- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- Topic Author
- Thank you received: 5924
29 Aug 2020 17:22 #179947
But since you are here, there are still some issues with offsets in PlasmC like Z axis for some unknown reason retracting to 171.5mm and sometimes to 175mm and tripping the home/limit switch although it is set at max 170 in the ini and home is at 160, and sometimes completely stopping motion after such occurrences requiring disabling the machine and enabling it again to be able to continue.
This was all with version 169 and LinuxCNC master version, same issue was in 165.
Everything else works magnificently.
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
You are welcomed, always.Thanks for the kind words.
Unfortunately after several requests to finish that table and fill it with water, it remains unfinished and dry, most probably will remain for the rest of it's working life like so. It is out of my hands now, so i can just keep asking them to do that.You need to get some water in there to protect those slats Tom.
- Topic Author
29 Aug 2020 20:49 #179965
Here are some pics taken today while doing some more tuning and finding out that more expensive non original nozzles are much worse than the cheaper original ones from Trafimet, the non-original would not cut through while the original does this with the same settings : 85A and 400mm/m feed rate
I can feel the envy from TheFabricator coming my way !
The following user(s) said Thank You: thefabricator03, shpatb
29 Aug 2020 20:54 #179967
Replied by rodw on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Tommy, are you trying to start the battle of the holes?
- Topic Author
29 Aug 2020 20:59 #179968
Oh yes, yes, YES !Tommy, are you trying to start the battle of the holes?
- thefabricator03
- Thank you received: 531
31 Aug 2020 04:06 #180130
by thefabricator03
Very nice holes Tom. It is interesting about the consumables.
Replied by thefabricator03 on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- Topic Author
01 Sep 2020 21:11 - 01 Sep 2020 21:59 #180358
This is what i use, the Trafimet AutoCut P141 and the electrode and nozzles with 1.4 and 1.7mm orifice, i also have 1.1mm ones. The above cuts were done with the 1.4mm one. The torch is good for 120A at 100% duty cycle, costs me about 170 Euro new, a set of nozzle/electrode is 4.6 Euro, and a 1.1mm set can do over 1000 meters of cut on a 3mm plate, consistently, so bloody worth every cent.Very nice holes Tom. It is interesting about the consumables.
Last edit: 01 Sep 2020 21:59 by tommylight. Reason: typo
- thefabricator03
01 Sep 2020 22:40 - 01 Sep 2020 22:40 #180369
by thefabricator03
I think you need to build yourself a table and set up a cutting service Tom. Teach a young guy to run it for you and sit back and watch the money roll in!
I have thought about it, I really enjoy cutting parts on my machine.
Last edit: 01 Sep 2020 22:40 by thefabricator03.
- Topic Author
02 Sep 2020 06:46 #180400
Thinking of it and working on it, had a chat yesterday with a guy to do the assembly and he already has someone who does on site installations.
Thank you very much for your continued support and ideas and advice.
- Topic Author
14 Sep 2020 22:02 #182150
Some more pictures of the big machine
We did cut some 20mm plates but i was on the phone, it was a busy day as i had to go check an industrial wood router thingy, Italian made some 20 years ago, still in working condition but pretty much useless due to dated software, so the owner insists on updating it to LinuxCNC.
And another machine i have built for them and a retrofit of a chinese one with LinuxCNC some 2 years back, still both working flawlessly.
- thefabricator03
14 Sep 2020 22:33 #182154
by thefabricator03
I really like the neons Tom. Reminds me of my chick magnet street racing car I had when I was 17. You just need to add some sub woofers and a big amp!
The following user(s) said Thank You: phillc54, tommylight
- Other Stuff
- Show Your Stuff
Time to create page: 1.039 seconds
