- Configuring LinuxCNC
- Advanced Configuration
- Manual gear change and max rpm (for constant surface speed)
12 Dec 2016 18:36 #83962
by Hakan
Manual gear change and max rpm (for constant surface speed) was created by Hakan
I would like to have a parameter say #<_maxrpm> that I can use in G96 statements, like
G96 D#<_maxrpm> S150
My lathe has a six speed manually operated gearbox. #<_maxrpm> needs to have its value set after which gear is used.
Right now I use a set of M101 - M106 command to manually set up the scaling for the speed. This works fine, except that I keep forgetting to enter the right M-code when I change gears. I can live with that. Here is an example for M104.
What I want is to have access to the MAXRPM value in a global parameter #<_maxrpm>.
When I enter a high max rpm in the G96 command, say
G96 D2000 S150
and the gearbox is in fourth gear and the spindle will only do 1770 rpm. The program stops here.
So I want to set the rpm in D to the max possible for the specific gear in use.
would work for any gear.
Is there a way to define a global parameter from M-code? Or even better from hal,
then I can use the auto-detection of gear.
#!/bin/bash
R=0.8846
MAXRPM=1770
halcmd setp scale.0.gain $R
halcmd setp scale.1.gain $(echo "scale=5;1.0 / $R"| bc -q)
exit 0
G96 D2000 S150
13 Dec 2016 13:01 #84025
Replied by andypugh on topic Manual gear change and max rpm (for constant surface speed)
There may be a neater way to do this.
linuxcnc.org/docs/2.7/html/remap/remap.h...remap:existing-codes
You can probably re-map the S-command to perform a G96 Sn Dxxxx automatically when G96 is in effect.
Having said that, is this really necessary? Presumably the spindle drive will just fail to go any faster if the required spindle speed is too high? Or is there a problem with spindle-at-speed not being set? If that is the case you could pass the spindle speed request through a limit block and compare to that.
13 Dec 2016 16:52 - 13 Dec 2016 20:02 #84044
by Hakan
I checked this. The vfd is a Huan Yang and it refuses to start with a higher speed commanded than its max. So it is the speed to the vfd that needs to be limited. I can put a limit to the max speed to the vfd, but what happens to the feed? Aren't the feed and speed out of sync?
motion.spindle-speed-out-abs is the wanted speed. motion.spindle-speed-in is the actual speed. Is motion okay with a large difference in set speed vs actual speed?
Edit:
On the last question I will answer YES. According to the documentation motion.spindle-speed-in is used by G96 and G95. Also my tests show that it works to put a limit on the rpm command sent to the vfd. I have not done any actual turning yet, but it looks ok running in the air, and the value of pins look ok at inspection.
So with that I think you are right andy, there is no need for a gear-specific rpm limit for G96. It is okay to set the highest rpm value that is comfortable for the lathe, and then the actual speed will be limited by the max limit in the vfd, if needed. Perfect. Better.
Replied by Hakan on topic Manual gear change and max rpm (for constant surface speed)
Edit:
Last edit: 13 Dec 2016 20:02 by Hakan. Reason: Tests done
Time to create page: 0.461 seconds
