12axis Step output
- marq_torque
- Topic Author
03 Apr 2016 07:49 #72607
by marq_torque
12axis Step output was created by marq_torque
Hello all members,
i have came across one application which requires 12Axis or more. have seen many Chinese PCI cards doing it, application is jewellery making. can anyone throw light how to add more axis in config ?? no kinematics needs just numerical stop n go would do. have tested upto 5axis on par-port.
Much thanks in advance.
Regards .
Ankit
Regards .
Ankit
03 Apr 2016 16:55 #72632
by cncbasher
Replied by cncbasher on topic 12axis Step output
Linuxcnc can do 9 axis , in cartiesen space , in world mode you'd get probably 12 , over that you would probably need to modify sources , but i cant see even jewellery needing more than 6 .
The following user(s) said Thank You: marq_torque
- marq_torque
- Topic Author
03 Apr 2016 17:40 #72635
by marq_torque
Replied by marq_torque on topic 12axis Step output
Thanks Mod,
Here is machine i am thinking of, >>
I need sub spindle axis and separate cutting tools. and apart from jewelery there is one spring forming application i am thinking of.
About modifying sources. i don't know i am very beginner recently switched from mach. still fighting for locating kinematics module in 2.7.4 Debian thats parallel story, not succeed yet.
if you could give any hint where to start from.
Thanks Again.
Ankit Mistry
Thanks Again.
Ankit Mistry
- marq_torque
- Topic Author
03 Apr 2016 19:04 #72640
by marq_torque
Tried Adding more axis to stock stepper Config received this message. Suggestion ?
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/motmod.ko: Operation not permitted
./stepper_xyza.hal:7: exit value: 1
./stepper_xyza.hal:7: insmod for motmod failed, returned -1
See the output of 'dmesg' for more information.
30115
PID TTY STAT TIME COMMAND
30115 ? R+ 0:00 [linuxcncsvr]
Stopping realtime threads
Unloading hal components
Error: Module motmod is not currently loaded
<commandline>:0: exit value: 1
<commandline>:0: rmmod failed, returned -1
<commandline>:0: unloadrt failed
Regards,
Ankit Mistry
30115
Regards,
Ankit Mistry
03 Apr 2016 19:16 - 03 Apr 2016 19:16 #72641
Replied by PCW on topic 12axis Step output
If the additional axis do not need coordinated movement (or standard Gcode control),
indexing motion can be done by using the limit3 component and a stepgen
Perhaps using M67/68 for position commands
Homing would need to be handled in the hal file
Last edit: 03 Apr 2016 19:16 by PCW.
- marq_torque
- Topic Author
03 Apr 2016 19:21 #72644
by marq_torque
Coordinated movement is needed.... like jog and follow
- marq_torque
- Topic Author
03 Apr 2016 22:45 #72659
by marq_torque
Ended with Error loading motmod.ko,
./9ax.hal:5: exit value: 1
./9ax.hal:5: insmod for motmod failed, returned -1
4130
One Hint
[ 129.429879] RTAI[math]: loaded.
[ 129.554451] MOTION: num_joints is 12, must be between 1 and 9
[ 131.750218] RTAI[math]: unloaded.
Now question is how to modify Math or stepgen.c file ??
i tested with 9axis configuration it has to work and it worked since it says joint must be between 1-9 number
Regards,
Ankit Mistry
4130
One Hint
Regards,
Ankit Mistry
- marq_torque
- Topic Author
04 Apr 2016 09:05 - 04 Apr 2016 09:10 #72688
by marq_torque
Is there any possibility to modify emcmotcfg.h file ?? and which other files need to be modified ??
Edit: I have tried simply copy paste edited file in motion folder, previous debug message is after that editing and editing havent made any change in error. i mean changing number of maximum joints isnt make any difference by simple editing. am i missing anything.??
* Description: emcmotcfg.h
* Default values for compile-time parameters.
* Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2004 All rights reserved.
* Last change:
#ifndef EMCMOTCFG_H
#define EMCMOTCFG_H
/* default name of EMCMOT ini file */
#define DEFAULT_EMCMOT_INIFILE "emc.ini" /* same as for EMC-- we're in
touch */
/* number of joints supported
Note: this is not a global variable but a compile-time parameter
since it sets array sizes, etc. */
#define EMCMOT_MAX_JOINTS 12 This Value was 9
/* number of axes defined by the interp */ //FIXME: shouldn't be here..
#define EMCMOT_MAX_AXIS 12 This value was 9
#define EMCMOT_MAX_DIO 64
#define EMCMOT_MAX_AIO 64
#if (EMCMOT_MAX_DIO > 64) || (EMCMOT_MAX_AIO > 64)
#error A 64 bit bitmask is used in the planner. Don't increase these until that's fixed.
#endif
#define EMCMOT_ERROR_NUM 32 /* how many errors we can queue */
#define EMCMOT_ERROR_LEN 1024 /* how long error string can be */
Shared memory keys for simulated motion process. No base address
values need to be computed, since operating system does this for us
#define DEFAULT_SHMEM_KEY 100
/* default comm timeout, in seconds */
#define DEFAULT_EMCMOT_COMM_TIMEOUT 1.0
/* seconds to delay between comm retries */
#define DEFAULT_EMCMOT_COMM_WAIT 0.010
/* initial velocity, accel used for coordinated moves */
#define DEFAULT_VELOCITY 1.0
#define DEFAULT_ACCELERATION 10.0
/* maximum and minimum limit defaults for all axes */
#define DEFAULT_MAX_LIMIT 1000
#define DEFAULT_MIN_LIMIT -1000
/* size of motion queue
* a TC_STRUCT is about 512 bytes so this queue is
* about a megabyte. */
#define DEFAULT_TC_QUEUE_SIZE 2000
/* max following error */
#define DEFAULT_MAX_FERROR 100
#endif
Have also used modified stepgen.c but i think in 2.8Dev its by default 16channel output and no need to add stepgen.c thanks to Big_johnT
Regards,
Ankit Mistry
* Author:
* System: Linux
* Last change:
#ifndef EMCMOTCFG_H
#define EMCMOTCFG_H
touch */
#endif
#endif
Regards,
Ankit Mistry
Last edit: 04 Apr 2016 09:10 by marq_torque. Reason: Proper description
04 Apr 2016 12:56 #72710
It can't be done.
Think about this from the point of view of G-code. How are you going to command a move in axes 10, 11 or 12? There are no G-code letters available.
You can move any number of actuators independently at fixed speed from HAL, but no more than 9 axes can perform simultaneous coordinated movements.
Replied by andypugh on topic 12axis Step output
It can't be done.
- marq_torque
- Topic Author
04 Apr 2016 17:48 #72730
by marq_torque
Alright Andy, i was in confusion that which letter will specify 10..11..12th axis ... as far as my study says there is no any other axis letter left. and finally ended with answer that its just customized IO, people market it as a 12axis. at a time mostly 4or 5 axis will be in simultaneous movement.
Now trying to workout 9axis on board. thanks for all of your inputs thanks a ton
Regards,
Ankit Mistry
Regards,
Ankit Mistry
Time to create page: 0.111 seconds
