper right now with this .
08 Feb 2020 02:39 #156730
by freddie
I did that, both image and headers, 4.16.12rt5-kona-rt amd64.deb and then the rt kernel. Same message at boot, you need to load kernel first. I am going to recheck again but no luck yet. I am sure I got the right files.
- BeagleBrainz
- User is blocked
08 Feb 2020 02:50 #156733
by BeagleBrainz
Does grub have an "Advanced Options" menu ?
If you delve into that it may have your rt kernel come up.
If you want to wait an hour or son from this post I'll have my Linux Mint 19.2 iso with an RT kernel and Linuxcnc 2.9 installed already to do a fresh install with.
08 Feb 2020 02:58 #156734
by WhyMe1
Yes and Advanced options menu only show 5.3.8.28.
Would be nice to download a iso all set up with LinuxMint & CNC ?
It would stop a lot of people from using a lot of aspirin as one fig it out
Time to create page: 0.250 seconds
