  • CORBETT
  • CORBETT's Avatar
10 May 2025 03:48
Help to configure external start button and external emergency button, EK1100
Category: EtherCAT
@Leuo_
Follow either of these two links and in the first post go down to PART 6 - LET’S SEE ETHERCAT WORK IN THE REAL WORLD .  There are detailed instructions on how to do the external Stop button and you should see how to do a start button also.
Ethercat build from source - full instructions - LinuxCNC
Ethercat build from source instructions - Updated for 2024 - LinuxCNC
Hope it helps,
Robert
  • hermann1976
  • hermann1976's Avatar
10 May 2025 03:23
Replied by hermann1976 on topic Change Tool Offsets after editing the Tool Table
Category: Gmoccapy
Thanks for your answer.
But Linuxcnc will coming up with an error:
  • cakeslob
  • cakeslob
10 May 2025 03:21
hey scott, ive been playing with it for the last 2 weeks. I dont have much to show, but i think the environment switching is working kinda. im testing with a nucleoh743, from the debug it seems to be working but serial is messed, it seems i dont know how to do a define or something,
github.com/cakeslob/Remora-STM32H7xx-PIO...43/Src/main.cpp#L116
  • cakeslob
  • cakeslob
10 May 2025 03:10
im not an expert but i think thats exactly what its supposed to look like (rpm changing as diameter changes). assuming those portions that are the straight lines are in between jog moves. I didnt see (or hear) any weird spindle speed drop outs like before thought. i am assuming you figured out the issue?
  • babinda01
  • babinda01
10 May 2025 02:14
Replied by babinda01 on topic Machine On Timer
Machine On Timer
Thanks Tommy
I think this is exactly what I was looking for.
  • ContactFever998
  • ContactFever998
10 May 2025 01:16
Replied by ContactFever998 on topic Help with Linux CNC Ethercat setup
Category: EtherCAT
I'm trying to use ethercat so via the onboard ethernet port to the drives.
Honestly, just because its small and would fit easily in my electronics enclosure.
I'm willing to setup a pc but would be process be any easier?
10 May 2025 01:15
Replied by tommylight on topic Machine On Timer
Machine On Timer
Press the machine on button 10 seconds before releasing E-stop.
Does not work, nothing will work while e-stop is active.
See timedelay:
linuxcnc.org/docs/2.9/html/man/man9/timedelay.9.html
  • langdons
  • langdons
10 May 2025 00:12
Replied by langdons on topic Ganty sawmill
Ganty sawmill
qtdragon_hd looks good and I've heard good things about it.
I personally can't get qtdragon to work at all.
But I am not that great at CNC stuff.
Just make sure to not accidentally saw jourself into pieces whilst attempting troubleshoot.
You have a nice HD monitor?
Touch screen is preferable (so I hear).
  • langdons
  • langdons
10 May 2025 00:07
Replied by langdons on topic Machine On Timer
Machine On Timer
  • langdons
  • langdons
10 May 2025 00:06
Replied by langdons on topic Help with Linux CNC Ethercat setup
Category: EtherCAT
How does the Pi communicate with (to?) the drivers?
Is there any specific reason you are using a Pi, not a PC?
For me, old PCs are very easily obtainable and work well enough (except when they randomy break for no reason).
  • langdons
  • langdons
09 May 2025 23:57
Replied by langdons on topic Which kernel version is best for real time?
If your CNC setup works, then don't worry and just move on.
If you are paranoid, just set your max jitter to some really high value in your config.
Don't worry about stuff unless you need to.
  • langdons
  • langdons
09 May 2025 23:50
Okay, disable hypethreading and turbo.
But don't mess with too much stuff.
"and any further interaction is at this point a worthless endeavour on my part."
Whoa!
Don't just write off people because they did one dumb thing!
  • langdons
  • langdons
09 May 2025 23:46
Replied by langdons on topic LinuxCNC S-Curve Accelerations
Sounds fun!
(not really)
  • langdons
  • langdons
09 May 2025 23:44
Can I have 2 seperate interfaces on the same computer?
Or different HDD.
Or different partition.
I reccomend never making an OS partition larger than 250GB so that way you might have extra space to make a dual-boot system.
My LinuxCNC PC has a 500GB HDD that has Ubuntu, Debian (For LinuxCNC), and some unpartitioned space.
  • PCW
  • PCW's Avatar
09 May 2025 23:34
analog Servo spins on its own when connected to 7i77
I would:
1. Disconnect the drive from the 7I77 analog output (with all power off)
2. Power up the 7I77 with LinuxCNC not running
3. Check the analog output voltage of the affected channel
If  it is not near 0V, the 7I77 output has been damaged
If it is near 0V when LinuxCNC is not running, (this is the expected condition)
It may simply be that the  feedback is reversed or there is some other tuning/setup
issue causing lack of control
Displaying 4726 - 4740 out of 24335 results.
Time to create page: 0.279 seconds
