- Hauligali22
- Hauligali22
08 Aug 2024 22:00
Replied by Hauligali22 on topic Closed Loop Computer Vision Enabled CNC
Category: QtPyVCP
Hello again, what is the difference between using hal and using Dmitry's pick and place machine? I have been briefly reviewing Dmitry's honestly incredible machine and it is frankly very complicated for me given my inexperience although I am hoping to obtain the necessary experience for my own project.
- Jindy
- Jindy
08 Aug 2024 21:21
Replied by Jindy on topic Second LPT port - SOLVED!
Thanks for putting up these instructions. I followed them to add a second parallel port, and linuxcnc now doesn't give any warnings when I run the 2 port tester. The on board port works with the tester, but the second port outputs are all stuck at 5V, regardless of what I toggle. Do you know what could be the problem?
- Hauligali22
- Hauligali22
08 Aug 2024 20:52
Category: QtPyVCP
Hello, I have been using opencv to perform just regular tracking but I have no idea how to implement the opencv tracking algorithms in a cnc machine. Aciera has given some awesome ideas for doing the closed-loop part, how does your implementation work?
- zz912
08 Aug 2024 20:50
Home => +A
End => -A
???? => +B
???? => -B
???? => +C
???? => -C
Here are the already occupied keys:
github.com/LinuxCNC/linuxcnc/blob/b054eb...ccapy.py#L3052-L3295
Replied by zz912 on topic Jog keys for A axis
Jog keys for A axis
Category: Gmoccapy
To Mariusl:What keys do you suggest?
To Aciera: Can I ask you for Pull Request?
I would also like this improvement.
For at least five (5) axis please but all six will be better.
Home => +A
End => -A
???? => +B
???? => -B
???? => +C
???? => -C
- scotta
08 Aug 2024 20:44
Deadband should be a positive number. I'll need to force that in the code. What you've done is kinda like what Cakeslob suggested.
// apply the deadband
if (error > deadband)
error -= deadband;
else if (error < -deadband)
error += deadband;
else
error = 0;
// calculate the output value
vel_cmd = pgain * error + data->cmd_d * ff1gain;
Try increasing your pgain.
error -= deadband;
error += deadband;
else
error = 0;
08 Aug 2024 19:49
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Category: EtherCAT
yes tested it works on my chromebook so it should work on any device Ethercat supports. Shame it does not have an Ethernet port
copy text to a file. call it ethinstall.sh and make it executable:
chmod +x ethinstall.sh
./ethinstall.sh
08 Aug 2024 19:37
Category: EtherCAT
The Raspberry pi images do not include the Ethercat repositories but enabling some commented out code should enable it according to feedback from etherlabmaster
Try running a script something like this
#!/bin/bash
# Install companion repositories. NOTE: QTPYVCP does not support the raspberry pi.
echo "Install ethercat repository"
mkdir -p /usr/local/share/keyrings/
wget -O- https://build.opensuse.org/projects/science:EtherLab/signing_keys/download?kind=gpg | gpg --dearmor | dd of=/etc/apt/trusted.gpg.d/science_EtherLab.gpg
tee -a /etc/apt/sources.list.d/ighvh.sources > /dev/null <<EOT
Types: deb
Signed-By: /etc/apt/trusted.gpg.d/science_EtherLab.gpg
Suites: ./
URIs: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/
EOT
08 Aug 2024 19:30
Replied by rodw on topic ethercat master service
Category: EtherCAT
no, out of my depth here but to me lcec.0 and lcec.1 imply separate instances of Ethercat. I would put them on different Linuxcnc threads so the timing is different.
- Moutomation
- Moutomation
08 Aug 2024 19:26
Replied by Moutomation on topic Ethercat installation from repositories - how to step by step
Category: EtherCAT
Hello,
Is it possible to install ethernet for raspbery pi? Are the iso files up to date ?
08 Aug 2024 19:18
Replied by rodw on topic Installing Linuxcnc on Debian Bookworm
Category: Installing LinuxCNC
Yes its pretty easy to give a user sudo access. I think from memory using sudo then requires root's password.
You just need to add your user to the sudoers user group when signed in as root
usermod -aG sudo newuser
- papaathome
- papaathome
08 Aug 2024 19:09
I want to mention a few points I ran into. Maybe others can do there advanage with it.
First: There is a warining not to supply a root password when installing Debian. If you do give a root password then sudo is disabled.
Of cause I had supplied a root password (old habits dont die easily!)
I had two options, reinstall and don't supply a password or find out how to enable sudo. I opted for the second one.
