Low budget plasma setup, what do I need?
26 Apr 2019 17:42 #132006
by tecno
The file ending with plasma was suggested and is the one i flashed with
Replied by tecno on topic Low budget plasma setup, what do I need?
You seem to have flashed with a firmware that has no steppers.
What firmwares do you have available? You need one with both "SV" (for servo, to get an encoder for the TGCAD) and "ST" (for Stepper) in the name.
26 Apr 2019 17:48 #132008
Replied by PCW on topic Low budget plasma setup, what do I need?
Let me check that bitfile, it looks like sssvst8_8_8
27 Apr 2019 03:24 - 27 Apr 2019 03:25 #132051
freeby.mesanet.com/7i90_plasma.zip
Contains the correct bitfile (8 stepgens, 2 PWM gens and 2 "A" pin only encoders on I/O 0..23)
The one in the dist is broken, will fix tomorrow
Last edit: 27 Apr 2019 03:25 by PCW.
The following user(s) said Thank You: tecno
27 Apr 2019 08:11 - 27 Apr 2019 09:57 #132072
by tecno
Thank you very much Peter, appreciated.
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Step/Table1 (Out)
3 1 IOPort StepGen 0 Dir/Table2 (Out)
5 2 IOPort StepGen 1 Step/Table1 (Out)
7 3 IOPort StepGen 1 Dir/Table2 (Out)
9 4 IOPort StepGen 2 Step/Table1 (Out)
11 5 IOPort StepGen 2 Dir/Table2 (Out)
13 6 IOPort StepGen 3 Step/Table1 (Out)
15 7 IOPort StepGen 3 Dir/Table2 (Out)
17 8 IOPort StepGen 4 Step/Table1 (Out)
19 9 IOPort StepGen 4 Dir/Table2 (Out)
21 10 IOPort StepGen 5 Step/Table1 (Out)
23 11 IOPort StepGen 5 Dir/Table2 (Out)
25 12 IOPort StepGen 6 Step/Table1 (Out)
27 13 IOPort StepGen 6 Dir/Table2 (Out)
29 14 IOPort StepGen 7 Step/Table1 (Out)
31 15 IOPort StepGen 7 Dir/Table2 (Out)
33 16 IOPort PWM 0 PWM (Out)
35 17 IOPort PWM 0 Dir (Out)
37 18 IOPort PWM 1 PWM (Out)
39 19 IOPort PWM 1 Dir (Out)
41 20 IOPort None
43 21 IOPort None
45 22 IOPort QCount 0 Quad-A (In)
47 23 IOPort QCount 1 Quad-A (In)
Last edit: 27 Apr 2019 09:57 by tecno. Reason: added text
27 Apr 2019 09:54 #132075
by tecno
THCAD300 ordered
3x steppermotors ordered
Time to start CAD on the frame
27 Apr 2019 10:25 #132076
I'f its like my journey, I'll come back in 3 years....
Replied by rodw on topic Low budget plasma setup, what do I need?
THCAD300 ordered
27 Apr 2019 10:25 #132077
by tecno
L o L
27 Apr 2019 16:11 #132093
by tecno
27 Apr 2019 16:27 #132095
by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
27 Apr 2019 16:29 #132096
by tecno
Nice table, too big for me
Time to create page: 0.142 seconds
