Raspberry Pi 4 Tutorial - fatal error
- Thank you received: 5925
10 Jul 2020 19:07 #174252
Replied by tommylight on topic Raspberry Pi 4 Tutorial
sudo gdebi <name of the file>.deb
11 Jul 2020 20:24 #174325
by moonco
Replied by moonco on topic Raspberry Pi 4 Tutorial
I was able to get LinuxCNC running. I am not sure if there are any issues yet as the same error occurred.
I just ignored the error and continued this time.
This time i followed the tutorial but replaced the next lines in the tutorial with the files from the buildbot as follows.
I was able to open Linuxcnc after doing this.
dpkg-buildpackage -us -uc -ui failed
sudo dpkg -i linuxcnc-uspace_2.8.0_pre1.5983.g19a686b67_armhf.deb
sudo dpkg -i llinuxcnc-doc-en_2.8.0_pre1.5983.g19a686b67_all.deb
11 Jul 2020 22:53 #174337
by phillc54
Replied by phillc54 on topic Raspberry Pi 4 Tutorial
Glad you got it working.
It would be nice to know what errors you got when using apt to install the packages. apt does call dpkg so it should work and it does for me.
12 Jul 2020 00:57 #174346
by moonco
Here is what was reading out on terminal. Maybe these aren't errors? I am mostly new to linux. I use linux at work but very limited. We build 3d printers and I mostly need to copy, paste, move files from servers onto the computer etc.
Many files couldn't convert with latex. Also dbfatal error at 1182
Pixel unit not handled (replaced by pt)
Cannot convert 'common/images/emc2-intro.png' to pdf
Cannot convert 'user/images/whatstep1.png' to pdf
Cannot convert 'gui/images/axis.png' to pdf
Cannot convert 'gui/images/touchy.png' to pdf
Cannot convert 'gui/images/gscreen-mill.png' to pdf
Cannot convert 'gui/images/gmoccapy_3_axis.png' to pdf
Cannot convert 'gui/images/ngcgui.png' to pdf
Cannot convert 'gui/images/axis-pyvcp.png' to pdf
Cannot convert 'gui/images/axis-gladevcp.png' to pdf
Cannot convert 'user/images/naive-cam.png' to pdf
inkscape -z -D --export-pdf=fig0.pdf /home/pi/emc/docs/src/user/images/mill-diagram_en.svg
inkscape -z -D --export-pdf=fig1.pdf /home/pi/emc/docs/src/user/images/lathe-diagram_en.svg
Image 'images/configuration-selector.png' not found
Cannot convert 'getting-started/images/configuration-selector.png' to pdf
Cannot convert 'config/images/stepconf-start_en.png' to pdf
Cannot convert 'config/images/stepconf-base_en.png' to pdf
Cannot convert 'config/images/latency-test_en.png' to pdf
Cannot convert 'config/images/stepconf-parallel-1_en.png' to pdf
Cannot convert 'config/images/stepconf-parallel-2_en.png' to pdf
Cannot convert 'config/images/stepconf-axis-x_en.png' to pdf
Cannot convert 'config/images/stepconf-x-test_en.png' to pdf
Cannot convert 'config/images/stepconf-spindle_en.png' to pdf
Cannot convert 'config/images/stepconf-options_en.png' to pdf
inkscape -z -D --export-pdf=fig2.pdf /home/pi/emc/docs/src/config/images/switch-nc-series_en.svg
inkscape -z -D --export-pdf=fig3.pdf /home/pi/emc/docs/src/config/images/switch-no-parallel_en.svg
Cannot convert 'config/images/pncconf-splash.png' to pdf
