encoder on step/dir system
- steva
07 Sep 2016 16:12 #80127
by steva
encoder on step/dir system was created by steva
Hello,
I have a configuration of the servo motor in position loop ( step / dir ) .
I connected servo drive encoder output to Mesa 7i77 encoder input.
I want to compare encoder.xx.position and axis.x.joint-pos-cmd.
I would like to receive a warning when the difference exceeds a certain predetermined level ( something like the following error ) .
Does anyone have something like this ?
- bkt
- Thank you received: 114
07 Sep 2016 17:03 #80135
by bkt
Replied by bkt on topic encoder on step/dir system
I'm not an expert but is possible to connect step/dir signal to mesa 7i77?
anyhow following error depends on Ferror parameter, if you have ferror parameter too little you obtain following error .... LCNC control step/dir by mesa 7i77 or by other input ??
Regards
Giorgio
Regards
Giorgio
- Thank you received: 4626
07 Sep 2016 20:27 #80170
LinuxCNC already does this for you. All you need is for your HAL to connect the encoder feedback to axis.N.position-cmd-fb
However, it doesn't really want you, it stops all motion and turns the machine off.
If you want a pre-warning, then the HAL "wcomp" component can help. Possibly combined with the HAL "message" component.
Is that enough? Just ask, if not.
Replied by andypugh on topic encoder on step/dir system
- steva
08 Sep 2016 07:29 #80209
by steva
Replied by steva on topic encoder on step/dir system
I can not find "axis.N.position-cmd-fb".
My fb signal in Axis is already used:
net x-pos-fb <= hm2_5i25.0.stepgen.00.position-fb => axis.0.motor-pos-fb
08 Sep 2016 08:30 #80210
Sorry. That's the pin.
I was working from memory (I am working inTurkry, a long way from my CNC machines)
Time to create page: 0.080 seconds
