PID Setting for drifting axis
21 Nov 2016 12:05 #83060
by Chre9
Replied by Chre9 on topic PID Setting for drifting axis
We just changed the output scale to -10 and everything works out perfectly.
Thanks for your help!!
We also added all the soft stop configuration without problems and a hand device that includes a turning wheel
and a switch to select the axis.
Now we also want to add a plus and a minus button to drive the axis, but don't know which output we have to connect to the signals of the buttons. Thanks in advance!
21 Nov 2016 13:19 #83071
Replied by andypugh on topic PID Setting for drifting axis
Have a look in halui. I think that is where the jog-plus and jog-minus pins live.
25 Nov 2016 12:54 #83269
by Chre9
Alright, we figured out, that we can either use
net jog-x-pos halui.jog.0.plus <= hm2_5i20.0.gpio.054.in_not
net jog-x-neg halui.jog.0.minus <= hm2_5i20.0.gpio.056.in_not
or
net jog-selected-pos halui.jog.selected.plus <= hm2_5i20.0.gpio.054.in_not
net jog-selected-neg halui.jog.selected.minus <= hm2_5i20.0.gpio.056.in_not
to jog the axis. Is that right?
The signals can be set true, by pushing the buttons, but the machine doesn't do anything.
Do we have to enable halui in some way?
Thanks in advance!
or
Thanks in advance!
25 Nov 2016 13:25 #83270
The choice of jog.selected or jog.N depends on whether yo have buttons per-axis or a selector.
Are you setting the halui.jog-speed pin? If that is zero you will jog at zero speed, which might be indistinguishable from not jogging at all.
The following user(s) said Thank You: Chre9
27 Nov 2016 19:34 - 27 Nov 2016 19:34 #83382
by Chre9
Thanks, that makes sense
One last thing we would like to add is a button, that makes the selected axis drive faster, while pressed.
Is there a pin for this? Otherwise, what's the best way to action it?
Regards!
Regards!
Last edit: 27 Nov 2016 19:34 by Chre9.
29 Nov 2016 12:52 #83426
Often you set the jog speed using a mux-component.
One example is here, in section 5:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
The mux4 is set up to pass one of 4 possible speeds to the jog-speed input. In the case shown, for safety, one speed is zero.
That example uses the or2 component to get 3 speeds + 0 from the mux4 with 3 buttons. A simpler setup just uses the mux and the button inputs to give slow for one button, fast for the other, and very fast for both. I used this setup on a joypad on the two rear buttons and it worked very nicely.
linuxcnc.org/docs/2.7/html/man/man9/mux4.9.html
01 Dec 2016 13:29 #83520
by Chre9
We used a mux2 function for either button pressed, or not pressed:
net speed_mode hm2_5i20.0.gpio.058.in_not => mux2.0.sel
setp mux2.0.in1 200
setp mux2.0.in0 20
net jog-speed halui.jog-speed <= mux2.0.out
Works perfectly, thank you!
setp mux2.0.in1 200
setp mux2.0.in0 20
Time to create page: 0.296 seconds
