Manual speed control using XHC-HB04 pendant
- javanree
17 Aug 2016 18:51 #78955
by javanree
Manual speed control using XHC-HB04 pendant was created by javanree
I am running a small 3040 mill as a 3-axis machine using LinuxCNC 2.7.6 on Wheezy
I've hooked up an XHC-HB04 (wired) pendant over USB and most functions are working perfectly
There's only one thing I'd like to be able to change :
When in manual mode I can start and stop the spindle, but I'd like to be able to switch the rotary to 'spindle' and then use the jog wheel to increase / decrease spindle speed and ultimately also not see a spindle RPM percentage in the display but the set spindle RPM (I'm using PWM on LPT pin 17 to control the spindle, no feedback. Minimum RPM is set to 3000 rpm in the configuration)
Is this even possible?
- Thank you received: 4646
17 Aug 2016 23:23 #78964
It doesn't seem impossible, but it might take some effort.
I think I would do it with a simple custom HAL component that watches xhc-hb04.jog.counts and xhc-hb04.enable-spindle-override, latching the counts and setting an output to 3000 when the enable-spindle-override pin goes to true, and then increasing the output speed command as the counts increase.
You could do it all with existing HAL components, but it would get a bit involved.
Replied by andypugh on topic Manual speed control using XHC-HB04 pendant
- javanree
19 Aug 2016 07:39 #79039
by javanree
Replied by javanree on topic Manual speed control using XHC-HB04 pendant
Thanks for the suggestions
Looks like I have some studying on HAL to do
Will post if I've made any progress