Cannot convert 'config/images/pncconf-basic.png' to pdf
Cannot convert 'config/images/pncconf-external.png' to pdf
Cannot convert 'config/images/pncconf-gui.png' to pdf
Cannot convert 'config/images/pncconf-mesa-config.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io2.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io3.png' to pdf
Cannot convert 'config/images/pncconf-mesa-io4.png' to pdf
Cannot convert 'config/images/pncconf-parport.png' to pdf
Cannot convert 'config/images/pncconf-axis-drive.png' to pdf
Cannot convert 'config/images/pncconf-scale-calc.png' to pdf
Cannot convert 'config/images/pncconf-axis-config.png' to pdf
Cannot convert 'config/images/pncconf-diagram-lathe.png' to pdf
Cannot convert 'config/images/pncconf-spindle-config.png' to pdf
Cannot convert 'config/images/pncconf-advanced.png' to pdf
Cannot convert 'config/images/pncconf-hal.png' to pdf
inkscape -z -D --export-pdf=fig4.pdf /home/pi/emc/docs/src/lathe/images/tool-positions_en.svg
inkscape -z -D --export-pdf=fig5.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-1_en.svg
inkscape -z -D --export-pdf=fig6.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-2_en.svg
inkscape -z -D --export-pdf=fig7.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-3_en.svg
inkscape -z -D --export-pdf=fig8.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-4_en.svg
inkscape -z -D --export-pdf=fig9.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-5_en.svg
inkscape -z -D --export-pdf=fig10.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-6_en.svg
inkscape -z -D --export-pdf=fig11.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-7_en.svg
inkscape -z -D --export-pdf=fig12.pdf /home/pi/emc/docs/src/lathe/images/tool-pos-8_en.svg
inkscape -z -D --export-pdf=fig13.pdf /home/pi/emc/docs/src/lathe/images/control-point_en.svg
inkscape -z -D --export-pdf=fig14.pdf /home/pi/emc/docs/src/lathe/images/ramp-entry_en.svg
inkscape -z -D --export-pdf=fig15.pdf /home/pi/emc/docs/src/lathe/images/ramp-cut_en.svg
inkscape -z -D --export-pdf=fig16.pdf /home/pi/emc/docs/src/lathe/images/radius-1_en.svg
inkscape -z -D --export-pdf=fig17.pdf /home/pi/emc/docs/src/lathe/images/radius-2_en.svg
inkscape -z -D --export-pdf=fig18.pdf /home/pi/emc/docs/src/lathe/images/radius-3_en.svg
inkscape -z -D --export-pdf=fig19.pdf /home/pi/emc/docs/src/lathe/images/radius-4_en.svg
Cannot convert 'plasma/images/primer_torch-head.png' to pdf
Cannot convert 'plasma/images/primer_cut-angularity.png' to pdf
Cannot convert 'plasma/images/primer_volts-height.png' to pdf
Cannot convert 'plasma/images/primer_ohmic-sensing.png' to pdf
Cannot convert 'plasma/images/primer_hypersensing.png' to pdf
Cannot convert 'plasma/images/primer_thc-delay.png' to pdf
Cannot convert 'plasma/images/primer_kerf-cross.png' to pdf
convert /home/pi/emc/docs/src/gui/images/tool_estop.gif fig20.pdf
convert-im6.q16: attempt to perform an operation not allowed by the security policy `PDF' @ error/constitute.c/IsCoderAuthorized/408.
