Low budget plasma setup, what do I need?
27 Apr 2019 16:35 #132098
by pl7i92
Replied by pl7i92 on topic Low budget plasma setup, what do I need?
27 Apr 2019 16:47 #132105
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
I will design mine to take 1000x500 material size.
Plan is to have a stand with water-pan outside and the CNC frame is to be lifted in place to register on the stand.
Budget is very low, I have the material for the CNC frame that will be 80x40 Bosch alu extrusions. Linear rails I already have Bosh R1651. Not decided yet how to drive my X/Y but probably timing-belt as the frame needs to be kind of rugged with minimal manhandling problems during storage.
I have to purchase the material for the stand.
27 Apr 2019 21:55 #132126
Replied by rodw on topic Low budget plasma setup, what do I need?
I think 60mm would be OK. I started with a 150mm ball screw and by the time its was built travel is a maximum of 84mm and a lot of that (10-15mm) is currently below the slats based on where I have clamped off the torch.
- Thank you received: 5918
28 Apr 2019 00:08 #132136
Replied by tommylight on topic Low budget plasma setup, what do I need?
That is usable for sure. If you intend to use floating head ( highly recommended ), make it so it has as little travel to trip the switch as possible.
28 Apr 2019 08:31 #132163
by tecno
OK I hear what you say Tommy.
So I need to shout out to PCW for some help to add code for 7i37 (P2 or P3) as I will need inputs to get a floating head switch working.
28 Apr 2019 13:33 - 28 Apr 2019 13:43 #132175
by tecno
Last edit: 28 Apr 2019 13:43 by tecno. Reason: added picture
28 Apr 2019 15:54 #132182
by pl7i92
28 Apr 2019 16:28 #132186
by tecno
29 Apr 2019 01:40 #132227
One rail on each axis, linear rails, mind you. Nice!
That should work nicely for that size.
29 Apr 2019 06:38 #132246
by pl7i92
im not going with toms suggestion one rail at a 800mm Span
you need to go double rail even if you use SBR12 better then leave it with dirt running on aluminium
and on that size it is a posible middle Ballscrew drive
as special as he gots very stiff framing
he also planing to use a water plate you need no more then 2inches of water table hight pool seeling clue is enoff to hold the metal together
at that length and width hight
if you use L-profile it will give you even more stiffness
Time to create page: 0.275 seconds
