trying to find my parallel port
17 May 2011 11:14 #9861
by alexr
trying to find my parallel port was created by alexr
hey guys
can any one tell me how to find my parallel port in terminal?
I have uses lspci -v for this print out
$ lspci -v
00:00.0 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
Subsystem: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
Flags: bus master, medium devsel, latency 8
Memory at d0000000 (32-bit, prefetchable) [size=256M]
Capabilities: <access denied>
Kernel driver in use: agpgart-via
Kernel modules: via-agp
00:00.1 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
Flags: bus master, medium devsel, latency 0
00:00.2 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. PT890 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:00.7 Host bridge: VIA Technologies, Inc. CN700/VN800/P4M800CE/Pro Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
Flags: bus master, 66MHz, medium devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: fca00000-feafffff
Prefetchable memory behind bridge: aff00000-cfefffff
Kernel modules: shpchp
00:0f.0 IDE interface: VIA Technologies, Inc. VT8251 AHCI/SATA 4-Port Controller (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: VIA Technologies, Inc. VT8251 AHCI/SATA 4-Port Controller
Flags: bus master, medium devsel, latency 64, IRQ 26
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
Memory at febffc00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ahci
Kernel modules: ahci
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 07) (prog-if 8a [Master SecP PriP])
Subsystem: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
Flags: bus master, medium devsel, latency 32
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled]
I/O ports at fc00
Kernel driver in use: pata_via
Kernel modules: pata_via
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
Flags: bus master, medium devsel, latency 64, IRQ 20
I/O ports at e080
Kernel driver in use: uhci_hcd
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
Flags: bus master, medium devsel, latency 64, IRQ 22
I/O ports at e000
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
Flags: bus master, medium devsel, latency 64, IRQ 21
I/O ports at dc00
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 90)
Flags: bus master, medium devsel, latency 64, IRQ 23
I/O ports at d880
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 90) (prog-if 20)
Subsystem: VIA Technologies, Inc. USB 2.0
Memory at febff800 (32-bit, non-prefetchable)
Kernel driver in use: ehci_hcd
00:11.0 ISA bridge: VIA Technologies, Inc. VT8251 PCI to ISA Bridge
Subsystem: VIA Technologies, Inc. VT8251 PCI to ISA Bridge
Flags: medium devsel
Kernel modules: i2c-viapro
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 70)
Subsystem: ASUSTeK Computer Inc. Device 81b9
Flags: bus master, medium devsel, latency 0, IRQ 22
I/O ports at d400
Kernel driver in use: VIA 82xx Audio
Kernel modules: snd-via82xx
00:11.7 Host bridge: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
Subsystem: VIA Technologies, Inc. VT8251 Ultra VLINK Controller
Flags: bus master, medium devsel, latency 128
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 7c)
Subsystem: ASUSTeK Computer Inc. Device 80a7
I/O ports at d000
Memory at febff400 (32-bit, non-prefetchable)
Kernel driver in use: via-rhine
Kernel modules: via-rhine
00:13.0 PCI bridge: VIA Technologies, Inc. VT8251 Host Bridge
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=02, subordinate=04, sec-latency=0
00:13.1 PCI bridge: VIA Technologies, Inc. VT8251 PCI to PCI Bridge (prog-if 01)
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
01:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1)
Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64, IRQ 16
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at b0000000 (32-bit, prefetchable) [size=256M]
Expansion ROM at feae0000 [disabled] [size=128K]
Kernel driver in use: nouveau
Kernel modules: nvidiafb, nouveau
02:00.0 PCI bridge: VIA Technologies, Inc. VT8251 PCIE Root Port
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
Kernel driver in use: pcieport
02:00.1 PCI bridge: VIA Technologies, Inc. VT8251 PCIE Root Port
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
For the life of me i cant seem to find in this detail... my parallel port. if you can please point it out to me.
All I am trying to do is see if Ubuntu 10.04 Live cd ( installed ) recognizes my parallel port. YES IT IS BIOS ENABLED! :-D
I am trying to find this because i am getting not response from my mill. Emc2 is setup and works fine and I know my machine works; but there seems to be no communication / movement.
Ruled out all connections and hardware faults by diagnosis and good old trial and error, so basically im drawing down to the last few ideas (last being my new PP cable is faulty)
all help praised and appreciated
$ lspci -v
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at fc00
I/O ports at e080
I/O ports at e000
I/O ports at dc00
I/O ports at d880
I/O ports at d400
I/O ports at d000
17 May 2011 11:39 #9865
by BigJohnT
Replied by BigJohnT on topic Re:trying to find my parallel port
Many cheap parallel port cables don't have all the pins connected you may have one of those.
I "think" this is the onboard parallel port
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
I/O ports at ec00
I/O ports at e880
I/O ports at e800
I/O ports at e480
I/O ports at e400
17 May 2011 11:46 #9867
by billykid
Replied by billykid on topic Re:trying to find my parallel port
do not see parallel ports. in this list ..
but is integrated or pci? if it is integrated is usually 0x0378 or 0x0278
if not then emc error. means that there is.
17 May 2011 20:38 #9878
by stevec
Replied by stevec on topic Re:trying to find my parallel port
Take a look at the file /proc/ioports and see if anything called parport is listed in there.
17 May 2011 21:15 - 17 May 2011 21:17 #9881
by BigJohnT
After boot up open up a terminal and put
dmesg > boot.txt
then open the file and search for paraport.
or
dmesg|grep parport
dmesg > boot.txt
or
dmesg|grep parport
Last edit: 17 May 2011 21:17 by BigJohnT.
17 May 2011 21:41 #9885
by alexr
Replied by alexr on topic Re:trying to find my parallel port
you are correct john! spot on infact.
tired dmesg|grep parport as per one of your other posts and i get
:~$ dmesg|grep parport
[ 11.551600] parport_pc 00:07: reported by Plug and Play ACPI
[ 11.551671] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 11.648233] lp0: using parport0 (interrupt-driven).
so its there! phew
so its there! phew
Time to create page: 0.071 seconds
