linuxcncrsh -- need suggest for chang open prog
- bkt
- Thank you received: 114
03 Mar 2016 17:46 #70984
by bkt
linuxcncrsh -- need suggest for chang open prog was created by bkt
I read the doc .... set open command is usable only for 1 program at session .... than I can restart linuxcncrsh with other ini file with different base program in ini file ...... but I seeking a way to do these without restart linuxcncrsh session ....
some suggest?
Giorgio
some suggest?
Giorgio
- dgarrett
- Thank you received: 297
03 Mar 2016 20:48 - 03 Mar 2016 20:51 #70991
by dgarrett
Replied by dgarrett on topic linuxcncrsh -- need suggest for chang open prog
The following session worked for me
I use the following simple ngc files for testing:
and monitor the running program with halshow using:
telnet localhost 5007
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
hello EMC me 1
HELLO ACK i 1.1
set enable EMCTOO
set enable EMCTOO
set echo off
set echo off
set estop off
set machine on
set mode auto
set open /tmp/1.ngc
set run 1
set open /tmp/2.ngc
set run 1
$ cat /tmp/1.ngc
(debug, 1.ngc)
m68 e0 q1.1111 ;set pin motion.analog-out-00
m2
$ cat /tmp/2.ngc
(debug, 2.ngc)
m68 e0 q2.2222 ;set pin motion.analog-out-00
m2and monitor the running program with halshow using:
$ cat l.halshow
pin+motion.analog-out-00
$ halshow l.halshow &
Last edit: 03 Mar 2016 20:51 by dgarrett. Reason: typo
The following user(s) said Thank You: bkt
- bkt
03 Mar 2016 21:22 - 04 Mar 2016 08:26 #70994
by bkt
Replied by bkt on topic linuxcncrsh -- need suggest for chang open prog
Real tanks ..... but the doc report command "open" not be used to close program. Than with these limit run only 1program per session.
I'm glad I misunderstood....
Regards
Giorgio
Regards
Giorgio
Last edit: 04 Mar 2016 08:26 by bkt.
Time to create page: 0.144 seconds
