Tool Changes
- CrazyPenguin
12 Nov 2009 20:41 - 13 Nov 2009 11:00 #1110
by CrazyPenguin
Tool Changes was created by CrazyPenguin
Hello, my name is Sebastian, i am new EMC2 user.....
I have installed UBUNTU 8.04 + EMC 2.3.0 and a Delta PLC like a distributed I/O (using Modbus).....
At the moment all system is working perfectly.......
But i need to add tool changes.......
In this particular case, on the top of z axis exist 4 spindle motors with one tool each (T1 on M1; T2 on M2; T3 on M3).......
So, i need that when a tool is selected, the position of xyz axis take it new value automaticly (pe: if T1 is selected, X0, Y0 and Z0 = x0, y0 and z0........ if T2 is selected, X0, Y0 and Z0 = x35, y50 and z-10).......
and..... i can not do it
if it is posible, i won't use G54, G55, G56.... i prefer to make a macro (using G and M codes).-
Thank you very much.-
Sebastian.-
Sebastian.-
Last edit: 13 Nov 2009 11:00 by CrazyPenguin.
