New Trajectory Planner - Testers/programs wanted
- skunkworks
- Thank you received: 148
28 Dec 2014 13:02 #54332
by skunkworks
Replied by skunkworks on topic New Trajectory Planner - Testers/programs wanted
Awesome!
Thanks Rob
Thanks Rob
Nice work! I have a fix in the works for this. The code that checks for the maximum axis accelerations didn't properly handle the case of having fewer than 3 axes. It seems to be a simple enough fix on the TP side, though I still have to look canon. I'll have it pushed to a test branch off of 2.7 in another day or two.
30 Jan 2015 09:53 #55475
by cmtunnel
Replied by cmtunnel on topic New Trajectory Planner - Testers/programs wanted
Hi guys,
Thanks for everyones' help with getting my 3-axis router running. I've milled a couple small .jpg files so far but haven't had much time to play too much. However, I have a 300 sheet order of different shapes cut from plywood coming and 3d molds for a concept car body after that. So I'm going to be doing a hell of alot machining in the months coming up. I'm hoping during this period you guys can help me get this machine screaming fast. It looks like the new trajectory planner is the way to go. Just looking for some input. Using 2.6.5 on 10.04 now. I've read a little on this thread and it looks like the tp I have now is good for only 100 ipm....is this still the case? I'll definitely need more speed than that for all this work. I think this is a good machine to test if you guys agree. thanks.
30 Jan 2015 19:54 #55483
The "classic" TP is not limited to 100ipm except by the acceleration limits of the specific machine.
Anyway, the new TP is in 2.7, and I believe that 2.7 is available from the Buildbot, even though the buildbot instructions don't mention it:
buildbot.linuxcnc.org/
Copy the 2.6 instructions but change to be 2.7 and see what happens
Replied by andypugh on topic New Trajectory Planner - Testers/programs wanted
31 Jan 2015 11:46 #55497
by cmtunnel
Ok I'll experiment with the accelerations tomorrow & see what happens. I wrote a couple of spiral programs that are point to point with a curve tolerance of .001". One of them is a regular 2d spiral and the other moves down in the z direction as it spirals out. Though this might be useful after reading through the thread. They are attached.
When I download the new 2.7 version with the updated tp will I be able to easily go back and use my current 2.6.5?
31 Jan 2015 16:12 #55499
by DaBit
Replied by DaBit on topic New Trajectory Planner - Testers/programs wanted
If you change the 2.7 back to 2.6 and run an update, you will receive 2.6 again.
The option I use is to run the regular LinuxCNC as 'installed' and the master (latest bleeding edge code) as 'Run In Place' build, compiled from sources. This allows a seamless switch between multiple versions of LinuxCNC.
But in reality all I use 2.6 for is to verify that strange behaviour is indeed a stupid user error instead of a bug. So far I have no stability or other problems running the development releases so I doubt you want to go back to 2.6 once you have 2.7 installed.
And yes, the new TP is a HUGE step forward. I am amost exclusively using curvy HSM-toolpaths, and with the new TP it is absolutely no problems to push 100Kbytes of awful CAM-generated short-segment G-code through the interpreter/motion controller in 5 minutes of milling.
31 Jan 2015 21:41 #55506
by cmtunnel
Ok, that sounds good. I have no idea how to set up 2.7 as 'run in place'. Will the info. earlier in this thread get me there? If not could you point me in the right direction? I hate to be so needy here but my time is limited right now and if I can get it running at 100ipm that will do for a little while. I'll get back to the 2.7 issue tonight though. Thanks for the help.
31 Jan 2015 22:16 #55508
by DaBit
I would do as Andy said and use the buildbot first: a lot less hassle if you are tight on time and I doubt you need to go back to 2.6. It won't be long before they release 2.7 officially anyway.
Thus:
- Open a terminal window
- Do a 'sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key E0EE663E' in that terminal window
- Do a 'sudo gedit /etc/apt/sources.list.d/linuxcnc-buildbot.list' and change a reference to 2.6 which is already there to 2.7. If there is none, add these two lines at the end of the file:
deb buildbot.linuxcnc.org/ lucid 2.7-rt
deb-src buildbot.linuxcnc.org/ lucid 2.7-rt
- Then save and exit gedit.
- Still in the terminal window do 'sudo apt-get update'
- Do a 'sudo apt-get install linuxcnc'
- Done.
The quotes (') above are not part of the commands and just there to separate the command from the rest of the text. Type/copy the commands without these quotes.
If you want to revert back to 2.6 do the same, but change 2.7 to 2.6 when editing the linuxcnc-buildbot.list file.
Now, I think the new TP uses reasonable defaults, but in case you might want to play: I have this configuration in my INI file:
[TRAJ]
AXES = 4
COORDINATES = X Y Z A
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 0
ARC_BLEND_OPTIMIZATION_DEPTH = 480
ARC_BLEND_GAP_CYCLES = 4
ARC_BLEND_RAMP_FREQ = 200
Both the optimization depth and ramp freq are a lot higher than default, but as I said: I am mostly running curvy toolpaths, I have fairly speedy axes (18 meters/minute) with high acceleration (2500-5000mm/s^2), a high servo thread rate (8kHz) and I need to keep the cutter cutting so heat goes into the chips and not into the endmill/workpiece when doing HSM-style toolpaths.
Thus:
- Done.
[TRAJ]
AXES = 4
- skunkworks
07 Feb 2015 07:45 #55761
by skunkworks
I had forgotten to update this. Rob has fixed this issue (x-y only machines violating constraints) and a few others. It will be in the next 2.7 pre-release. (maybe this weekend)
or you can pull the branch - it is on git.linuxcnc.org
feature/spiral-arc-handling-2.7
sam
sam
11 Mar 2016 14:56 #71407
by db1981
Replied by db1981 on topic New Trajectory Planner - Testers/programs wanted
Hello,
i have a few mistakes with milling circles. My cam (CamBam) divides full circles into segments, so an circle consists of 3-4 Arcs.
Now with LinuxCNC 2.7, i have the problem that the machine everytime at the end of the first segment slows down.
But the following Circle Segments would be driven right, all together without slow down.
I have tested this with G64 and P from 2 to 0.05, its all the same.
this is the gcode:
If you delete the line "G1 F300.0 Z-3.0" , all segments would be driven as one circle without slow down.
Any suggests?
Regards DB
this is the gcode:
G21 G17 G90 G64 P0.05 G40
G0 Z3.0
T1 M6
M3 S1000
G0 X556.0 Y-300.0
G1 F300.0 Z-3.0
G3 F3000.0 X172.0 Y-78.2975 I-256.0 J0.0
G3 Y-521.7025 I128.0 J-221.7025
G3 X556.0 Y-300.0 I128.0 J221.7025
G0 Z3.0
M5
M30
Any suggests?
Regards DB
- skunkworks
11 Mar 2016 16:06 #71418
by skunkworks
I am seeing the behavior here. It seems to exact stop between the first 2 arc. (and removing the Z move fixes makes it not stop)
I will ping rob and see if he has some time to look at it.
sam
sam
The following user(s) said Thank You: db1981
