LinuxCNC on Debian 10 Buster quick and easy install
- strahlensauger
- Thank you received: 64
with a
sudo apt-get install grub-customizer
sudo grub-customizer
a graphical tool can be installed to move the extended Options
with the RT Kernel to the top at the bootstart
- Topic Author
- Thank you received: 5874
No need for that, Debian 10 uses the same kernel as default without RT, so when you install RT it becomes the default.That was something I was looking for.
with a
If it was needed, i would have posted it. I did remove the pressing ctrl+shift after double checking, in the original post.
- Topic Author
The issues is as follows: It can see Wi-Fi access points but it will not connect to them.
Synopsis: naming issue, namely issuing very long names for Wi-Fi devices to such an extent of making them useless.
Solution on the first post of this thread.
Tested and working with 3 different types of USB Wi-Fi dongles.
This is the easiest way to get Linuxcnc working on Debian Buster:
--Download the non-free version of Debian as the free version has no proprietary drivers included and may result in non functioning hardware, from here
cdimage.debian.org/images/unofficial/non...-live+nonfree/amd64/
From the long list ISO section, which of the non-free should I be using for Mesa stuff and or PPort
- Topic Author
Direct link cdimage.debian.org/images/unofficial/non...d64-mate+nonfree.iso
Torrent link cdimage.debian.org/images/unofficial/non...+nonfree.iso.torrent
- BeagleBrainz
- User is blocked
- Thank you received: 570
- Topic Author
Haven't used that in quite some time, so i might give it a go.The LXQT desktop looks promising.
Thanks.
# Return to your home folder
cd
# Download python-gtksourceview2 since it doesn't exist in Debian Buster
wget http://http.us.debian.org/debian/pool/main/p/pygtksourceview/python-gtksourceview2_2.10.1-3_amd64.deb
# Load GPG keys for LinuxCNC
sudo apt-key adv --keyserver ha.pool.sks-keyservers.net --recv-keys EF1B07FEE0EE663E
# Create APT source entry
echo "deb http://buildbot.linuxcnc.org/ buster 2.8-rtpreempt" | sudo tee /etc/apt/sources.list.d/linuxcnc.list
echo "deb-src http://buildbot.linuxcnc.org/ buster 2.8-rtpreempt" | sudo tee -a /etc/apt/sources.list.d/linuxcnc.list
# Update APT
sudo apt update
# Install gdebi and Linux RT
sudo apt install gdebi linux-headers-4.19.0-8-common-rt linux-headers-4.19.0-8-rt linux-image-4.19.0-8-rt-amd64
# Install python-gtksourceview2 from our downloaded deb file
sudo gdebi python-gtksourceview2_2.10.1-3_amd64.deb
# Install LinuxCNC
sudo apt install linuxcnc-uspace linuxcnc-uspace-dbgsym linuxcnc-uspace-dev linuxcnc-doc-en
# Reboot system
sudo reboot
- Topic Author
That will also work, thank you.
tommylight keep the great work..
Thanks...