If you search the internet then you can find several sites with advice how to do it.
In the instructions I used the command `adduser username sudo` is used. That command could not be found.
Solution: use `whereis adduser` then use the command with the full path.
The rest is just read first, check and check again then do exact what you are told to do. No further problems.
Now running kernel Linux 6.1.0-23-rt-amd64 with LinuxCNC installed.
Latency tests are a factor 2 better compared to running LinuxCNC life.
I have made some changes in the bios between testing with LinuxCNC life and the current situation but have not (yet) fully tuned this installation.
I want to try the next step, using the RTAI kernel.
Kind regards.
Replied by papaathome on topic Installing Linuxcnc on Debian Bookworm
Just followed the procedure, it was a doddle.Installing linuxcnc on a standard Debian instance is described in the docs here
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
Kind regards.
- anfänger
08 Aug 2024 18:10
Replied by anfänger on topic Fehlmann Picomax 100 Retrofit
Category: Milling Machines
- anfänger
08 Aug 2024 18:02 - 08 Aug 2024 19:35
Replied by anfänger on topic Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
Category: QtPyVCP
Hi I installed the development system with 2.9.3 and the deb files like in the tutorial described.
kcjengr.github.io/probe_basic/development_quick_start_apt.html
Then I tried to open my config I used with probe_basic under 2.8.2. Fixed the python3 issues with my own Hal components.
now it ts trying to start an I am expecting to fail due to missing Hal pins from qtpyvcp, cause I heavyly modified the ui file to match my machine.
but I get this error:
I guess try coming from my custom_config.yml
ad related files.
and when I emote the custom widget (its for setup sheets)
I come to the point where it fails due to missing pins.
copying my ui file over the one in the deb package let it fail again.
I guesss there were some changes which make it fail.
I'll made all ma chalets just to one tab I added.
So I did edit this section in the ui file. and still run into errors.
I am afraid I need to redo all ma work. maybe its faster since I've done it before
will there be a better option in the future keep custom tabs?
for more complex machines this might help a lot.
Thanks Patrick[/code]
[qtpyvcp.app.launcher][CRITICAL] Unhandled exception in probe_basic line 8 (launcher.py:37)
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config['windows'])
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 228, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 208, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/home/wully/linuxcnc/configs/wully/custom_probebasic.py", line 15, in __init__
super(CustomProbeBasic, self).__init__(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 35, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 47, in __init__
self.loadUi(ui_file)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 106, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
return self.parse(filename, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 118, in createQObject
return self._cpolicy.instantiate(factory, *args, **kwargs)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 137, in instantiate
return clsObject(*ctor_args)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/display_widgets/vtk_backplot/vtk_backplot.py", line 179, in __init__
self.default_view = view_options[view_default_setting]
ad related files.
# example of a machine specific settings
windows:
mainwindow:
provider: custom_probebasic:CustomProbeBasic
#windows:
# mainwindow:
# kwargs:
# confirm_exit: false
settings:
# VTK backplot view settings
backplot.show-grid:
default_value: false
backplot.show-program-bounds:
backplot.show-program-labels:
backplot.show-program-ticks:
backplot.show-machine-bounds:
backplot.show-machine-labels:
backplot.show-machine-ticks:
backplot.perspective-view:
backplot.view:
default_value: P
options: ["X: Front View", "XZ: Lathe View", "XZ2: Lathe View", "Y: Front View", "Z: Top View", "Z2: Bottom View", "P: Isometric"]
backplot.multitool-colors:
default_value: True
sys.exit(main())
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
ModuleNotFoundError: No module named 'qtpyvcp_conversational_gcode'
sys.exit(main())
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 116, in createQObject
raise NoSuchWidgetError(classname)
PyQt5.uic.exceptions.NoSuchWidgetError: Unknown Qt widget: HalLCDNumber
- Lpkkk
- Lpkkk
08 Aug 2024 17:30
Replied by Lpkkk on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I will try your settings. So far the best settings I could find were :
DEADBAND = -0.0002
FF1_GAIN = 1
P_GAIN = 1
I put negative deadband because it seems to work better than positive. I've tried many di settings in last few days. A lot of testing.
DEADBAND = -0.0002
FF1_GAIN = 1
P_GAIN = 1
- anfänger
08 Aug 2024 17:04 - 08 Sep 2024 15:23
Replied by anfänger on topic Mesa Analog Vs Step Dir
Category: Driver Boards
thanks again.
Update is running...
And home with index is working!
many thanks!
many thanks!
Time to create page: 0.430 seconds