Unexpected error occured
convert /home/pi/emc/docs/src/gui/images/tool_power.gif fig21.pdf
convert /home/pi/emc/docs/src/gui/images/tool_open.gif fig22.pdf
convert /home/pi/emc/docs/src/gui/images/tool_reload.gif fig23.pdf
convert /home/pi/emc/docs/src/gui/images/tool_run.gif fig24.pdf
convert /home/pi/emc/docs/src/gui/images/tool_step.gif fig25.pdf
convert /home/pi/emc/docs/src/gui/images/tool_pause.gif fig26.pdf
convert /home/pi/emc/docs/src/gui/images/tool_stop.gif fig27.pdf
convert /home/pi/emc/docs/src/gui/images/tool_blockdelete.gif fig28.pdf
convert /home/pi/emc/docs/src/gui/images/tool_optpause.gif fig29.pdf
convert /home/pi/emc/docs/src/gui/images/tool_zoomin.gif fig30.pdf
convert /home/pi/emc/docs/src/gui/images/tool_zoomout.gif fig31.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_z.gif fig32.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_z2.gif fig33.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_x.gif fig34.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_y.gif fig35.pdf
convert /home/pi/emc/docs/src/gui/images/tool_axis_p.gif fig36.pdf
convert /home/pi/emc/docs/src/gui/images/tool_rotate.gif fig37.pdf
convert /home/pi/emc/docs/src/gui/images/tool_clear.gif fig38.pdf
Cannot convert 'gui/images/axis-homed.png' to pdf
Cannot convert 'gui/images/axis-limit.png' to pdf
Cannot convert 'gui/images/axis-machineorigin.png' to pdf
Cannot convert 'gui/images/axis-outofrange.png' to pdf
Cannot convert 'gui/images/axis-currentandselected.png' to pdf
Cannot convert 'gui/images/touchoff.png' to pdf
Cannot convert 'gui/images/axis-mdi.png' to pdf
Cannot convert 'gui/images/axis-emc-status.png' to pdf
Cannot convert 'gui/images/manual-tool-change.png' to pdf
Cannot convert 'gui/images/axis-lathe-tool.png' to pdf
Cannot convert 'gui/images/axis-foam.png' to pdf
Cannot convert 'gui/images/holes.png' to pdf
Cannot convert 'gui/images/gmoccapy_5_axis.png' to pdf
Cannot convert 'gui/images/gmoccapy_ntb_preview_maximized_2.png' to pdf
Cannot convert 'gui/images/gmoccapy_ntb_preview.png' to pdf
Cannot convert 'gui/images/gmoccapy_with_left_box_in_edit_mode.png' to pdf
Cannot convert 'gui/images/gmoccapy_with_right_panel_in_MDI_mode.png' to pdf
Cannot convert 'gui/images/gmoccapy_mdi_hidden_keyboard.png' to pdf
Cannot convert 'gui/images/gmoccapy_getting_macro_info.png' to pdf
Cannot convert 'gui/images/gmoccapy_0_9_7_sim_hardware_button.png' to pdf
Cannot convert 'gui/images/manual_toolchange.png' to pdf
Cannot convert 'gui/images/gmoccapy_0_9_7_tool_info.png' to pdf
Cannot convert 'gui/images/sketch_auto_tool_measurement.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_button.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_appearance.png' to pdf
Cannot convert 'gui/images/gmoccapy_file_selection_dialog_with_keyboard.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_hardware.png' to pdf
Cannot convert 'gui/images/gmoccapy_settings_advanced.png' to pdf
Cannot convert 'gui/images/gmoccapy_lathe.png' to pdf
Cannot convert 'gui/images/gmoccapy_back_tool_lathe.png' to pdf
Cannot convert 'gui/images/gmoccapy_plasma.png' to pdf
Cannot convert 'gui/images/strange_numbers.png' to pdf
Image 'gui/images/tool_estop.gif' already converted as fig20.pdf
Image 'gui/images/tool_power.gif' already converted as fig21.pdf
Image 'gui/images/tool_run.gif' already converted as fig24.pdf
Cannot convert 'gui/images/ngcgui-db25-1.png' to pdf
Cannot convert 'gui/images/ngcgui-db25-2.png' to pdf
Cannot convert 'gui/images/ngcgui-db25-3.png' to pdf
Cannot convert 'gui/images/silverdragon.png' to pdf
Cannot convert 'gui/images/spartan.png' to pdf
Cannot convert 'gui/images/gaxis.png' to pdf
Cannot convert 'gui/images/industrial.png' to pdf
Cannot convert 'gui/images/tester.png' to pdf
Cannot convert 'gui/images/tester_editor.png' to pdf
Cannot convert 'gui/images/tkemc.png' to pdf
