C code in <any>_kins.c for an XYZABC machine
31 May 2013 21:14 - 31 May 2013 21:25 #35020
by niftyEnt
C code in <any>_kins.c for an XYZABC machine was created by niftyEnt
Let's talk about the machine language "C"...
prologue:
When attempting to write a kins module for a 6-axis gantry style machine, I am unable to recreate the results my spreadsheet returns for X-axis compensation when rotating about axis C.
please note-- I am NOT a C programmer
discussion:
Discrepancies in syntax exist between the various examples of <your>kins.c available from various sources, to wit:
Example 1 (from www.linuxcnc.org/docs/html/motion/kinematics.htm) --
1 int kinematicsForward(const double *joint, EmcPose *world,
2 const KINEMATICS_FORWARD_FLAGS *fflags,
3 KINEMATICS_INVERSE_FLAGS *iflags)
and
4 int kinematicsInverse(const EmcPose * world, double *joints,
5 const KINEMATICS_INVERSE_FLAGS *iflags,
6 KINEMATICS_FORWARD_FLAGS *fflags)
please notice that in lines 1 thru 3 of example 1, "*joint" , "*world", "*fflags", and "*iflags" all indicate pointers whereas in lines 4 thru 6 of example 1 "*joints" is a pointer to a different label and "* world" indicates multiplication.
Example 2 (from wiki.linuxcnc.org/uploads/5axiskins.c)--
1 int kinematicsForward(const double *joints,
2 EmcPose * pos,
3 const KINEMATICS_FORWARD_FLAGS * fflags,
4 KINEMATICS_INVERSE_FLAGS * iflags)
and
5 int kinematicsInverse(const EmcPose * pos,
6 double *joints,
7 const KINEMATICS_INVERSE_FLAGS * iflags,
8 KINEMATICS_FORWARD_FLAGS * fflags)
In Example 2, "*joints" indicates a pointer while "* pos", "* fflags" and "* fflags" all indicate multiplication. Further, "* joints" is used in both methods.
specifics:
In writing the kinematics for an existing machine detailed in the attached .png files, the problem is that when I home all joints in joint mode (using the Axis UI), the machine coordinates reflect the correct offset of
X: 7.0625
Y: 0.0000
Z: 25.0000
A: 0.0000
B: 0.0000
C: 0.0000
but when I enter the following G-code into the MDI:
g0 c30
the manual display in joint mode shows
X: 0.9462
Y: -3.5312
Z: 0.0000
A: 0.0000
B: 0.0000
C: 30.0000
This result indicates (to me) that the head of my machine will be translated along the X axis FURTHER from 0. The trig in my equation ie:
adj.x = ((C_len * cos(C_rad)) * cos(B_rad)) ...
where rotating the C axis SHOULD yield a result for X CLOSER to 0 (as the identical equation entered into a spreadsheet does).
I have attempted various modifications of this statement including:
adj.x = C_len - ((C_len * cos(C_rad)) * cos(B_rad))) ...,
double C_reverse = deg2rad(C_deg + 180);
adj.x = C_len + ((C_len * cos(C_reverse)) * cos(B_rad))) ...,
etc...
but ALL equations result in a translation amount FURTHER away from 0X. This result is unexpected and incorrect.
Also, rotations of the A and B axes result in expected translations of X, Y, and Z (identical to the results achieved in my spreadsheet).
Comments:
This machine is complete and ready to start cutting. The only thing stopping me is this error in the translation results, and I have been attempting to achieve the correct results for about two weeks, to no avail. I certainly hope you guys can help solve this.
