  • julienrl
  • julienrl
09 Aug 2024 23:53
7i76e to Spindle analogic from Cortini mill L300
Category: Driver Boards
Hello, terribly sorry to revive this thread, but I am looking for someone who can help me re-wire my Cortini L300 that a acquired with the boards unplugged. I have a partial manual and have just finished rebuilding the fried spindle control board, but I am not sure which wires the interruptor connects to, nor where the AC input goes into the board as that page of my manual is missing.
Thank you
  • Mecanix
  • Mecanix
09 Aug 2024 23:53
linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Yeah them awesome silicon. Received 2 (two) ESP32-P4NRW32 to prototype hardware with, looking forward integrating them into projects. Here's the pre-release official block diagram for it, the one advertised is kinda old.
CONF. Do NOT share those attachments, yet. For your eyes only.
  • fsabbatini
  • fsabbatini
09 Aug 2024 21:53
Cylindrical mapping was created by fsabbatini
Cylindrical mapping
Category: Show Your Stuff
Cylindrical mapping in linuxcnc: you program a part with X Y and Z in a lathe and it is mapped in a rotary axis (using spindle a C axis)
Better explained here
Best regards!
  • rodw
  • rodw's Avatar
09 Aug 2024 21:29
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Can you share any solution for fix this error about DKMS and don't need  to reinstall with .ISO ?
Refer here. Please restrict this thread to Ethercat installation only
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
  • PhilipME
  • PhilipME's Avatar
09 Aug 2024 21:16 - 09 Aug 2024 21:18
Replied by PhilipME on topic my f`irst hal `file need help
yes
I was missing the start
after adding start it is working
Now I will read how to make soft button
  • Grotius
  • Grotius's Avatar
09 Aug 2024 20:58 - 09 Aug 2024 21:26
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
Hi guys,
Tonight i did a test on the ethercat production machine, i brought a pc for the machine, pre installed linuxcnc and halcore on it.
This pc was already tested ok on the ethercat test board.
At the machine, after a while i came to the conclusion that one of the lcec output module's was broken, the stepper dir module.
altough it's brand new.  So maybe it is thanks to Stuxnet that i had so much trouble this week.
I had to drive to home again, and get a other lcec module. Then replaced it, and it worked.
But then the 24v input's where a problem. The input lights are burning on the module, but in halview, no signal is incoming.
So that's a problem i still have to solve. It was no problem for testing the machine altough.
Ok i made a few video's to show you.
The machine is never used before, and is software limited to 15000mm/min, it can run up to about 19000mm/min.
The machine has 2 x-axis motors, 1 for y, 1 for z. The machine setup is backslash free.
At the time it was configured with steppers. Nowaday's i think i would use servo's.
The machine in the workshop, the workshop i a collection of items, you see an old car in the background.
First video, running halcore.
Surface test.
Lcevette file milling, tiny product.
  • Alexandrion
  • Alexandrion
09 Aug 2024 20:46
Replied by Alexandrion on topic Spindle.0.at-speed False not inhibiting motion
Category: HAL
That is exactly what I did to solve the issue. The interesting part is that this behavior become apparent only after I upgraded my PC and changed my Mesa 5i25(PCI) with 7I92TF(ethernet).
  • PCW
  • PCW's Avatar
09 Aug 2024 20:27
Replied by PCW on topic my f`irst hal `file need help
I'm not sure about halrun but the thread component needs
a start command when run from halcmd
  • dave.franchino@gmail.com
09 Aug 2024 20:25
Can you get me started on using LinuxCNC on a non-traditional kinematic mechanis
Sorry... another newb question.
I have written and understand the need for a reverse transformation that converts a desired X,Y location to joint rotations (I have a simple 2-axis system).
We are running in open loop so there is no feedback.
Is there a reason LinuxCNC needs the "forward transformation" (which if I understand correctly, would convert a known joint rotation to LinuxCNC to a specific X,Y location. in an open loop system, what purpose does having both a forward and reverse transformation in your kinematics file do?
09 Aug 2024 20:15
Replied by dave.franchino@gmail.com on topic configuring my GPIO pins to linuxcnc with Raspberry pi 4
Category: HAL
Rod,
Also a newby here - trying to run LinuxCNC on a Raspberry pi4 and use the GPIO but getting an error that we don't have hal_pi_gpio module. Where do we find this? I've seen reference to this being part of Machinekit. Do we need to replace our existing LinuxCNC install with Machinekit or can we simply install the necessary hal_pi_gpio modules to get the GPIO running with our Pi4?
  • PhilipME
  • PhilipME's Avatar
09 Aug 2024 20:07 - 09 Aug 2024 20:08
my f`irst hal `file need help was created by PhilipME
I want to change the state of pin 17 on my breakout board. At this stage, I dont want any GUI involved.
I want to change the state of pin 17 by halrun command
halcmd: setp parport.0.pin-17-out 1
the hal file name secondhal.hal,      then I issue
halrun -I -f secondhal.hal
loadrt threads name1=base-thread fp1=0 period1=50000 name2=servo-thread period2=1000000
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
1addf parport.0.read base-thread
but no change to bob pin 17
Can anyone help?
Good day
Philip
  • Bari
  • Bari's Avatar
09 Aug 2024 19:07 - 09 Aug 2024 19:11
Replied by Bari on topic Remora for RP2040
Remora for RP2040
$5 Raspberry Pi Pico 2 with RP2350 Microcontroller
linuxgizmos.com/introducing-the-5-raspbe...350-microcontroller/
Now we need them to combine the newer 2350 with the W5500.
  • Moutomation
  • Moutomation
09 Aug 2024 18:19
Category: EtherCAT
Make a new and clean installation on another computer, do not touch the existing computer. If you can run it on a new computer, reinstall it on your existing computer.
  • Henk
  • Henk
09 Aug 2024 18:18
Category: HAL
If spindle at speed signal goes false during a feed move, motion does not stop. It will only stop at the end of the current move,before the next move.
We have 3 deckels, all with gearboxes that are automated. I always invert the spindle at speed signal and connect it to motion.feed-inhibit to deal with this issue
Henk
Displaying 23416 - 23430 out of 25036 results.
Time to create page: 0.466 seconds
