A6 Ethercat - digital IO mapping?
- spumco
- Thank you received: 864
24 May 2026 18:15 #346584
by spumco
A6 Ethercat - digital IO mapping? was created by spumco
Just dipping my toe in the ethercat waters and trying to set up a single drive on the bench.
I've got LCNC talking to the drive, and can start LCNC with a basic 1-axis config. Very exciting to see the position change when I twist the motor shaft. Much thanks to the forum!
Next move is to enable/configure the drive's IO, but none of the various xml file examples I could find in the forum appear to have mapped DI1-DI5 & DO1-DO3 to HAL pins.
I'd like to use all the DI/DO as general purpose IO (other than DO3 for a brake). Does anyone have an xml file with all the IO defined and mapped?
And whatever else I need, maybe a HAL file with IO pin names?
Thanks for any examples or suggestions.
Time to create page: 0.095 seconds
