USB IO module
08 Jan 2019 03:31 #123746
by crowloy
USB IO module was created by crowloy
Anyone ever find out a source for the USB IO module that Tormach uses? So far I've only found one that's similar and it might be possible to make it work, but it's a definite might.
08 Jan 2019 05:21 #123748
by smgvbest
Replied by smgvbest on topic USB IO module
Looking at how PP communicates with the board there are Tormach specific strings in it.
I would tend to believe that the board is either custom tormach or a commercial board that has been customized by Tormach.
it send the command VE and gets back two values, r and data, data contains the "Tormach I/O"
this is contained in the usbio.py file
A bit of recoding in the usbio.py probably could make this work with other boards.
the other thing you can do is you can map in the hal file I/O directly. i did this for 4 outputs as a test
08 Jan 2019 15:53 #123781
by sharmstr
Replied by sharmstr on topic USB IO module
At one time (last year) the IO module was a CP2102 with 4 relays attached.
23 Jan 2019 23:23 #124692
by jwatte
Replied by jwatte on topic USB IO module
It's a CP2102, a microcontroller, and four relays (output) plus four optocouplers (inputs) plus an ID selector.
If you're comfortable rolling your own, I reverse-engineered the protocol, and wrote firmware for the Teensy 3.2/3.5 microcontroller (Arduino-like but harder/better/faster/stronger) that emulates the USB I/O: github.com/jwatte/teensy_tormach_usbio
It can also be used on an Arduino Leonardo with minor changes, I've heard, but it doesn't work well on a "plain" Arduino because the serial bootloader gets in the way of properly detecting the board.
The following user(s) said Thank You: sharmstr
24 Jan 2019 12:39 #124731
by crowloy
Replied by crowloy on topic USB IO module
thank you for this. I figured that someone probably had done this before. I was going to eventually look into this myself, but this works too.
- Contract_Pilot
- Thank you received: 11
25 Feb 2019 06:25 - 25 Feb 2019 07:46 #127084
by Contract_Pilot
Replied by Contract_Pilot on topic USB IO module
I seen this on youtube..
Found the board in the video on amazon..
www.amazon.com/gp/product/B07DGPT293
Last edit: 25 Feb 2019 07:46 by Contract_Pilot.
The following user(s) said Thank You: tivoi
25 Feb 2019 09:15 #127093
by smgvbest
I saw that also and I have 3 of those boards, they are decent boards.
my concern with this is he's looking to sell these. my hope is he's designing his own board and not using this on. basically, relying on someone else who could stop production at anytime is usually not a good thing.
I wish him luck and it appears to work well.
I've played with the teensy code and find it ok but has some quirks and of course you have to add your own relays and input protection to teensy.
- Contract_Pilot
25 Feb 2019 12:05 #127101
by Contract_Pilot
Seen a post on the zone looks like he shelved the project due to MCU change on the board.
26 Feb 2019 00:42 #127135
by smgvbest
Yeh, that's why you don't based offerings on other hardware, you have no control.
and one of these type of boards is not that hard to design.
29 Apr 2019 21:04 #132315
by belli
Replied by belli on topic USB IO module
There has been a little progress on this board, new version with Pro Mini and this: www.dhgate.com/product/dc-5v-12v-24v-4-c...board/392767641.html daughter board.
There is a free version that supports one I/O.
jsea.tech.blog/arduino-uno-pathpilot-usb-i-o/
Github:
Hope this helps.
Github:
Hope this helps.
The following user(s) said Thank You: Dorro1971
Moderators: cncbasher
Time to create page: 0.223 seconds
