PlasmaC torch starting problem (Solved with help from the famous three)
15 Mar 2020 22:50 #160358 by phillc54
But I was using pierce only and it was that, that was getting rid of the G4
Yes, it only looks for spindle on signals and does it own thing.
That also explains the G1 X 0.000001 you referred to before, LinuxCNC needs to have some motion otherwise it won't turn the torch on.
If you had saved the Pierce Only file then added the G4 codes in then loaded it and run it in Pierce and Cut mode it should work.
15 Mar 2020 23:36 #160367 by Clive S
Yes I now understand what was happening. What this has now shown me is that the G4P15 after the first cut works but it is not good with a 15 sec delay before each cut . This looks like a problem with the cutter not fire-ing until the air stops.
I have tried it with THC off to no avail. So my next move is to have a temporary button to see if the torch will fire manually as the air is still purging (when it is purging the volts are hovering around 0-18 then when the air stops it is rock steady on zero)
15 Mar 2020 23:40 #160369 by phillc54
Have you tried a long Arc Fail timeout?
15 Mar 2020 23:42 #160370 by Clive S
What would you call long , 15 secs ?
15 Mar 2020 23:45 #160372 by phillc54
Yeah, I guess whatever you are using for the G4 time.
15 Mar 2020 23:47 #160373 by Clive S
Thanks Ok I will try that in the morning. (We are self isolating here)
16 Mar 2020 00:25 #160376 by phillc54
I thought Australia would be self isolating but heaps of folk here seem to have caught a panic virus.
16 Mar 2020 12:18 #160417 by Clive S
Phil I have now confirmed it is not a fault of the machine as it will fire when I manually used a button to cut the relay out ie shorted the relay contacts.
I think the problem is that the relay is not stopping energised long enough for the torch to fire.
Is there a parameter for that or is there a way to do it in the code I would like to try 2 secs
It could be that the hovering volts 0-20 is messing it up. I have tried OK Low Volts between 5-30
16 Mar 2020 23:50 #160489 by phillc54
The Torch On signal should be on the whole duration of the Arc Fail Timeout.
It could affect it if the voltage went above the OK Low Volts and then went back below it, that would be seen as an arc failure.
17 Mar 2020 08:31 #160520 by Clive S
I am not sure how to trouble shoot this. I have not tried OK_low_volts at zero !!
I have noticed when using the temporary push button I see the physical pilot ark come on then it changes to the full arc so there is a slight delay there.
Any suggestions? It will always work on the fist cut. But on the next cut I do see the relay energise very briefly.
Time to create page: 0.186 seconds
