Low budget plasma setup, what do I need?
15 Aug 2019 17:28 #142259
Replied by andypugh on topic Low budget plasma setup,going with 7i96
I was wondering if the problem was a wire-reduced parallel port cable (as those are quite common) but it seems to be working now?
15 Aug 2019 17:34 #142260
by tecno
Replied by tecno on topic Low budget plasma setup,going with 7i96
Hi Andy, yes it works sort of. Changed the pport PCI card so now readhmid and halcmd works but now I´m stuck to set up a config. A bit confused I am how to run stepconfig for 7i90.
15 Aug 2019 17:56 #142266
You _don't_ use Stepconfig for a 7i90. You use PncConf.
15 Aug 2019 18:01 #142267
by tecno
Really? There is no 7i90 in the dropdown menu.
15 Aug 2019 18:23 #142270
Try a 7i80, then do a search and replace. It should be close.
You will also need to change the loadrt hm2_eth line to match the 7i90 line that you have already used a few times.
24 Aug 2019 12:03 #143084
by tecno
24 Aug 2019 13:47 - 24 Aug 2019 13:50 #143091
by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
this low budget went way out of budget as it has been anounced around 1000
why not using standard RACK poinion at T10 or T5
as it is NORM like here
maedler.de/product/1643/1618/2130/zahnst...teilung-5mm-und-10mm
for plasma realy good workes fine and even no steplos at gantry gearing
Last edit: 24 Aug 2019 13:50 by pl7i92.
24 Aug 2019 13:50 #143092
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
Hmmmm. I have never said any amount on my budget only that I will use what I have on hand and try to make do with it.
Just now I do not afford to buy these racks in steel.
My car broke down = lost my power steering so I need to buy a new servo pump.
VAG parts are not cheap!
26 Aug 2019 13:07 #143218
by tecno
- Thank you received: 5923
26 Aug 2019 13:52 #143220
Maybe you should move here ?
Those racks do look nice.
Replied by tommylight on topic Low budget plasma setup, what do I need?
VW parts are pretty cheap here as they are the most used cars here and there are plenty of authorized and unauthorized dealers/services.My car broke down = lost my power steering so I need to buy a new servo pump.
Time to create page: 0.153 seconds