Cannot convert 'gui/images/tkemc-interp.png' to pdf
Cannot convert 'gui/images/tkemc-override-limits.png' to pdf
Cannot convert 'gui/images/tkemc-mdi.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_home_new.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_new.png' to pdf
Cannot convert 'plasma/images/plasmac_config.png' to pdf
Cannot convert 'plasma/images/plasmac_run.png' to pdf
Cannot convert 'plasma/images/plasmac_monitor.png' to pdf
Cannot convert 'plasma/images/plasmac_buttons_a.png' to pdf
Cannot convert 'plasma/images/plasmac_buttons_g.png' to pdf
Cannot convert 'plasma/images/plasmac_control_a.png' to pdf
Cannot convert 'plasma/images/plasmac_control_g.png' to pdf
Cannot convert 'plasma/images/plasmac_stats.png' to pdf
Cannot convert 'plasma/images/plasmac_extras.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_home_used.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_upgrade.png' to pdf
Cannot convert 'plasma/images/plasmac_configurator_reconfigure.png' to pdf
Cannot convert 'plasma/images/plasmac_material_main.png' to pdf
Cannot convert 'plasma/images/plasmac_material_dialogs.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_pmx.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_sunnix.png' to pdf
Cannot convert 'plasma/images/plasmac_rs485_dtech.png' to pdf
Cannot convert 'plasma/images/plasmac_reed_arc_ok.png' to pdf
Cannot convert 'gcode/images/offsets.png' to pdf
Cannot convert 'gcode/images/polar01.png' to pdf
Cannot convert 'gcode/images/polar02.png' to pdf
inkscape -z -D --export-pdf=fig39.pdf /home/pi/emc/docs/src/gcode/images/g2_en.svg
inkscape -z -D --export-pdf=fig40.pdf /home/pi/emc/docs/src/gcode/images/g2-3_en.svg
Cannot convert 'gcode/images/nurbs01.png' to pdf
inkscape -z -D --export-pdf=fig41.pdf /home/pi/emc/docs/src/gcode/images/g76-threads_en.svg
Cannot convert 'gcode/images/g76-01.png' to pdf
inkscape -z -D --export-pdf=fig42.pdf /home/pi/emc/docs/src/gcode/images/eight-holes_en.svg
inkscape -z -D --export-pdf=fig43.pdf /home/pi/emc/docs/src/gcode/images/twelve-holes_en.svg
inkscape -z -D --export-pdf=fig44.pdf /home/pi/emc/docs/src/gcode/images/g81mult_en.svg
inkscape -z -D --export-pdf=fig45.pdf /home/pi/emc/docs/src/gcode/images/g81ex1_en.svg
inkscape -z -D --export-pdf=fig46.pdf /home/pi/emc/docs/src/gcode/images/g81ex2_en.svg
inkscape -z -D --export-pdf=fig47.pdf /home/pi/emc/docs/src/gcode/images/g81_en.svg
inkscape -z -D --export-pdf=fig48.pdf /home/pi/emc/docs/src/gcode/images/g81a_en.svg
Cannot convert 'gui/images/image-to-gcode.png' to pdf
Cannot convert 'gui/images/i2g-roughing.png' to pdf
Cannot convert 'gcode/images/ToolTable-TouchOff.png' to pdf
inkscape -z -D --export-pdf=fig49.pdf /home/pi/emc/docs/src/gcode/images/comp-path_en.svg
inkscape -z -D --export-pdf=fig50.pdf /home/pi/emc/docs/src/gcode/images/comp02_en.svg
Cannot convert 'gcode/images/outside-comp.png' to pdf
Cannot convert 'gcode/images/inside-comp.png' to pdf
Cannot convert 'gui/images/tooledit.png' to pdf
Cannot convert 'gui/images/tooledit-sort.png' to pdf
Cannot convert 'gui/images/tooledit-columns.png' to pdf
Cannot convert 'config/images/servo-feedback.png' to pdf
Cannot convert 'config/images/pid-feedback.png' to pdf
Cannot convert 'config/images/latency-plot.png' to pdf
Cannot convert 'config/images/latency-histogram.png' to pdf
Cannot convert 'config/images/step-calc-inch-math.png' to pdf
Cannot convert 'config/images/step-calc-mm-math.png' to pdf
Cannot convert 'config/images/encoder-counts-math.png' to pdf
Cannot convert 'config/images/p-term.png' to pdf
Cannot convert 'config/images/i-term.png' to pdf
Cannot convert 'config/images/ff2.png' to pdf
Cannot convert 'config/images/output-offset.png' to pdf
Cannot convert 'config/images/scale-math.png' to pdf
Cannot convert 'config/images/calibration-1.png' to pdf
Cannot convert 'config/images/calibration-2.png' to pdf
