- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
03 May 2020 07:17 #166478
Replied by rodw on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Can youi post a link to the Z axis?
I don't think you will gain much from a belt drive, I'd leave the rack and pinion there.
The following user(s) said Thank You: CNCFred
- Topic Author
- Online
- Thank you received: 5907
03 May 2020 09:50 #166493
2x round rail 16mm at 25cm each, 10 euro,
1x micro switch for floating, 2 euro
1x proximity sensor for home, 3 euro i think, not sure,
1x leadscrew and nut 9 euro i think
Alu parts 10 euro
screws 2 euro
so a bit over 70, here, most probably a bit cheaper wherever you are.
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
4x 16mm linear bearings at 7 euro eachWhat is the material costs without nema17? Approx!
Alu parts 10 euro
screws 2 euro
03 May 2020 09:56 #166495
Ooops, I relised afterwards the question was used at your build Tommy!
The following user(s) said Thank You: tommylight, CNCFred
03 May 2020 10:17 - 03 May 2020 10:27 #166498
by CNCFred
Replied by CNCFred on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
www.ccmrails.com/products/ball-screw-actuators-s-series/
S150D I have got
As sad I bought it from a shop here for cnc parts with no knowledge.
But I find it is worth it. For somebody with limited precision machinery! Just bolt on
My rack pinion is not spring loaded so on some positions I have a bit of backlash.
The rack was intended to be mounted spring back.. Didn't work out.
I don't want to capture this nice show off, my deepest apologies!
Well 70euro is nice for such a well done one!
S150D I have got
Last edit: 03 May 2020 10:27 by CNCFred.
The following user(s) said Thank You: tommylight, Coachbuilder
- Topic Author
- Online
03 May 2020 10:32 #166501
No worries, you are welcomed, always.I don't want to capture this nice show off, my deepest apologies!
- Topic Author
- Online
06 May 2020 19:07 #166883
- Topic Author
- Online
07 May 2020 11:01 #166956
Z axis mounted in place, now to add motion to X axis and ...... wait for the cable management ! Will have to do something temporarily, and i know there is not solution more permanent that a temporary solution, but hell i hate waiting.
Here are some more pics:
That is the Z axis home sensor and there is another switch inside for probing or floating switch.
- Topic Author
- Online
08 May 2020 18:43 #167070
- Topic Author
- Online
09 May 2020 21:38 #167179
Another quick update, the big one is nearing it's finish, needs back and side panels to be made and bolted then disassembled and sent to paint. Unfortunately no powder coating as the only colours i can choose from are black, white and some dark grey. I want none of that !
I also need to do something about the electronics enclosure, the only ones i can find here are the plain Gray ones for electrical installations at 105 Euro a piece, and i have one of those but it is a shame to put that on these machines.
Here is a quick video of it cutting air at 36m/m and rapids at 48m/m, although it can do 58 on Y axis and 66 on X axis without ever stalling. When i tighten everything up i might do another "casually hanging on the gantry" video, so stay tuned for more.
Here is the video, enjoy.
09 May 2020 23:35 #167190
Looks awesome tommy, BUt where is your beloved LAms on the Z axis. Any reason you did not use one?
- Other Stuff
- Show Your Stuff
Time to create page: 0.246 seconds
