- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- Topic Author
- Thank you received: 5924
28 Nov 2020 23:51 #190568
- thefabricator03
- Thank you received: 531
29 Nov 2020 00:16 #190570
by thefabricator03
Replied by thefabricator03 on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Its looking good.Ill trade you temps, its 39 at the moment with a top of 42.
- Topic Author
29 Nov 2020 00:22 #190572
I love summer, to bad i can not have it all the time.
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
OOO yes !Its looking good.Ill trade you temps, its 39 at the moment with a top of 42.
29 Nov 2020 01:14 #190574
by johnmc1
Replied by johnmc1 on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
42c here yesterday .
Shed footing looks interesting.
Is the shed footing fully covered with concrete?
cheers john
cheers john
- Topic Author
29 Nov 2020 01:29 #190577
Will be soon enough.Is the shed footing fully covered with concrete?
The following user(s) said Thank You: johnmc1
- thefabricator03
29 Nov 2020 01:30 #190579
by thefabricator03
Why welded and not bolted connections?
- Topic Author
29 Nov 2020 01:31 #190581
Saves time and gona be 2.5m above ground.
29 Nov 2020 09:08 #190593
by Clive S
Replied by Clive S on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
I see you have asked Santa to come early with his little helpers .
- Topic Author
29 Nov 2020 09:11 #190594
Yes, but did not bring any presents!I see you have asked Santa to come early with his little helpers .
- Topic Author
04 Dec 2020 19:03 #191057
Will someone let me know when this is getting out of hand ?
The linear rails are here! So are the 150X150mm frame tubes and aluminium profiles for gantry and side mounts, L shaped aluminium for the reductions and motor mounts, control box for one of them is already finished and the second is nearly done, .......
The following user(s) said Thank You: thefabricator03, shpatb
- Other Stuff
- Show Your Stuff
Time to create page: 0.323 seconds