Cannot convert 'config/images/calibration-3.png' to pdf
Cannot convert 'config/images/encoder-scale.png' to pdf
Cannot convert 'config/images/stepper-scale.png' to pdf
Cannot convert 'config/images/HomeAxisTravel_V2.png' to pdf
Cannot convert 'config/images/HomeAxisTravel_V3.png' to pdf
Cannot convert 'config/images/emc2-motion-homing-diag.png' to pdf
Cannot convert 'remap/images/debug_embedded_python.png' to pdf
Cannot convert 'gui/images/pyvcp_group.png' to pdf
Cannot convert 'gui/images/pyvcp_mypanel.png' to pdf
Cannot convert 'gui/images/pyvcp_axis_lathe.png' to pdf
Cannot convert 'gui/images/pyvcp_label.png' to pdf
Cannot convert 'gui/images/pyvcp_led.png' to pdf
Cannot convert 'gui/images/pyvcp_rectled.png' to pdf
Cannot convert 'gui/images/pyvcp_button.png' to pdf
Cannot convert 'gui/images/pyvcp_checkbutton.png' to pdf
Cannot convert 'gui/images/pyvcp_radiobutton.png' to pdf
Cannot convert 'gui/images/pyvcp_number.png' to pdf
Cannot convert 'gui/images/pyvcp_s32.png' to pdf
Cannot convert 'gui/images/pyvcp_bar.png' to pdf
Cannot convert 'gui/images/pyvcp_meter.png' to pdf
Cannot convert 'gui/images/pyvcp_spinbox.png' to pdf
Cannot convert 'gui/images/pyvcp_scale.png' to pdf
Cannot convert 'gui/images/pyvcp_dial.png' to pdf
Cannot convert 'gui/images/pyvcp_jogwheel.png' to pdf
Cannot convert 'gui/images/pyvcp_image01.png' to pdf
Cannot convert 'gui/images/pyvcp_image02.png' to pdf
Cannot convert 'gui/images/pyvcp_image_u32_01.png' to pdf
Cannot convert 'gui/images/pyvcp_borders.png' to pdf
Cannot convert 'gui/images/pyvcp_hbox.png' to pdf
Cannot convert 'gui/images/pyvcp_vbox.png' to pdf
Cannot convert 'gui/images/pyvcp_labelframe.png' to pdf
Cannot convert 'gui/images/pyvcp_table.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs1.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs2.png' to pdf
Cannot convert 'gui/images/pyvcp_tabs3.png' to pdf
Cannot convert 'gui/images/xyz_ACO.png' to pdf
Cannot convert 'gui/images/xyz_buttons.png' to pdf
Cannot convert 'gui/images/ptest.png' to pdf
Cannot convert 'gui/images/ptest-final.png' to pdf
Cannot convert 'gui/images/gs2_panel.png' to pdf
Cannot convert 'gui/images/pyvcp-rth.png' to pdf
Cannot convert 'gui/images/example-panel-small.png' to pdf
Cannot convert 'gui/images/example-tabbed-small.png' to pdf
Cannot convert 'gui/images/touchy-tab-33.png' to pdf
Cannot convert 'gui/images/glade-manual-small.png' to pdf
Cannot convert 'gui/images/hal-pin-change-66.png' to pdf
Cannot convert 'gui/images/checkbutton.png' to pdf
Cannot convert 'gui/images/radiobutton.png' to pdf
Cannot convert 'gui/images/button.png' to pdf
Cannot convert 'gui/images/hscale.png' to pdf
Cannot convert 'gui/images/spinbutton.png' to pdf
Cannot convert 'gui/images/Hal_Dial.png' to pdf
Cannot convert 'gui/images/JogWheel.png' to pdf
Cannot convert 'gui/images/SpeedControl.png' to pdf
Cannot convert 'gui/images/leds.png' to pdf
Cannot convert 'gui/images/progressbar2.png' to pdf
Cannot convert 'gui/images/hal_hbar.png' to pdf
Cannot convert 'gui/images/vscale.png' to pdf
Cannot convert 'gui/images/hal_meter.png' to pdf
Cannot convert 'gui/images/gremlin.png' to pdf
Cannot convert 'gui/images/combi_dro.png' to pdf
Cannot convert 'gui/images/iconview.png' to pdf
Cannot convert 'gui/images/gtk-tooledit.png' to pdf
Cannot convert 'gui/images/offsetpage.png' to pdf
Cannot convert 'gui/images/hal_sourceview.png' to pdf
Cannot convert 'gui/images/small-screenshot.png' to pdf
Cannot convert 'gui/images/vcp-actions.png' to pdf
Cannot convert 'gui/images/whoareyou.png' to pdf
Cannot convert 'gui/images/speed.png' to pdf
Cannot convert 'gui/images/oword.png' to pdf
Cannot convert 'hal/images/remote-start.png' to pdf
Cannot convert 'gui/images/vismach.png' to pdf
Cannot convert 'drivers/images/5i20-halpins.png' to pdf
Cannot convert 'drivers/images/pico-ppmc-math.png' to pdf
