Low budget plasma setup, what do I need?
26 Apr 2019 16:14 #131983
Replied by andypugh on topic Low budget plasma setup, what do I need?
Also, doesn't Mesaflash need to know the parallel port base address?
26 Apr 2019 16:19 #131986
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
Well in BIOS it is set to EPP = that is a nobrainer.
If 2 separate PC's are set to EPP show same error I read this as 7i90 is not working.
So I am really going to trash the 7i90 = too much problems.
Have to bite the bullet and arrange some cash so buy ETH based board as discussed earlier.
26 Apr 2019 16:21 #131987
by tecno
Not clear but PCW does not have this in his syntax. Have tried --epp --addr 0x0378 but get error on addr.
- Thank you received: 1369
26 Apr 2019 16:29 #131989
Replied by Todd Zuercher on topic Low budget plasma setup, what do I need?
The syntax for the command is in the 7i90 manual pg.19
www.mesanet.com/pdf/parallel/7i90hdman.pdf
one example there
one example there
mesaflash --device 7I90 --port 0x378 --verify FPGAFILE.BIT
26 Apr 2019 16:32 #131992
by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
i will make a YT video to show you how easy it is to get seting to the 7i92
low cost high efficent Mesa
26 Apr 2019 16:34 - 26 Apr 2019 16:36 #131993
by tecno
This is weird. Did take my laptop off from docking-station and mounted back and restarted and now I have connection via mesaflash to my 7i90.
Todd, your syntax do I have to know what bit file is flashed?
/edit
port = NO
addr = Yes
Verify = need to know what file
/edit
port = NO
addr = Yes
Last edit: 26 Apr 2019 16:36 by tecno. Reason: added text
26 Apr 2019 16:41 #131996
by tecno
26 Apr 2019 17:07 #132001
You appear to need (for example) --addr=0xe010 if the card is not on the 0x378 address
26 Apr 2019 17:29 #132004
by tecno
Now I have reflashed the board, so what pin numbers goes to X/Y/Z steppers? and where connect THCAD300?
26 Apr 2019 17:38 #132005
You seem to have flashed with a firmware that has no steppers.
What firmwares do you have available? You need one with both "SV" (for servo, to get an encoder for the TGCAD) and "ST" (for Stepper) in the name.
Time to create page: 0.111 seconds
