Servo Tuning Help
23 Oct 2016 20:46 #81973
by bevins
Servo Tuning Help was created by bevins
Hi all,
I am having trouble getting my servo's tuned especially the slaved Y to A.
What I did was up the P until it stats to oscillate. Then I go back on the P until it stops oscillating. Then I have it like in the pic. But whatever I do, I cannot get the f-error to straight.
The other drives are much worse.
I tried, raising ff1, and it distorts the oscillating, but never can get it to go away.
- Thank you received: 1370
24 Oct 2016 02:07 #81978
Replied by Todd Zuercher on topic Servo Tuning Help
I'd say that is still too much P, back it off until the oscillation is minimized during the movement, as well. Then set FF1 to minimize flowing error.
24 Oct 2016 16:00 #81991
Replied by andypugh on topic Servo Tuning Help
Do you have an I-Gain?
25 Oct 2016 20:24 - 25 Oct 2016 20:38 #82057
by bevins
Yes, This is on the X and it has to be - or it goes a bit crazy.
Replied by bevins on topic Servo Tuning Help
Last edit: 25 Oct 2016 20:38 by bevins.
25 Oct 2016 20:27 - 25 Oct 2016 20:49 #82058
by bevins
Last edit: 25 Oct 2016 20:49 by bevins.
25 Oct 2016 20:50 #82061
by bevins
These are KRS drives, I have removed the option of the drives handling internal pid, so it is sending out to Linuxcnc the encoder and linuxcnc is handling the PID.
25 Oct 2016 20:53 #82062
by bevins
27 Oct 2016 19:13 #82156
by bevins
Anyone have an at_pid config I can look at?
27 Oct 2016 19:45 - 27 Oct 2016 19:46 #82157
Replied by PCW on topic Servo Tuning Help
Are the drives programmed for velocity or torque mode operation?
(if torque mode, you will likely need to run a faster servo thread to get decent performance)
Last edit: 27 Oct 2016 19:46 by PCW.
27 Oct 2016 20:36 #82158
Peter, brings up a very good point. You said earlier that you disabled the drives PID. That may have been a mistake, if you disabled the drives velocity loop. Without that the drive would be operating in "torque mode" where the analog input would be a force command. This is much more difficult to tune in Linuxcnc that the usual velocity command. But to have a velocity control the drive needs to have some kind of feedback loop that needs to be tuned. You may need to study the manuals for your drives a bit more.
Time to create page: 0.338 seconds