Cannot convert 'drivers/images/pluto-pinout.png' to pdf
Cannot convert 'drivers/images/pluto-step-pinout.png' to pdf
Cannot convert 'drivers/images/pluto_step_waveform.png' to pdf
Cannot convert 'drivers/images/GMsystem.png' to pdf
Cannot convert 'drivers/images/GM_PCIpinout.png' to pdf
Cannot convert 'drivers/images/GM_IOpinout.png' to pdf
Cannot convert 'drivers/images/GM_AXISpinout.png' to pdf
Cannot convert 'drivers/images/GM_AxisInterface.png' to pdf
Cannot convert 'drivers/images/GM_RefSignals.png' to pdf
Cannot convert 'drivers/images/GM_ENDSWpinout.png' to pdf
Cannot convert 'drivers/images/GM_RS485topology.png' to pdf
Cannot convert 'examples/images/spindle-math.png' to pdf
Cannot convert 'ladder/images/ladder_action_load.png' to pdf
Cannot convert 'ladder/images/ladder_action_loadbar.png' to pdf
Cannot convert 'ladder/images/ladder_action_out.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil2.png' to pdf
Cannot convert 'ladder/images/example_link_contact_coil3.png' to pdf
Cannot convert 'ladder/images/Default_Sections_Manager.png' to pdf
Cannot convert 'ladder/images/Default_Section_Display.png' to pdf
Cannot convert 'ladder/images/Bit_Status.png' to pdf
Cannot convert 'ladder/images/watch_window.png' to pdf
Cannot convert 'ladder/images/Default_Symbols_names.png' to pdf
Cannot convert 'ladder/images/Editor.png' to pdf
Cannot convert 'ladder/images/Config.png' to pdf
Cannot convert 'ladder/images/AssignCompare-Ladder.png' to pdf
Cannot convert 'ladder/images/Assignment_Expression.png' to pdf
Cannot convert 'ladder/images/Comparison_Expression.png' to pdf
Cannot convert 'ladder/images/Config-io.png' to pdf
Cannot convert 'ladder/images/Config-com.png' to pdf
Cannot convert 'ladder/images/modbus_register_setting.png' to pdf
Cannot convert 'ladder/images/modbus_com_setting.png' to pdf
Cannot convert 'ladder/images/stepconf_ladder.png' to pdf
Cannot convert 'ladder/images/Section_Display_Grid.png' to pdf
Cannot convert 'ladder/images/Editor_NO_Input.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build01.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build02.png' to pdf
Cannot convert 'ladder/images/Section_Display_Build03.png' to pdf
Cannot convert 'ladder/images/SaveAs.png' to pdf
Cannot convert 'ladder/images/wrapping-counter.png' to pdf
Cannot convert 'ladder/images/extra-pulse-reject.png' to pdf
Cannot convert 'ladder/images/EStop_Section_Display.png' to pdf
Cannot convert 'ladder/images/axis_cl-estop.png' to pdf
Cannot convert 'ladder/images/Tmr_Section_Display.png' to pdf
Cannot convert 'hal/images/hal_circuit_concept.png' to pdf
Cannot convert 'hal/images/HAL_Configuration.png' to pdf
Cannot convert 'hal/images/signal-direction.png' to pdf
Cannot convert 'hal/images/halmeter-select.png' to pdf
Cannot convert 'hal/images/halmeter-1.png' to pdf
Cannot convert 'hal/images/halscope-01.png' to pdf
Cannot convert 'hal/images/halscope-02.png' to pdf
Cannot convert 'hal/images/halscope-03.png' to pdf
Cannot convert 'hal/images/halscope-04.png' to pdf
Cannot convert 'hal/images/halscope-05.png' to pdf
Cannot convert 'hal/images/halscope-06.png' to pdf
Cannot convert 'hal/images/halscope-07.png' to pdf
Cannot convert 'hal/images/halscope-08.png' to pdf
Cannot convert 'hal/images/halscope-09.png' to pdf
Cannot convert 'hal/images/halscope-10.png' to pdf
Cannot convert 'hal/images/halscope-11.png' to pdf
Cannot convert 'hal/images/hal-meter01.png' to pdf
Cannot convert 'hal/images/hal-meter02.png' to pdf
Cannot convert 'hal/images/sim_pin.png' to pdf
Cannot convert 'hal/images/simulate_probe.png' to pdf
Cannot convert 'hal/images/hal-histogram.png' to pdf
Cannot convert 'hal/images/halshow-1.png' to pdf
Cannot convert 'hal/images/halshow-3.png' to pdf
Cannot convert 'hal/images/halshow-2.png' to pdf
Cannot convert 'hal/images/halshow-4.png' to pdf
