PlasmaC Fiber laser 1Kw head height control + auto focuas
It may be possible to add another mode to PlasmaC to handle the laser stuff, depending on what the requirements are.it works with plasmac as THC but i have to do some gas setting and GUI for it..
also changing probing process..
i can give u for linuxcnc with VNC,, with acutal system connected we can test togather ,.. also i can hold the gui if u want,
STATE:
0 IDLE
1 PROBE_HEIGHT
2 PROBE_DOWN
3 PROBE_UP
4 ZERO_HEIGHT
5 PIERCE_HEIGHT
6 TORCH_ON
7 ARC_OK
8 PIERCE_DELAY
9 PUDDLE_JUMP
10 CUT_HEIGHT
11 CUT
12 PAUSE_AT_END
13 SAFE_HEIGHT
14 MAX_HEIGHT
15 FINISH
16 TORCHPULSE
17 PAUSED_MOTION
18 OHMIC_TEST
19 PROBE_TEST
20 SCRIBING
21 CONSUMABLE_CHANGE_ON
22 CONSUMABLE_CHANGE_OFF
23 CUT_RECOVERY_ON
24 CUT_RECOVERY_OFF
25 DEBUG
EDIT: I missed this post...
I'd be happy to take a look at the changes you have made.i can give u for linuxcnc with VNC,, with acutal system connected we can test togather ,.. also i can hold the gui if u want
PlasmaC has an output pin named plasmac.state-out which shows the current state PlasmaC is in.
Warning: Spoiler!STATE: 0 IDLE 1 PROBE_HEIGHT 2 PROBE_DOWN 3 PROBE_UP 4 ZERO_HEIGHT 5 PIERCE_HEIGHT 6 TORCH_ON 7 ARC_OK 8 PIERCE_DELAY 9 PUDDLE_JUMP 10 CUT_HEIGHT 11 CUT 12 PAUSE_AT_END 13 SAFE_HEIGHT 14 MAX_HEIGHT 15 FINISH 16 TORCHPULSE 17 PAUSED_MOTION 18 OHMIC_TEST 19 PROBE_TEST 20 SCRIBING 21 CONSUMABLE_CHANGE_ON 22 CONSUMABLE_CHANGE_OFF 23 CUT_RECOVERY_ON 24 CUT_RECOVERY_OFF 25 DEBUG
EDIT: I missed this post...I'd be happy to take a look at the changes you have made.i can give u for linuxcnc with VNC,, with acutal system connected we can test togather ,.. also i can hold the gui if u want
thats exactly what i was looking for,, thanks...
from PlasmaC state out.. i can control the gas and pwm from Qtpyvcp
but i have to link material profile.. to the qtpyvcp.. whats the easiest way for it? is there any component or hal for it?
plasmac_run.kerf-width-f
plasmac_run.thc-enable
plasmac_run.pierce-height-f
plasmac_run.pierce-delay-f
plasmac_run.cut-height-f
plasmac_run.cut-feed-rate-f
plasmac_run.cut-amps-f
plasmac_run.cut-volts-f
plasmac_run.puddle-jump-height-f
plasmac_run.puddle-jump-delay-f
plasmac_run.pause-at-end-f
plasmac_run.gas-pressure-f
plasmac_run.cut-mode-f
plasmac_run.use-auto-volts
plasmac_run.cornerlock-enable
plasmac_run.kerfcross-enable
plasmac_run.ohmic-probe-enable
plasmac_run.x-single-cut-f
plasmac_run.y-single-cut-f
plasmac_run.single-cut
plasmac_run.powermax-enable
you are gr8 manThe following HAL pins are available for reading:
Warning: Spoiler!plasmac_run.kerf-width-f plasmac_run.thc-enable plasmac_run.pierce-height-f plasmac_run.pierce-delay-f plasmac_run.cut-height-f plasmac_run.cut-feed-rate-f plasmac_run.cut-amps-f plasmac_run.cut-volts-f plasmac_run.puddle-jump-height-f plasmac_run.puddle-jump-delay-f plasmac_run.pause-at-end-f plasmac_run.gas-pressure-f plasmac_run.cut-mode-f plasmac_run.use-auto-volts plasmac_run.cornerlock-enable plasmac_run.kerfcross-enable plasmac_run.ohmic-probe-enable plasmac_run.x-single-cut-f plasmac_run.y-single-cut-f plasmac_run.single-cut plasmac_run.powermax-enable
i can fix the setting to make it in working state...
and i will let u access the machine.. to see what improvement u can make to be easier to choose between plasmaC modes
- Thank you received: 5909
A 40 to 80W CO2 one with the power supply !.....how powerful is a 500usd laser cutter? .............
and if I could do it for under 10k usd that would be awesome. If would pay for itself so fast. then I would just need a brake press and we are away. need a linuxcnc brake press controller next lol sounds like i better get up to speed with qtpyvcp
it would be good to get a fiber laser if possible
you should have a play maybe. we use laser cutters all the time to cut out our projects. (we pay another company to do it. But the cut quality is so good. it is amazing. )
and a chinese laser cutter is about 50000 usd for a 2kw one. and then you still get a chinese controller that may or may not break down and can't be fixed. So I am keen as to use linuxcnc I could make the frame for about 3 or 4k usd I think that would be with square linear rails and high speed chinese servos. and then the other big cost is the laser source.
That was a joke, CO2 can cut some plastic and wood, but not metal.is this from JPT tommy?
I am very interested in this and it would have been magnificent to have one now as i have two machines that can do some stupendous speeds and accelerations. But i can not order one for now.
