  • SilverRain
  • SilverRain
12 Aug 2024 19:58
Replied by SilverRain on topic Question: Gmoccapy 3.4.2 and touchscreen
Category: Gmoccapy
I haven't been able to get 2.9.3 to work for over a month now. more and more new problems... on another machine 2.8.4 there are already 4 goals - everything is fine. I have no more strength. Tomorrow I will roll back to 2.8.4
  • Mecanix
  • Mecanix
12 Aug 2024 19:35 - 12 Aug 2024 19:36
Replied by Mecanix on topic Computer crashing
Computer crashing
Category: Installing LinuxCNC
Have a look into /var/log/syslog and see if you can find anything time-relevant to your issue(s).
  • Lpkkk
  • Lpkkk
12 Aug 2024 19:20 - 12 Aug 2024 19:22
Hi pin outputs you can find in the attachment.
Estop has 2 pins, same for probe. Other inputs have one common and one negative for each input.
  • Mecanix
  • Mecanix
12 Aug 2024 19:18
Replied by Mecanix on topic Y axis configuration
#*** AXIS_Y *******************************
[AXIS_Y]
MIN_LIMIT = 0
MAX_LIMIT = 144
MIN_LIMIT = -144
MAX_LIMIT = 0
[JOINT_1]
MIN_LIMIT = 0
MAX_LIMIT = 144
MIN_LIMIT = -144
MAX_LIMIT = 0
Rename attachement keybingdings.py.txt to keybingdings.py
Place into your /config/ folder.
Hope this helps.
  • scda
  • scda's Avatar
12 Aug 2024 18:47
Mesa7i96s + 7i85 + pktv2 firmware for Huanyang VFD
Category: Driver Boards
Hi PCW. Ok thanks for the reply. This was my backup plan, so I will probably go this route then and leave the modbus stuff for another project.
Cheers,
David
  • swepeter
  • swepeter
12 Aug 2024 18:43 - 12 Aug 2024 18:45
Pi4b and Pi5 users - What should go in a 2.9.3 image
how do i use a img.xz.sha256 file?
I believe that is the wrong file
  • Ismacr63
  • Ismacr63
12 Aug 2024 18:37
Y axis configuration was created by Ismacr63
Hi, I've been trying to configure my Y axis on a bf20 type milling machine for a few days now.
I've read a lot on the forum, but I'm not able to configure it the way I'd like.
I understand that the Y axis, when the spindle moves away from me (or the table moves towards me) should be positive. That's what my Y axis does
I have an inductive sensor installed as a switch for both limits and home. When I search for home it goes to the negative side and I want it to go to the positive side.
I've tried HOME_SEARCH_VEL = 10.000000 and it goes to the positive side, but after home it always hits the hard limits when I get close.
Another issue is that I'd like to change the direction I move the table on the Y axis with the keys. When I press the up arrow I'd like the table to move away from me.
  • PCW
  • PCW's Avatar
12 Aug 2024 18:36
I would think it would be simpler to use a 0-->10V analog spindle speed control
Also, I'm not sure if the Mesa MODBUS interface would work with the Huantyang
  • AndyDM01
  • AndyDM01
12 Aug 2024 18:27
I have serious questions about some stuff I didn't find an answer for
Category: EtherCAT
I am just overloaded with other jobs at work right now, didn't even get the one I am retrofitting from mach3 (dead Bob... again!) to linuxcnc to move yet... already working overtime just trying to get the normal repairs done in a normal schedule..
  • AndyDM01
  • AndyDM01
12 Aug 2024 18:21
Category: EtherCAT
this is exactly what i told to my boss about this shite pneumatic cilinder doing the up / down torch BS... thx Rodw for pointing this out . when you can have the chance to upgrade a machine, then you should upgrade the machine all the way
  • Krulli_Fräser
  • Krulli_Fräser
12 Aug 2024 18:18
Replied by Krulli_Fräser on topic 7i97t with 7i84d connection problem
I have 24V on the 5 pins to the left of the orange screw terminal.
  • besriworld
  • besriworld
12 Aug 2024 18:12
Replied by besriworld on topic OLD Lathe conversion to a CNC
Category: Turning
Thanks, what size should the ring be?
  • PCW
  • PCW's Avatar
12 Aug 2024 18:03
Replied by PCW on topic 7i97t with 7i84d connection problem
Looks OK, can you verify that you have +24V
on both VFIELDB pins?
  • Carsten
  • Carsten
12 Aug 2024 18:00
Replied by Carsten on topic Probe Basic in QTDragon
Category: Qtvcp
Hi Chris,
I upgraded to 2.9.3 and would appreciate a hint how to use a custom iu file.
Kind regards
Carsten
  • cncproject2024
  • cncproject2024
12 Aug 2024 17:53
Replied by cncproject2024 on topic Wiring limit switches to MESA 7i96s
I have now solved the issue. Thanks for the help
Displaying 23251 - 23265 out of 25032 results.
Time to create page: 0.541 seconds