Cannot convert 'hal/images/stepgen-block-diag.png' to pdf
Cannot convert 'hal/images/stepgen-type0.png' to pdf
Cannot convert 'hal/images/stepgen-type2-4.png' to pdf
Cannot convert 'hal/images/stepgen-type5-10.png' to pdf
Cannot convert 'hal/images/stepgen-type11-14.png' to pdf
Cannot convert 'hal/images/encoder-block-diag.png' to pdf
Cannot convert 'hal/images/pid-block-diag.png' to pdf
Cannot convert 'hal/images/velocity-01.png' to pdf
Cannot convert 'hal/images/softstart-scope.png' to pdf
Cannot convert 'motion/images/bipod.png' to pdf
Cannot convert 'motion/images/kinematics-math-01.png' to pdf
Cannot convert 'motion/images/kinematics-math-02.png' to pdf
Cannot convert 'motion/images/kinematics-math-03.png' to pdf
Cannot convert 'motion/images/kinematics-math-04.png' to pdf
Cannot convert 'motion/images/kinematics-math-05.png' to pdf
Cannot convert 'motion/images/kinematics-math-06.png' to pdf
Cannot convert 'motion/images/kinematics-math-07.png' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-001.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-002.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-003.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-004.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-005.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-006.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-007.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-008.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-009.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-010.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-011.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-012.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-013.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-014.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-015.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-016.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-017.jpg' to pdf
Cannot convert 'motion/rv-6sl/rv-6sl-018.jpg' to pdf
Cannot convert 'motion/5-axis-figures/equation__1.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-1.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__2.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__3.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-2.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__4.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__5.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-3.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-4.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__6.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__7.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__8.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__9.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__10.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__11.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__12.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__13.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__14.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__15.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__16.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__17.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-5.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-6.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__18.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__19.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__20.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__21.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__22.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__23.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__24.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__25.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__26.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__27.