  • CNC_ANDI
  • CNC_ANDI
09 Dec 2024 19:29 - 09 Dec 2024 19:33
Replied by CNC_ANDI on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
ok thanks and how can i configure my axis display without dev install?
you can run fusion 360 for a 4th axis part....
always you have to do ist configure a 2D adaptive clearing and sort it in a round pattern...finish now you have a indexed 4th axis part
here is a 4th axis gcode:
File Name: 1001_2024-12-09.ngc
File Size:507 KB
  • 0x2102
  • 0x2102's Avatar
09 Dec 2024 19:08
Replied by 0x2102 on topic Exchange Spindle "Tab" with something else
Category: Gmoccapy
This is documented here:
linuxcnc.org/docs/html/gui/gmoccapy.html...tabs-and-side-panels
You can replace the spindle box with your own glade file / function.
  • Lcvette
  • Lcvette's Avatar
09 Dec 2024 18:34
Replied by Lcvette on topic Probe_Basic Bugs?
Probe_Basic Bugs?
Category: QtPyVCP
vtk which is the back plotter is undergoing extensive reconfiguring, so the latest stable had some issues in it that went unnoticed in certain areas. many things have been corrected in the develop version but a few still need to be sorted. one of the things was how the plotter draws and follows the program tool paths. hopefully this will be pushed and released very soon as i think most of it has been corrected but there are still a few bugs to sort out and testing is difficult without multiaxis cam available
  • RDA
  • RDA
09 Dec 2024 17:54
ASD B3 0121 L Loses connection with computer when Servo On
Category: Driver Boards
I would also add that if it’s possible to use shielded motor cables, use them and tie the shield to PE from both ends.
It’s the switching noise from the drive IGBT.
  • hmnijp
  • hmnijp
09 Dec 2024 17:46
Feedback control XY not full speed run G1 when curve or Arc
You should increase motion blending tolerance (g64 p0.002)
The more accurate the tolerance -> the lower the speed.
For roughing operation (adaptive) such accuracy is not required. Try setting P0.05, this will smooth the trajectory and allow it to be executed at high speed.
If the acceleration of your machine is not high, then for roughing operation you can choose P even more.
  • CNC_ANDI
  • CNC_ANDI
09 Dec 2024 17:07
Probe_Basic Bugs?
Category: QtPyVCP
In an older Probe_Basic version I adjusted the interface so that everything worked.
However, I don't know how to edit the interface in the stable version. I'll probably have to install the developer version again, which I don't necessarily want to do since the machine is currently in use.
However, I still have the question of why the 4th axis plot doesn't work, which used to work in the older version... my configuration has remained the same.
  • Deje63
  • Deje63
09 Dec 2024 16:22
Category: Gmoccapy
I do have an Kress 1050 FME-1, just manual ON/OFF (automatic via Zigbee Switch) and speed control. So the Spindle Tab in Gmoccapy is useless.
Is there any EASY way to exchange it with lets say ON/OFF Button for the Spindle?
  • digiex_chris
  • digiex_chris
09 Dec 2024 15:57
ah thank you! Knowing that it's possible is helpful. I will look into it and let you know if there is something we can adjust to make it easy.
  • meister
  • meister
09 Dec 2024 15:51
ok, IO_TYPE for cst pins are back, but only if it is set to non-default value
  • sk_linuxcnc
  • sk_linuxcnc
09 Dec 2024 15:30 - 09 Dec 2024 15:32
Turn of Digital output when E-stop is activated.
I have pneumatic actuator controlled by one of the digital outputs. when my machine goes into estop or external estop swtich is pressed, the system stops, but the pneumatic actuator still remains on!
i tried using the and2 examples from one of the earlier threads, but it didnt help me (or atleast i wasnt able to make the and2 logic work)
net estopwa and2.0.in0 <= halui.machine.is-on
net estopwa and2.0.in1 <= motion.digital-out-00
net parport.0.pin-07-out <= and2.0.out
- Also, as the program is resumed after the estop, i want it to run from the same line.
I have this in my ini file.
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
GCodeContinueOnEstop = True
However, if the program resumes from the same spot, and we reach a solution to turn off the pneumatic actuator on an estop event, the pneumatic actuator would remain disengaged, i want it to re-engage on the resuming of program.
Looking forward to expert help :D
  • Lcvette
  • Lcvette's Avatar
09 Dec 2024 15:25
(Solved)NameError: name 'tool' is not defined on Probe_Basic_Lathe
Category: QtPyVCP
Glad you got it sorted, I think there is a patch for linuxcnc versions after the lockdown 2.9.3 for this issue, it was discussed in a previous thread I think.
  • daveyr
  • daveyr
09 Dec 2024 15:25
Replied by daveyr on topic Ethercat-conf.xml with beckhoff el1008
Category: EtherCAT
Sorry not sure on loading to soon for the Mesa. My Ethercat is still on my bench system which i then have a esp32 for doing the other step and it didnt seem to matter the order or i have not played enough to cause errors.
  • Lcvette
  • Lcvette's Avatar
09 Dec 2024 15:23
Probe_Basic Bugs?
Category: QtPyVCP
Hmmm, sounds like a joint numbering issue and PB UI load issue, I will need to sit down and ponder this, covering all of the various configurations is a bit tough, need to find a better method I think. Maybe have the axis drop box be a user definable box.. not sure though, will take some figuring to find a solution I think. In the interim you may need to customize your UI. Any fixes for this will be have to come in the develop version and will be a bit away, I'm a bit slammed at work right now. I will update here as I find a good solution.
  • meister
  • meister
09 Dec 2024 15:11
I do not know why, but Tab Overview shows graphic again.
IO_TYPE is better to have back, please :-)
i have fixed the overview today.
IO_TYPE, no not at the moment, have to check some things first.
@digiex_chris
i have no RPI5, so i can not test it :(
i only know that there is a general problem with RPI5 and SPI,
but someone on youtube got it to work with RIO
  • CNC_ANDI
  • CNC_ANDI
09 Dec 2024 15:00
Probe_Basic Bugs? was created by CNC_ANDI
Probe_Basic Bugs?
Category: QtPyVCP
Hello i´m using the actually Probe_basic stable apt install and i have some questions....
i find a bug in the probe_basic axis view on the mainsite...
i´m using XYZB Axis but probe basic shows me XYZA
when i put on another axis like this XYZBW then probe_basic shows me XYZAB
the same on the single axis ref button i´m using a XYYZB Machine but...
X ref is ref my X Axis -> OK
Y ref is ref my Y Axis -> OK
Z ref is ref my Y Axis -> Fail
A ref and b ref i don´t know i have to try it...
the plot doesn´t show me the 4th Axis gcode...
when i turn my B Axis the plot turn the mill around my Y axis that´s ok. but when i load a 4th axis gcode the plot shows me only a 3axis gcode only the milling tool is rotating around the y axis
Displaying 21946 - 21960 out of 22112 results.
Time to create page: 0.501 seconds
