- Configuring LinuxCNC
- Advanced Configuration
- custom kinematics causes joint following errors depending on speed
- alexfloca
09 Dec 2016 00:07 #83818
by alexfloca
custom kinematics causes joint following errors depending on speed was created by alexfloca
I have developed a custom kinematics module for a 5 axis router with a rotating-tilting head and rotary axis position error compensation.
Every thing works just fine if I jog the machine up to approx 1.400 mm/min in world mode. In joint mode, I can jog any axis up to the maximum speed of 15000 mm/min. As soon as I increase the jog speed in world mode over the 1400 mm/min, I get a following error in the axis I jog.
From the linuxcnc point of view we are talking about a basic stepper configuration using the parport driver.
I tried optimizing the trigonometry calculations with no luck, no increase in jog speed. I even tried commenting out the whole trigonometric calculations (having this custom kinematics module act similar to trivkins) with no luck, same maximum jog speed. The only thing that works is increasing the MIN_FERROR and FERROR for every axis in the .ini file.
Any ideeas where this limitation/error can come from?
I am using linuxcnc 2.7.8, kinematics as follows:
#include "kinematics.h" /* these decls */
#include "posemath.h"
#include "hal.h"
#include "rtapi.h"
#include "rtapi_math.h"
#define d2r(d) ((d)*PM_PI/180.0)
#define r2d(r) ((r)*180.0/PM_PI)
struct haldata {
hal_float_t *tool_length;
hal_float_t *pivot_length;
} *haldata;
static PmCartesian s2r(double r, double t, double p ) {
PmCartesian c;
double dx = 0.65;
double dy = 0.05;
double dxdx = 0.4225;
double dydy = 0.0025;
t = d2r(t), p = d2r(p);
double cosp = cos(p);
double sinp = sin(p);
double dydx = 0.0769230769;
double t1 = sqrt(dxdx*cosp*cosp + dydy);
double t2 = t + atan(dydx/cosp); //dy/dx
c.x = t1*cos(t2) - r * sinp*cos(t);
c.y = t1*sin(t2) - r * sinp*sin(t);
c.z = -(dx*sinp+r*cosp);
return c;
int kinematicsForward(const double *joints,
EmcPose * pos,
const KINEMATICS_FORWARD_FLAGS * fflags,
KINEMATICS_INVERSE_FLAGS * iflags)
PmCartesian r = s2r(*(haldata->pivot_length)+*(haldata->tool_length), joints[5], joints[4]);
pos->tran.x = joints[0] + r.x;
pos->tran.y = joints[1] + r.y;
pos->tran.z = joints[2] + r.z;
pos->a = joints[3];
pos->b = joints[4];
pos->c = joints[5];
pos->u = joints[6];
pos->v = joints[7];
pos->w = joints[8];
return 0;
int kinematicsInverse(const EmcPose * pos,
double *joints,
const KINEMATICS_INVERSE_FLAGS * iflags,
KINEMATICS_FORWARD_FLAGS * fflags)
PmCartesian r = s2r(*(haldata->pivot_length)+*(haldata->tool_length), pos->c, pos->b);
joints[0] = pos->tran.x - r.x;
joints[1] = pos->tran.y - r.y;
joints[2] = pos->tran.z - r.z;
joints[3] = pos->a;
joints[4] = pos->b;
joints[5] = pos->c;
joints[6] = pos->u;
joints[7] = pos->v;
joints[8] = pos->w;
return 0;
/* implemented for these kinematics as giving joints preference */
int kinematicsHome(EmcPose * world,
double *joint,
*fflags = 0;
*iflags = 0;
return kinematicsForward(joint, world, fflags, iflags);
KINEMATICS_TYPE kinematicsType()
return KINEMATICS_BOTH;
#include "rtapi.h" /* RTAPI realtime OS API */
#include "rtapi_app.h" /* RTAPI realtime module decls */
#include "hal.h"
EXPORT_SYMBOL(kinematicsType);
EXPORT_SYMBOL(kinematicsForward);
EXPORT_SYMBOL(kinematicsInverse);
MODULE_LICENSE("GPL");
int comp_id;
int rtapi_app_main(void) {
int result;
comp_id = hal_init("5axecomp");
if(comp_id < 0) return comp_id;
haldata = hal_malloc(sizeof(struct haldata));
result = hal_pin_float_new("5axe.tooloffset.z", HAL_IN, &(haldata->tool_length), comp_id);
if(result < 0) goto error;
result = hal_pin_float_new("5axe.pivot-length", HAL_IO, &(haldata->pivot_length), comp_id);
*(haldata->pivot_length) = 161.0;
hal_ready(comp_id);
return 0;
error:
hal_exit(comp_id);
return result;
void rtapi_app_exit(void) { hal_exit(comp_id); }
#include "hal.h"
#include "rtapi.h"
struct haldata {
} *haldata;
PmCartesian c;
double dx = 0.65;
double dy = 0.05;
return c;
EmcPose * pos,
pos->a = joints[3];
pos->b = joints[4];
pos->c = joints[5];
pos->u = joints[6];
pos->v = joints[7];
pos->w = joints[8];
return 0;
double *joints,
joints[3] = pos->a;
joints[4] = pos->b;
joints[5] = pos->c;
joints[6] = pos->u;
joints[7] = pos->v;
joints[8] = pos->w;
return 0;
double *joint,
*fflags = 0;
*iflags = 0;
#include "hal.h"
int comp_id;
int result;
hal_ready(comp_id);
return 0;
error:
hal_exit(comp_id);
return result;
- alexfloca
09 Dec 2016 00:24 #83819
by alexfloca
Replied by alexfloca on topic custom kinematics causes joint following errors depending on speed
just tested using rotatekins and not my custom kinematics module, very same results, same critical feedrate where following error occures.
- Thank you received: 5246
09 Dec 2016 01:28 #83820
Replied by PCW on topic custom kinematics causes joint following errors depending on speed
can you post your hal and ini files?
- alexfloca
09 Dec 2016 06:31 #83828
by alexfloca
those are the hal and ini files for my test configuration, stripped down to a minimum, no limit switches as no physical machine is connected to this test configuration
09 Dec 2016 18:01 #83833
With a quick look, I dont see anything obviously wrong there
If you widen your ferror limits and plot ferror in halscope when you jog
it may give a clue to why things are going wrong
- Thank you received: 4636
10 Dec 2016 01:38 #83871
Replied by andypugh on topic custom kinematics causes joint following errors depending on speed
I suspect that the problem is due to you not having a [TRAJ]DEFAULT_ACCELERATION
linuxcnc.org/docs/2.7/html/config/ini-config.html#_traj_section
Also, your [TRAJ]MAX_VELOCITY seems to be a bad match to the axis velocities.
(I realise that it is not at all clear how these settings all interact. And I am not in a position to fix that, I don't know either)
- alexfloca
11 Dec 2016 21:59 #83927
by alexfloca
Hi Andy,
[TRAJ]DEFAULT_ACCELERATION did a huge difference,now everything works just fine as it was supposed to
thanks for the hint!
Alex
Alex
Time to create page: 0.324 seconds