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-7.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-8.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__28.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__29.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__30.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__31.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__32.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__33.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__34.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__35.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__36.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__37.png' to pdf
Cannot convert 'motion/5-axis-figures/equation__38.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-9.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-10.png' to pdf
Cannot convert 'motion/5-axis-figures/Figure-11.png' to pdf
Build Master_Documentation.pdf
built-in module pdftex registered
no support found for ifthen
no support found for ifxetex
no support found for fontspec
no support found for xltxtra
no support found for fontenc
no support found for inputenc
no support found for fancybox
built-in module makeidx registered
no support found for emc2
building additional files...
checking if compiling is necessary...
the output file doesn't exist
pdflatex -interaction=batchmode Master_Documentation.tex
pdflatex failed
A possible reason for transformation failure is invalid DocBook
(as reported by xmllint)
Erroa2x: ERROR: "dblatex" -t pdf -p "/etc/asciidoc/dblatex/asciidoc-dblatex.xsl" -s "/etc/asciidoc/dblatex/asciidoc-dblatex.sty" -P doc.publisher.show=0 -P latex.output.revhistory=0 -s ../docs/src/emc2.sty -P latex.hyperparam=colorlinks,linkcolor=blue,filecolor=blue,urlcolor=blue,citecolor=blue -V "/home/pi/emc/docs/src/Master_Documentation.xml" returned non-zero exit status 1
r: pdflatex compilation failed
make[1]: *** [../docs/src/Submakefile:443: ../docs/src/Master_Documentation.pdf] Error 1
make[1]: Leaving directory '/home/pi/emc/src'
make: *** [debian/rules:34: build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
debuild: fatal error at line 1182:
12 Jul 2020 01:10 #174347
by phillc54
That looks more like an error that you would get while building a package rather than one from installing a package.
08 Aug 2020 16:04 #177688
by kramerda
Replied by kramerda on topic Raspberry Pi 4 Tutorial
When installing the RT kernel - setting up options - from JTs tutorial
There is a command for
KERNEL=kernel7l.
From the font used in the tutorial (and same reading the Raspberry kernel instructions for the Rpi4) I can't tell if 'kernel seven one or kernel seven 'ell'
Both documents use a type with serifs for the one and the letter 'l'.
KERNEL=kernel7l.
08 Aug 2020 22:49 #177722
by phillc54
lowercase L
09 Aug 2020 15:59 #177760
by kramerda
OK I hope someone can help a novice here. - with my Linuxcnc install per JT.
1. I have the same question at BlueChicago on May 12. I'm at the point where I'm ready to run debian/configure uspace. Using nano debian/configure, I searched and found the two lines to delete (with the python-vte | girl.2-vte-2.91 difference). I removed them, did an exit with save.....
2. the next step debian/configure uspace
leaves me hanging with the following
PACKAGE: command not found
with a few more 'not found' following.
Not smart enough to know if these issues are related. ?????
11 Aug 2020 23:06 #177956
by kramerda
12 Aug 2020 10:49 #178018
by rvh
Replied by rvh on topic Raspberry Pi 4 Tutorial
You main the part arround nano debian/configure ?
In my opinion nothing needs to be changed here. (unless I'm wrong)
I just skipped it and continued to the next step (Edit debian/control.bottom.in...)
I didn't got any problems with it and have a running linuxcnc now.
