About Teach-in Script
- marq_torque
- Topic Author
06 May 2016 06:28 #74287
by marq_torque
About Teach-in Script was created by marq_torque
Hello all Mods and Members,
I have recently setup for 9Axis Special purpose Spring machine, i came across Teach-In Python script which is used for teaching. so now i am confused how to utilize in 2.7.4 version as i am not able to find any directory or file as stated in git where its located. also blank that how it works. i am feeling totally noob at this point.
Any one throw some light please. my concept is to jog and put that axis and its value entry in program/file directly by a click of button.
Thanks in advance,
Ankit
Thanks in advance,
Ankit
- marq_torque
- Topic Author
06 May 2016 17:35 #74310
by marq_torque
Replied by marq_torque on topic About Teach-in Script
No one here ?? with help of Teach-in.py script ?
06 May 2016 17:47 #74312
by dgarrett
Replied by dgarrett on topic About Teach-in Script
For a rip build, the file is:
your_git_top_dir/src/emc/usr_intf/axis/scripts/teach-in.py
but it is not made available as an executable in a deb install
for 2.7.x -- probably just forgotten, you could file a bug
report
It is made available in the joints_axes13 branch at
/usr/bin/teach-in
report
/usr/bin/teach-in
The following user(s) said Thank You: marq_torque
- marq_torque
- Topic Author
06 May 2016 19:34 #74316
by marq_torque
Thanks for your input dgarrett,
can you clear some of points... as your answer is totally bouncer to me. all i got it its not included in 2.7.x, now i am confused at what is "joints_axes13 branch" and how old script used to work with emc ? and is there any way i can compile in new version ? like kinematics ? as i am only familiar to work with .hal .ini and kinematics files only.
Thanks Again
Ankit
Thanks Again
Ankit
06 May 2016 19:54 #74317
by dgarrett
teach-in.py is a python script so you could download the blob and just use it
make it executable (chmod 755 teach-in.py)
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...47;hb=refs/heads/2.7
joints_axes13 is a developmental branch
- marq_torque
- Topic Author
07 May 2016 05:51 #74328
by marq_torque
hello dgrrett,
i checked link, i am so noob to know how to download? i have copied all lines and put in empty file. and removed numbers. is there any straight way to download ? am i missing anything ? and how to execute ? guide me Sir,
Regards,
Ankit
Regards,
Ankit
- marq_torque
- Topic Author
07 May 2016 06:12 #74329
by marq_torque
I was playing with script. loaded as a Gcode and it opened a dialogue box with joint and world mode, i am able to capture position but not axes name ! how to get it done ?
Any input ?
Regards,
Ankit
Any input ?
Regards,
Ankit
08 May 2016 12:57 - 08 May 2016 13:00 #74376
by BigJohnT
Replied by BigJohnT on topic About Teach-in Script
The axes are in the order of X Y Z A B C U V W so if you have a 3 axis mill for example the numbers from left to right are X Y Z. The four numbers after the axes positions are flood, mist, lube and spindle enabled. You can run teach-in.py after starting LinuxCNC. Starting teach-in without a file name the saved position just go to standard out.
JT
JT
Last edit: 08 May 2016 13:00 by BigJohnT.
- marq_torque
- Topic Author
08 May 2016 13:04 #74377
by marq_torque
Thanks BigJohnT,
Where the saved file is located ?? I couldn't find it. Also there is 0 0 1 0 output in each line.
I want to modify little manually after teaching.
Regards,
Ankit
Regards,
Ankit
- marq_torque
- Topic Author
08 May 2016 13:19 #74378
by marq_torque
I have modified script to get G01 and corresponding axes letter. But not able to remove trailing 0 0 1 0 ... also Not sure where the file is saved i can see loaded program with saveral errors only !
Also need to add % before first line and after last line.
For routine use its headache to modify file everytime.
Time to create page: 0.150 seconds
