ESC Brushless MESA PWM 6i25+7i76
08 Mar 2017 00:55 - 08 Mar 2017 00:56 #89185
Replied by PCW on topic ESC Brushless MESA PWM 6i25+7i76
Hmm, looks like I made a custom bitfile for 7I76 with just one 1 PWM per card (where stepgen 4 usually goes)
freeby.mesanet.com/5i25_7i76x2_1P.bit
Last edit: 08 Mar 2017 00:56 by PCW.
The following user(s) said Thank You: HalaszAttila
- HalaszAttila
- Thank you received: 5
09 Mar 2017 06:55 #89239
by HalaszAttila
Replied by HalaszAttila on topic ESC Brushless MESA PWM 6i25+7i76
I forgot to tell, i use 7i92 ethernet board with 7i76 card.
09 Mar 2017 10:40 #89244
Replied by andypugh on topic ESC Brushless MESA PWM 6i25+7i76
You can probably run your ESC using a stepgen. You need to set it to velocity mode to get a fixed-frequency output to suit the ESC then alter the step-length to give the required pulse length.
However: The pulse-length is a HAL _parameter_ not a pin, so can't be directly connected in HAL. You would need to use (as an example) a custom M-code that issues a "halcmd setp hm2_7i92.0.stepgen.04.step-length NNN" command.
- HalaszAttila
09 Mar 2017 18:36 #89278
by HalaszAttila
Thanks, I solved with this way. I use fix PWM duty cycle, because this is a braking mechanism for turret on lathe.
Time to create page: 0.078 seconds
