Plasma Stress Test
- thefabricator03
- Thank you received: 531
02 Dec 2019 03:06 #151722
by thefabricator03
Plasma Stress Test was created by thefabricator03
Hi Guys,
I have recently upgraded ( or downgraded depending on how you look at it) my machine to use Leadshine closed loop stepper motors instead of the DC servos I was using. (Leadshine call them Easy Servos)
They are rated at 7Nm @ 100 RPM and 0.6 Nm @ 2400 RPM. I am using a 10:1 reduction so I am hoping they will have enough torque to move my 140kg gantry at the same speed as my old servos. All the calculation I have done suggest they will work.
What I was wondering, what would be a good item to cut that will really test out the limits of the motors? I dont think the rectangle plates I usually cut with four holes will place much stress on the system.
- Thank you received: 1369
02 Dec 2019 04:52 #151727
Replied by Todd Zuercher on topic Plasma Stress Test
I think a series of high speed direction reversals including multi axis moves (all axis moving at once and changing directions together) is probably the best test and should stress the motors as much or more than most any cutting moves.
- thefabricator03
02 Dec 2019 05:38 #151728
by thefabricator03
Replied by thefabricator03 on topic Plasma Stress Test
Next question, what is considered high speed for a large gantry machine? 12500mm/m?, 24500mm/m?
- machinedude
- Thank you received: 271
02 Dec 2019 07:00 #151731
by machinedude
Replied by machinedude on topic Plasma Stress Test
i would start at 12500 mm/m and work up until you see a failure and then back it off 15 to 20 % if it were me and compare what you get with the servo motors you are replacing and see how well these closed loop steppers do.
- thefabricator03
02 Dec 2019 07:38 #151733
by thefabricator03
Stupid question, What would failure look like? Will the machine just not move any quicker past a certain point? Or will it shut down?
- machinedude
02 Dec 2019 08:12 - 02 Dec 2019 09:05 #151735
by machinedude
well basically your encoder feed back and motor won't match the controller if you loose steps and your drive should fault in that case. plus when you loose steps you have a visual on a stalled stepper as well.
Last edit: 02 Dec 2019 09:05 by machinedude. Reason: better basic description
- machinedude
02 Dec 2019 08:40 #151736
by machinedude
one last thing that might help you out is pay close attention to how the motors sound. if for some reason your drives don't fault out stepper motors make a very distinctive sound when they start loosing steps. some times they flat out stall and don't move and some times they cut in and out. if you notice any sound changes that would most likely be lost steps. that's when you start getting into your acceleration and speed type adjustments to fine tune your system. i don't know enough about linux in that department to offer any help.
- Thank you received: 5874
02 Dec 2019 10:30 #151737
Replied by tommylight on topic Plasma Stress Test
I hang a 6Kg vice from the torch mount and have it run one of the two attached gcode fro two days, checking at the end if it returns to the starting point correctly.
- thefabricator03
20 Jan 2021 23:36 #196036
by thefabricator03
21 Jan 2021 09:01 #196070
I can answer this now. High acceleration and lots of small parts, heaps of pierces will cause motors to overheat. When they overheat, they miss steps! I don't think closed loop steppers will help here.
So you can reduce the current but you loose torque so using a smarter driver such as those from Lam Technologies, you can reduce current when at constant velocity and only smash the amps at the motor for those few milliseconds its accellerating.
At this point, if you have not installed the drivers correctly, then the drives themselves will overheat. They can tell Linuxcnc of this via an error pin. But use the correct pin, this is treated similar to an estop. I need to do more work on how to handle it so it can recover (when they cool)
So then once you fix this, the plasma cutter can overheat. If this happens, it drops the ArcOK and Plasmac handles it very gracefully. It pauses and once the error subsides, pressing pause, the job continues.
Replied by rodw on topic Plasma Stress Test
The following user(s) said Thank You: tommylight, thefabricator03
