[solved] module scarakins do not exist in ......
01 Sep 2016 18:01 - 02 Sep 2016 08:19 #79858
by bkt
[solved] module scarakins do not exist in ...... was created by bkt
In order to try solve my scara issue I've modified scarakins ..... I've only insert numeric PI value instead PM_PI ... save as .... new name ...
sudo halcompile --install myscarakins.c ... copy myscarakins.ko in JA rtailib folder .... . rip environment ... linuxcnc .... so obtain these strange error .....
Is not I firs time that compile a new kins .... sometinghs is wrong??
giorgio
UPDATE .... sorry my big mistache ... when I make a copy of my new kins in JA rtailib folder I cancel the old one ........ maybe because I mistakenly edited directly the version in the JA folder ... but I had not noticed .... I copied today scarakins.ko in rtailib of JA and everything worked well ... .
Regards
giorgio
giorgio
Regards
giorgio
Last edit: 02 Sep 2016 08:19 by bkt.
02 Sep 2016 19:37 #79926
Replied by andypugh on topic [solved] module scarakins do not exist in ......
I _think_ that if you halcompile the kins in the same console as you . ./rip-environment in, then it gets put in the right place
Time to create page: 0.191 seconds
