Using jog wheel to move forward and backwards through a gcode program
08 Mar 2017 16:35 - 08 Mar 2017 16:35 #89209 by skunkworks
There is a reverse run branch that rob created that allows you to do
negative adaptive feed. This and some hal bits an you can 'jog' through
a gcode program. Don't know if I would ever use this.. but it is kinda
cool Someone had mentioned that another control had this
functionality - that made me want to see if it was possible..
I was using a HB04 wireless pendant - A real encoder with a good
velocity estimation would be a lot better. (I had to do some fiddly
bits to get a velocity from the encoder counts.)
robs branch is
feature/reverse-run-master2
sam
Last edit: 08 Mar 2017 16:35 by skunkworks.
25 Sep 2017 08:32 #99396 by parth1799
can any one tell me....where will i get feature/reverse-run-master2 on internet.
Time to create page: 0.152 seconds
