PlasmaC Fiber laser 1Kw head height control + auto focuas
- Online
- Thank you received: 5906
30 Jul 2020 22:32 #176570
Replied by tommylight on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
Do you have any schematics or wiring diagrams or pictures of connectors and maybe the insides of it ?
Take some pictures, post them here, there are plenty of very smart people here that can figure out a lot of stuff like that.
30 Jul 2020 22:47 #176574
by taloot
not very hard its easier than plasma... in some aspects..
it works with plasmac as THC but i have to do some gas setting and GUI for it..
also changing probing process..
laser once it works almost no down time compare to plasma.. i have been working for 2 weeks and zero consumables, ( protection mirror and nozzle)
i think plasma no go,. anymore,,, price of laser almost same as powermax105 and consume 3.3KW of power compare to 15kw for plasma..
NO more 0-30 error
Replied by taloot on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
cutting head start from 500 USDhey taloot.
I am also interested in making a laser cutter.
did you end up getting plasmac going ok for laser cutters.
6k sounds like a pretty good price for a laser cutting head. and the mechanical machine would be easy as to make. it is just the laser beam controlling that is hard I think. and I would be very interested in seeing what you have gotten up to with that. in a few years I think I might try build one of these
Andrew
NO more 0-30 error
31 Jul 2020 00:52 - 31 Jul 2020 01:08 #176589
by taloot
drive.google.com/drive/folders/1YiR6bJno...X_Syypa1?usp=sharing this is the manual
on page 15 u can see the wiring
Last edit: 31 Jul 2020 01:08 by taloot.
The following user(s) said Thank You: Becksvill
31 Jul 2020 01:45 #176593
by phillc54
Replied by phillc54 on topic PlasmaC Fiber laser 1Kw head height control + auto focuas
It may be possible to add another mode to PlasmaC to handle the laser stuff, depending on what the requirements are.it works with plasmac as THC but i have to do some gas setting and GUI for it..
- Online
31 Jul 2020 07:59 #176612
From what i can gather from the manual, you need only 24V PWM OR 0-10V analogue to control it, the enable signal and the interlocks have to be closed.
Since you have the 7i76E, there is no need for anything else, wire the enable and the analogue outputs from the mesa spindle connector to the laser, wire the interlocks and it should work.
No need for ESP32 or serial anything, not even PWM.
31 Jul 2020 14:23 #176662
by taloot
exactly that what i want mode 3 for example
alot of work already done to plasmaC
31 Jul 2020 14:34 - 31 Jul 2020 14:45 #176664
by taloot
i used esp32 for THC only..
u need 24 PWM + 0-10v both important
both
0-10v to set the power ( i can set it always 10v)
PWM for modulating freq
so if analog is 10v and interlock is shorted and enable is triggered... the laser wont emit,, till i give PWM
i have same thought as u in the beginningFrom what i can gather from the manual, you need only 24V PWM OR 0-10V analogue to control it, the enable signal and the interlocks have to be closed.
both
Last edit: 31 Jul 2020 14:45 by taloot.
31 Jul 2020 14:38 #176665
by taloot
esp32 only act as capacitance amplifier like THC for plasma.
- Online
31 Jul 2020 16:11 #176676
That explains a lot, so still the 24V PWM can be done with 2 small transistors and 4 resistors, or buy a cheap module that does that but all seem to be for 10V output.
both
31 Jul 2020 20:54 - 31 Jul 2020 21:02 #176697
by taloot
pins and hardware connection is not problem,,
i want to know if there is component for piercing in linuxcnc or how the picing counted...
because i want to link the picing time,,, to specific pressure 28 psi for piercing and 12-13 psi.. for cutting,,
how can this be done (each material have different values but very close to eachother
also from piercing time i can set the PWM freq
if i took the pricing time as start point i can set all value accordingly
Last edit: 31 Jul 2020 21:02 by taloot.
Time to create page: 0.126 seconds
