Low budget plasma setup, what do I need?
26 Apr 2019 10:42 #131939
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
This Shuttle box is not working OK, hardware errors running latency-histogram with or without GLX.
So I will have to find another candidate.
26 Apr 2019 13:51 #131954
Which LinuxCNC version / realtime system?
Replied by andypugh on topic Low budget plasma setup, what do I need?
26 Apr 2019 14:01 #131959
by tecno
26 Apr 2019 14:04 #131961
I would definitely suggest trying the Stretch ISO then.
www.linuxcnc.org/testing-stretch-rtpreem...tch-uspace-amd64.iso
26 Apr 2019 14:10 #131962
by tecno
Have to check first that my 7i90HD is ok, did not get mesaflash to find anything on --epp
Is Stretch OK with PPort?
26 Apr 2019 14:13 #131963
Yes.
Yes.
26 Apr 2019 14:27 #131965
by tecno
It appears be something wrong with my 7i90HD so I think I will try something else for my simple plasma setup.
26 Apr 2019 15:09 #131969
Replied by PCW on topic Low budget plasma setup, what do I need?
Did you make sure that your parallel port is set to EPP mode in the BIOS?
26 Apr 2019 15:23 - 26 Apr 2019 15:24 #131976
by tecno
Last edit: 26 Apr 2019 15:24 by tecno.
26 Apr 2019 16:12 #131982
You typically need to go in to the BIOS to enable EPP for motherboard parallel ports.
I am not sure how you do it for PCI cards.
