ubuntu 10.04 Lcnc2.7 JA8 custom kins
18 Nov 2015 16:20 - 18 Nov 2015 16:23 #65443 by bkt
Replied by bkt on topic ubuntu 10.04 Lcnc2.7 JA??
k-1's Avatar
@ ANdyPugh .... in motion not have jog.select pin .....
I summarize: i
in joint mode->
halui.mode.is-teleop off
halui.jog.0.increment -257 (go to negative)
halui.jog.selected.increment 0.01
joint.0.wheel-jog.active on
joint.0.jog.scale xxx(not remember
joint.0.jog.enable on
joint.0.jog.increment -257 ALL WORKS 1JOINT AT TIME
in world mode->
halui.mode.is-teleop on
joint.0.jog.increment -257 AXIS/JOINT IS STOP WITH EXTERNAL MPG. With axis button all works!!
@Andypugh as you see I have joint.0.jog.enable on joint.0.jog.scale == selected.increment halui.jog.selected.increment 0.01 halui.jog.0.increment -257 (the value depends of movement of encoder wheel..)
If I try these:
setp    axis.0.jog-vel-mode 0   (axis or joint depends if I use JA8 or Lcnc2.7 --- this is Lcnc code)
net selected-jog-incr    =>  axis.0.jog-scale (selected-jog-incr depends of mux4 0.001/0.004/0.012)
net joint-select-a       =>  axis.0.jog-enable   <=  hm2_5i25.0.7i77.0.0.input-16
net joint-selected-count =>  axis.0.jog-counts  (joint-selected-counts depends of encoder count mesa pin)
#******OR IN JA8************************
setp    joint.0.jog-vel-mode 0   (axis or joint depends if I use JA8 or Lcnc2.7 --- this is JA8 code)
net selected-jog-incr    =>  joint.0.jog-scale (selected-jog-incr depends of mux4 0.001/0.004/0.012)
net joint-select-a       =>  joint.0.jog-enable   <=  hm2_5i25.0.7i77.0.0.input-16
net joint-selected-count =>  joint.0.jog-counts  (joint-selected-counts depends of encoder count mesa pin)
I can make jog in joint mode but not in world mode .... the same in JA8 too .... What is wrong
Giorgio
Last edit: 18 Nov 2015 16:23 by bkt.
18 Nov 2015 18:14 #65452 by bkt
that fool I am .... I can not give the same jog.count all axes if I want interpolate us.... but I'll probably give jog.enable to all or maybe not . And this true?
18 Nov 2015 19:57 #65457 by andypugh
Replied by andypugh on topic ubuntu 10.04 Lcnc2.7 JA??
Actually, I think you can.
Each individual axis looks at the change in jog counts when it is enabled for jogging, rather than absolute jog counts.
18 Nov 2015 21:22 - 18 Nov 2015 21:29 #65460 by bkt
double response
Last edit: 18 Nov 2015 21:29 by bkt.
18 Nov 2015 21:29 - 18 Nov 2015 21:34 #65463 by bkt
I can?? than there are no reason because this code doesn't work in world mode with delta kins:
setp  joint.0.jog-scale  0.001
net MPG-encoder-count  hm2_5i25.0.7i77.0.0.encoder.5.count  =>  joint.0.jog-counts
Is right?
But in joint mode works fine ..... swithc to world mode and the axis stop .... I move the hand wheel whitout any result ...than I switch again to joint mode and the axis litterally JUMP for an amount of position than not move in world mode.
Giorgio
Last edit: 18 Nov 2015 21:34 by bkt.
19 Nov 2015 08:52 #65488 by bkt
today I try with other kinematics customisation....
19 Nov 2015 10:07 #65490 by andypugh
I am setting up a JA system on my new controller.
So far with the normal 2.7 version I can confirm your joint-mode but not world-mode jogging experience.
The following user(s) said Thank You: bkt
19 Nov 2015 11:50 - 19 Nov 2015 11:54 #65492 by bkt
ok .... Today I make all the necessary pin to make a jog in world mode in deltakinematics with handwheel ... ... very funny .... the macanism:
if is-teleop & is-manual & selected-axis is ON condition than set encoder.reset to 0 and add encoder-count/selected-increment convert to float in these way : emcpose * pos->tran--selected axis + encoder-value......
int kinematicsInverse(const EmcPose * world,
		      double * joints,
		      const KINEMATICS_INVERSE_FLAGS *iflags,
		      KINEMATICS_FORWARD_FLAGS *fflags)
    double x0, y0, z0, theta1, theta2, theta3;
    int status;
if ( condition ....)
     {x0 = world->tran.x + encoder-value (for example);}
else if (condition ....)
    { y0 = world->tran.y+ encoder-value (for example);}
else {
      x0 = world->tran.x;
      y0 = world->tran.y;
     z0 = world->tran.z;
     joints[3] = world->a;
     joints[4] = world->b;
     joints[5] = world->c;
     joints[6] = world->u;
     joints[7] = world->v;
     joints[8] = world->w;
     theta1 = theta2 = theta3 = 0;
     status = delta_calcAngleYZ(x0, y0, z0, &theta1);
obviusly when the is-teleop & is-manual & selected
axis than condition is OFF emcpose*pos return immediately to original value .... how to add definitively some value in kinematics to emcpose*pos? Appreciate any link to study the situation.
I try to add the code on foward kins .... dro show the modified new quote but nothing move. Than I put the code on inverse kins....
Tanks
Regards
giorgio
Last edit: 19 Nov 2015 11:54 by bkt.
19 Nov 2015 12:05 #65493 by andypugh
Kinematics really is not the place to do this.
It needs to be in motion. (if for no other reason that otherwise the limits will not work).
19 Nov 2015 12:38 - 19 Nov 2015 12:44 #65494 by bkt
you are in right ... but when I see motion.c I see a lot of pin that send to hal ...... so I can add the encoder value from inverse kins to hal file joint.N.motor-pos-fb ?? is possible?? Or must rearrange motion code for add to my system in motion ? then who assures me that he sends the values ​​to the inverse kinematics ? now in effect it does not!
in any case are not such a good programmer to get by with a couple of hours of work for this ..... I tried the way kinematics .... I know the file (which is quite simple ) and just do the My changes ......
Last edit: 19 Nov 2015 12:44 by bkt. Reason: find last question by me
Time to create page: 0.641 seconds