Regards,
niftyEnt
the relevant section of my .hal code is:
setp XYZABCkins.A_length 21
setp XYZABCkins.B_length 4
setp XYZABCkins.C_length 7.0625
the relevant sections of my XYZABCkins.c code based on a work under
* Copyright (c) 2007 Chris Radek are:
#define deg2rad(d) ((d)*PM_PI/180.0)
#define rad2deg(r) ((r)*180.0/PM_PI)
struct haldata_2 {
hal_float_t *A_length;
hal_float_t *B_length;
hal_float_t *C_length;
} *haldata_2;
static PmCartesian fwd_adj(double A_len, double B_len, double C_len, double A_deg, double B_deg, double C_deg) {
PmCartesian adj;
double A_rad = deg2rad(A_deg);
double B_rad = deg2rad(B_deg);
double C_rad = deg2rad(C_deg);
adj.x = ((C_len * cos(C_rad)) * cos(B_rad)) + ((A_len * cos(A_rad) * sin(B_rad)) + (B_len * sin(B_rad)));
adj.y = (A_len * sin(A_rad)) + (C_len * sin(C_rad));
adj.z = (A_len * cos(A_rad) * cos(B_rad)) + (B_len * cos(B_rad)) + (C_len * cos(C_rad) * sin(B_rad));
return adj;
EmcPose * pos,
PmCartesian adj_fwd = fwd_adj(*(haldata_2->A_length), *(haldata_2->B_length), *(haldata_2->C_length), joints[3], joints[4], joints[5]);
pos->tran.x = joints[0] + adj_fwd.x;
pos->tran.y = joints[1] + adj_fwd.y;
pos->tran.z = joints[2] + adj_fwd.z;
pos->a = joints[3];
pos->b = joints[4];
pos->c = joints[5];
pos->u = joints[6];
pos->v = joints[7];
pos->w = joints[8];
return 0;
double *joints,
PmCartesian adj_inv = fwd_adj(*(haldata_2->A_length), *(haldata_2->B_length), *(haldata_2->C_length), joints[3], joints[4], joints[5]);
joints[0] = pos->tran.x - adj_inv.x;
joints[1] = pos->tran.y - adj_inv.y;
joints[2] = pos->tran.z - adj_inv.z;
joints[3] = pos->a;
joints[4] = pos->b;
joints[5] = pos->c;
joints[6] = pos->u;
joints[7] = pos->v;
joints[8] = pos->w;
return 0;
prologue:
discussion:
and
2 EmcPose * pos,
and
6 double *joints,
specifics:
X: 7.0625
Y: 0.0000
Z: 25.0000
A: 0.0000
B: 0.0000
C: 0.0000
g0 c30
X: 0.9462
Y: -3.5312
Z: 0.0000
A: 0.0000
B: 0.0000
C: 30.0000
etc...
Comments:
Regards,
niftyEnt
struct haldata_2 {
} *haldata_2;
PmCartesian adj;
return adj;
EmcPose * pos,
pos->a = joints[3];
pos->b = joints[4];
pos->c = joints[5];
pos->u = joints[6];
pos->v = joints[7];
pos->w = joints[8];
return 0;
double *joints,
joints[3] = pos->a;
joints[4] = pos->b;
joints[5] = pos->c;
joints[6] = pos->u;
joints[7] = pos->v;
joints[8] = pos->w;
return 0;
Last edit: 31 May 2013 21:25 by niftyEnt. Reason: correction to 1 line of code
01 Jun 2013 01:53 #35049
by niftyEnt
Replied by niftyEnt on topic C code in <any>_kins.c for an XYZABC machine
by the way...
I'm running version 2.5.1 on Ubuntu 10.04 straight from the distro disc.
01 Jun 2013 10:18 #35076
No. * only means multiplication if it is between things that C expects to multiply. As I understand it spaces are ignored in C syntax.
So, *a and * a are the same.
Whether the * is multiplication or dereference is context sensitive. Don't ask me to defend C.
Replied by andypugh on topic C code in <any>_kins.c for an XYZABC machine
01 Jun 2013 10:53 #35080
by niftyEnt
Cool.
So the methods as written are not the problem. That just leaves the trig.
Any suggestions?
Any suggestions?
01 Jun 2013 22:20 #35098
I don't understand why you think that X=0.9642 is further from the origin than X=7.0625
Any suggestions?
02 Jun 2013 12:59 #35139
by niftyEnt
My apologies.
I should have written:
0: 0.9462
1: -3.5312
2: 0.0000
3: 0.0000
4: 0.0000
5: 30.0000
as the joints instead of axes.
However, all is moot. I reinstalled linuxCNC and everything is now working as expected.
Thanks for the clarification about C. Understanding always precludes the need for defense.
And thanks for your timely response.
niftyEnt
0: 0.9462
1: -3.5312
2: 0.0000
3: 0.0000
4: 0.0000
5: 30.0000
niftyEnt
Time to create page: 0.156 seconds
