Low budget plasma setup, what do I need?
14 Aug 2019 17:58 #142139
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
As this PC is still under evaluation for the plasma I will reinstall to get it working.
Is the 4.9+80+deb9u7 OK or is there other more new?
14 Aug 2019 18:05 #142140
Replied by PCW on topic Low budget plasma setup, what do I need?
The OS version is not really relevant as far as the problem you have goes (not finding drivers), that a LinuxCNC setup issue
How did you install LinuxCNC on your PC?
14 Aug 2019 18:09 #142143
by tecno
linuxcnc-stretch-uspace-amd64.iso Downloaded june 11
14 Aug 2019 18:24 #142145
OK, that should work as-is
is it possible you have added a new linuxCNC installation on top
of the base installation included with stretch?
14 Aug 2019 18:30 - 14 Aug 2019 18:33 #142146
by tecno
Only update / upgrade
// edit
Did not have any printerport PCI card installed then at time of ínstall, can this have caused issues?
// edit
Last edit: 14 Aug 2019 18:33 by tecno.
14 Aug 2019 18:41 - 14 Aug 2019 18:42 #142148
No, not finding the hm2_7i90 driver sounds like a LinuxCNC issue
I suspect the update broke something but cannot be sure
I guess I would try with a virgin Stretch test ISO install to see
Last edit: 14 Aug 2019 18:42 by PCW.
15 Aug 2019 10:35 #142219
by tecno
Did new Install and still no joy.
bengt@plasma:~$ halcmd -f
halcmd: loadrt hostmot2
<stdin>:1: waitpid failed /usr/bin/rtapi_app hostmot2
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hostmot2 failed, returned -1
bengt@plasma:~$
So what can be wrong?
bengt@plasma:~$
15 Aug 2019 12:01 #142221
by tecno
I have decided to go with 7i96 as it is easier to work with compared to pport and 7i90.
15 Aug 2019 12:52 #142222
if "loardrt hostmot2" does not work, no Mesa cards will work
what do the commands
locate hostmot2
locate hm2_7i90
report?
locate hostmot2
locate hm2_7i90
report?
15 Aug 2019 13:10 #142223
by tecno
The command locate does not exist
bengt@plasma:~$ locate hostmot2
bash: locate: kommandot finns inte
bengt@plasma:~$
bengt@plasma:~$
Time to create page: 0.399 seconds
