  • CNC_Tinkerer
  • CNC_Tinkerer
07 Aug 2024 14:46
Replied by CNC_Tinkerer on topic Latency, error finishing read, and IRQ affinity
Is it possible /etc/default/irqbalance is not being used and thus not reaching our lcnc_irqbalancepolicy.sh file? I don't understand how that process is supposed to work...
  • PCW
  • PCW's Avatar
07 Aug 2024 14:36 - 07 Aug 2024 16:07
Replied by PCW on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Just a guess but you definitely  do _not_ want a gateway (or DNS)
address on the 10.10.10.x range
  • Muftijaja
  • Muftijaja
07 Aug 2024 14:31
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Well, that was at the time as I cut the MEesa eno1 connection in purpose to be in internet and coming into the forum to write my post.
Eno1 has a fixed IP in network manager:  10-10-10-10 MEsa resp. -2 for Intel Card.
The connection eno1 does not have an ip adress in that state. Here is an ip a with both states. Upper feedback is with connection active, lower lines without.
Content of /interfaces is commented out except the loopback:
  • CNC_Tinkerer
  • CNC_Tinkerer
07 Aug 2024 14:27 - 07 Aug 2024 14:33
Hi!
I am working with a custom ethernet interface and think I really need this IRQ management. Unfortunately I have not been able to get what's described here to work after quite a few hours beating my head on the desk and rereading ALL these posts several times. I've tried a number of things but I don't know much about scripting. I'm probably missing something obvious.
If someone has debugging suggestions or can tell me what other information to post here I would really appreciate it.
Architecture: x86_64
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 17
Model name: AMD Ryzen 5 PRO 2400G with Radeon Vega Graphics
The obvious things:
I did install irqbalance via Synaptic. I did change IP to 10.0.0.1 two places in rt_setup.sh--that's the address in interfaces file.
What happens:
If I run rt_setup.sh it says it is creating the affinity file, and it ends up in /etc/linuxcnc as expected with permissions correct. But after restart I seem to end up with ethernet interrupts always on cpu5 where I would expect cpu7.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./rt_setup.sh
[sudo] password for user1:
Linux debian2 4.19.0-16-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.181-1 (2021-03-19) x86_64
GNU/Linux irqbalance is running AND there are more than 2 cpus - setting up policy script
The script comes up with isolcpus 6,7 in grub, which is what I determined months ago and added manually and seems like it should be correct.
    linux    /boot/vmlinuz-4.19.0-16-rt-amd64 root=UUID=5b220cf2-b101-424f-9abb-ee2246a65503
ro initrd=/install/gtk/initrd.gz quiet
isolcpus=6,7 intel_idle.max_cstate=1 i915.enable_rc6=0
my /etc/network/interfaces (after removing commented out lines and loopback):
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/*
# NEW - Lenovo Ryzen desktop PC
allow-hotplug enp8s0f0
iface enp8s0f0 inet static
address 10.0.0.1
Significant things I tried:
Running test script "pinirq_2024-05-12.txt" with parameter enp8s0f0 displays expected results. But watching interrupts stills shows the nic IRQs on cpu5.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo ./pinirq enp8s0f0
Cores: 8 Old CPU Mask: 0020 Set device enp8s0f0 IRQ 61 CPU mask to 0128
I tried using NIC=`enp8s0f0` in place of both awks in rt_setup.sh but that does not work either (note the quotes I used!).
I did have loopback lines and old (commented out) iface and address lines in interfaces file. I removed them and reran everything as I'm not sure how picky that grep is.
user1@debian2:~/linuxcnc/irq-mgmt$ sudo /etc/init.d/irqbalance status -l
● irqbalance.service - irqbalance daemon
   Loaded: loaded (/lib/systemd/system/irqbalance.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2024-08-07 08:31:44 EDT; 1h 8min ago
     Docs: man:irqbalance(1)
           https://github.com/Irqbalance/irqbalance
 Main PID: 577 (irqbalance)
    Tasks: 2 (limit: 4915)
   Memory: 6.3M
   CGroup: /system.slice/irqbalance.service
           └─577 /usr/sbin/irqbalance --foreground --policyscript=/etc/linuxcnc/lcnc_irqbalancepolicy.sh
Aug 07 08:31:44 debian2 systemd[1]: Started irqbalance daemon.
section from /proc/interrupts:
60: 0 0 0 0 0 0 0 0 IR-PCI-MSI 4726791-edge xhci_hcd
61: 0 0 0 0 0 71062 0 0 IR-PCI-MSI 4194304-edge enp8s0f0
62: 0 0 0 697991 0 0 0 0 IR-PCI-MSI 4718592-edge amdgpu
  • DoWerna
  • DoWerna's Avatar
07 Aug 2024 14:15
Retrofitting a small bending machine was created by DoWerna
Category: CNC Machines
Hi
seem to have stumbled into a little project.
I have already retrofitted my Maho MH500 and a cycle lathe to Linuxcnc
retrofitted, which is why a friend has now asked me to have a look
to have a look at his bending machine.
The press was probably retrofitted to a newer control system.
However, it has now stopped working and when I switch it on I get the error message
"WARNING LOST VIDEO TABLES"
if I google this I only find 3 forum entries, but without any answer or even a solution.
I can't say whether the controller is broken or "just" lost the programming or parameters...
In any case, I now need a replacement.
A simple 3-axis positioning controller.
The controller would only have to control 2 stops and the press stop.
all 3 axes have analog -10/+10V drives
there are probably 3 encoders somewhere for the position feedback
and that's about it.
I don't need cycles and bending programs.
If we get the 3 axes into the desired position via the control system and
then operate the press hydraulically as usual is enough...
If the machine were in my shop, I would say
Linuxcnc Raspberry, small TFT mesa card and I operate the thing via Gcode in MDI.
Maybe there is a simpler standalone solution?
  • JamesHoward
  • JamesHoward
07 Aug 2024 13:56
Replied by JamesHoward on topic Is a parport fast enough?
totally off topic... (off linuxcnc too) do any of you know anything about old fanuc controls?? A fanuc model 0m-b in particular....
  • PCW
  • PCW's Avatar
07 Aug 2024 13:37 - 07 Aug 2024 13:39
Category: Deutsch
So eno1 does not have an assigned IP address
What does /etc/network/interfaces contain?
cat /etc/network/interfaces
  • Sami
  • Sami
07 Aug 2024 13:13
Replied by Sami on topic Pc reboot / 5i25(6i25) & 7i77
Ok, we stay with 3.40. Those two different test pc have own power supply. Both are 650w and different brand.
  • rdtsc
  • rdtsc's Avatar
07 Aug 2024 13:04
Replied by rdtsc on topic Help me setting up My LinuxCNC
Category: Basic Configuration
You must identify how the EStop is exposed by the MPG. There is nothing about EStop in the mpg.hal file above. You may have to consult the MPG manual. It may be exposed as a signal you can add to the mpg.hal file, or it may only be exposed as two or four wires (which you must wire as a hardware-EStop.)
Your .hal file also does not have any entries for EStop. You'll need to use the .hal command 'net' to link it. How the 'net' command works: linuxcnc.org/docs/2.5/html/hal/basic_hal...#_net_a_id_sub_net_a
Once you figure out how your EStop button works, it would be best to find a similar setup: duckduckgo.com/?q=linuxcnc+estop+net
07 Aug 2024 12:50
Replied by tommylight on topic Pc reboot / 5i25(6i25) & 7i77
No beta, might have bugs.
Are you using the same power supply for all those boards?
If yes, change the power supply.
  • Moutomation
  • Moutomation
07 Aug 2024 12:45
Replied by Moutomation on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
thaks a lot
  • Sami
  • Sami
07 Aug 2024 12:43
Thank you for your quick response!
Prime x370x-pro motherboard has bios version 6042 and we can update it to next week. At the moment we have another (newer) motherboard
to test with. Asrock Phantom Gaming 4 B550M and it have bios version 3.40 [2024/1/23] (latest stable version) and with this setup we still have
reboot issue with Lathe software. Should we go with beta 3.41 (Update AMD AM4 AGESA Combo V2 PI 1.2.0.C)?
  • Aciera
  • Aciera's Avatar
07 Aug 2024 11:42
Replied by Aciera on topic gmoccapy pins
gmoccapy pins
Category: Gmoccapy
File path is defined in this line in the python code of the user component above:
file_path = 'file.txt'
eg change to:
file_path = '/home/<user_name>/<your_path>/<your_file>'
  • Moutomation
  • Moutomation
07 Aug 2024 11:32 - 07 Aug 2024 11:40
gmoccapy pins
Category: Gmoccapy
It's very nice, it works very well, thank you very much.
  • Muftijaja
  • Muftijaja
07 Aug 2024 11:00 - 07 Aug 2024 11:07
Category: Deutsch
Of course:
hanno@cnc2:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:0a:cd:00:00:56 brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.55/24 brd 192.168.178.255 scope global dynamic noprefixroute enp2s0
       valid_lft 855370sec preferred_lft 855370sec
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 00:23:24:5b:b4:ac brd ff:ff:ff:ff:ff:ff
    altname enp0s25
hanno@cnc2:~$
Tonight, I thought by myself - maybe it's a stroke of fate, that just one connection in time  is working correctly. I would never surf the internet while running my router. In real operation, I will need internet just for updates, research, nothing really worth. BUt technically, I think that should work, and in your simulation it ran free of problems. So, I would go on...
Thanks for your time!
Hanno
Displaying 23596 - 23610 out of 25041 results.
Time to create page: 0.479 seconds
